Devo7e work
the 8s module pinout (using the numbering in the flysky docs):skruth wrote: Another quick question about the replacement of devo7e's RF module with the one from 6s/8s.
Can anybody point me to a complete pinout of the 8s module (WK-21201RF). What I've digged from the devo8 connections and the flysky doc looks like:
1: chip select
2: SCK
3: GND
4: MOSI
5: MISO
6: V+
10:Reset
The Devo7e:
1) Chip Select
2) SCK
3) MISO
4) MOSI
5) Reset
6) V+
7) GND
PhracturedBlue wrote: the low pass filter will not cause the voltage to drop in that way unless there is a bug which there may well be.
Maybe MCU can be switched to 'sleep' mode in time ADC reading, for lowering noise?
- sbstnp
PhracturedBlue wrote: It turns out that the issue was that for some reason in continuous mode the ADC seems to pick up some coupling from the throttle channel. I've found I can still enable the low-pass filter without needing the ADC running fully in continuous mode. This fixes the voltage dependence on throttle without any negative effect. I've recalibrated the devo7e voltage and it should be withing 50mV from 4V to 5V.
It looks this has fixed the voltage readout on Devo 10 as well (at first look). I'll keep and eye on it and update the issue on BB.
EDIT: I spoke too soon, I got 10.05V reading and the dreaded "Battery too low can't save" at the same time lol. I'll update issue #234
Devo 10 + 4in1
FrSky Taranis + TBS Crossfire
- skruth
Cheers, Stefan
sbstnp wrote: EDIT: I spoke too soon, I got 10.05V reading and the dreaded "Battery too low can't save" at the same time lol. I'll update issue #234
Also, Devo 8, battery reading 4.77V and "Battery too low can't save" at the same time. Battery alarm 4.30V, batt_critical=3800.
- sbstnp
Mine was 7.5V critical, 8.8V alarm.
Devo 10 + 4in1
- Xermalk
You even get it with the charger connected.
Battery alarm 4.40V, batt_critical=3800
Im going to have to downgrade to a earlier version so i can fly tonight.
Its one helluva bug though, to bad you really cant increase or decrease the battery charge level simply by moving a stick
Does anyone know what the last working version was for the 7E?
I checked in a change that should prevent reading a glitch value which may prevent the battery low issue. Or not. Can't test until this weekend.
If a couple folks could test the latest code and see whether it actually helps of not, that would be helpful.
- sbstnp
PhracturedBlue wrote: If a couple folks could test the latest code and see whether it actually helps of not, that would be helpful.
The warning hasn't popped up in the last 2 minutes or so since I flashed my radio. I'll keep an eye on it for the next 15 minutes or so.
It used to appear on the 1 minute mark where I have set my low voltage alarm.
EDIT: ~20 minutes, no warning so far. Voltage looks good I lost around 0.2V with brightness set on 1.
Devo 10 + 4in1
I have never seen this bevor but I am not watching the battery voltage when flying...
Version: devo8-b79f385a1569
While charging: 6,02 - 5,63 - 5,33
Tomorrow I can flash an actual version.
- cmpang
method is to lower the power output bit by bit until the Rx just goes into failsafe mode. The critical settings for both Txs turned out to be the same value of 1mW.
Be reminded that both antennea have to be pointing in the same orientation during the test, as the original 7e antenna is unable to fold up during use and would natually lay parallel to the ground. While in the Devo 10 we usually points the antenna up to give the best radiation pattern.
okay. something is just broken here. I'll revisit the whole ADC thing again. Maybe for all but the devo12 go back to the old way of reading which seemed to work fine on all other tx.vlad_vy wrote: Devo 8. Now I have not "Battery too low, can't save", but sometimes I see accidental throws 10-40% at stick channels (Input monitor, Channel monitor and Main screen). 7e058aa9d523
- Xermalk
Edit: Theres a very high chance that one of my servos have been reversed from the random input. The joy of alpha firmware
Edit 2: called wolf to early. Seems i somehow corrupted my model.ini, so servo isnt reversed.
deviation-devo7e-d7e61bcd6c44.zip is still sending garbage over the channels though. And the channel monitor screen flickers when it does. Reverted to b76ac7445568 for now.
Edit 3: Voltage measurement seems to be working just fine in d7e61bcd6c44, PB you might want to hunt down exactly in what revision it broke.
arduino.cc/forum/index.php/topic,38119.0.html
int rawAnalogReadWithSleep( void )
// Generate an interrupt when the conversion is finished
ADCSRA |= _BV( ADIE );
// Enable Noise Reduction Sleep Mode
set_sleep_mode( SLEEP_MODE_ADC );
sleep_enable();
// Any interrupt will wake the processor including the millis interrupt so we have to...
// Loop until the conversion is finished
do
// The following line of code is only important on the second pass. For the first pass it has no effect.
// Ensure interrupts are enabled before sleeping
sei();
// Sleep (MUST be called immediately after sei)
sleep_cpu();
// Checking the conversion status has to be done with interrupts disabled to avoid a race condition
// Disable interrupts so the while below is performed without interruption
cli();
// Conversion finished? If not, loop.
while( ( (ADCSRA & (1<<ADSC)) != 0 ) );
// No more sleeping
sleep_disable();
// Enable interrupts
sei();
// The Arduino core does not expect an interrupt when a conversion completes so turn interrupts off
ADCSRA &= ~ _BV( ADIE );
// Return the conversion result
return( ADC );
What we now know:
On the devo12, the board wiring is introducing significant noise. We need low pass filtering here otherwise there is a lot of jitter
Continuous-read works well on the devo12, but seems to affect the voltage-sense value for an unknown reason.
shutting down the adc via an interrupt can cause a partial-write which appears as a channel glitch.
I will run further experiments. Ideally I'd like to use the same methods on all transmitters. But if I can't make that work, I'll use the old single-sample solution on the devo6/7e/8/10 and the low-pass solution on the devo12.
Let me know if you see any more issues.
- sbstnp
PhracturedBlue wrote: Ok, after a lot more testing, I have checked in a solution which seems to give stable voltage readings on all Tx, and does not exhibit the glitch behavior.
Flashing it right now. Will test tomorrow since it's almost 9PM here.
Devo 10 + 4in1
I just wanted to suggest something like that to prevent the need for 2 kind of ADC reading...
- Devo7e work
