How To apply "two switches" patch for Devo7e soft
- Xermalk
Or has the config files changed again so i need to remake them?
The latest nightly is almost a month old now. Strange.
I don't seem to have the menu issues on my devo 10 and the latest svn build ddf6350.
- kaworu
- jason4207
Got X4v2 full LED and anti-flip control as well as V222 accessory control on yesterday's nightly build. Also got the ability to use trims as switches.
Just added toggle switches to my 7E last night, and that's the only thing not working.
TIA!!
Edit: Daryoon hooked me up! Thanks bro!
- sllewji
- the emu key assignments are now made in the emu_devo7e target rather than the emu_common target.
- the emu key assignments now properly cater for when HAS_ADDITIONAL_SWITCHES is both defined and undefined - see below
I've modified the patch to use a define so the two-switch support can easily be turned on and off (comment out HAS_ADDITIONAL_SWITCHES in src/target/devo7e/target_def.h to turn it off)
I've also modified the emulator so it gets the additional switches too
The emu key assignments are :-
When HAS_ADDITIONAL_SWITCHES is defined :-
z = HOLD
x = ELE_DR
c = AIL_DR
v = FMOD
When HAS_ADDITIONAL_SWITCHES is not defined :-
z = HOLD
x = FMOD
I increased the number of trims from 6 to 10, which seems to work ok on my Tx, although PB did express a concern that the 7e might not have the resources to handle more than 6 - so caveat emptor if you decide to leave as-is.
Ian
If you are already using the latest nightly (c960b8e), you only need to flash the dfu and copy the protocols folder to the Tx - and copy the emu exe & dlls into your existing emu folder.
!!You try these files at your own risk!!
- cmpang
cmPang
- sllewji
Take note of the caveat before you proceed
Ian
- cmpang
sllewji wrote: I've updated my post above with the release zip files.
Ian
looking forward to it .. thx
- sllewji
- cmpang
sllewji wrote: I've now made the hardware mods to my Devo7e and noticed a couple of issues in the code I previously posted, so I've updated the code in my earlier post with corrections.
got it. Will test it out asap... thx
cmPang
- cmpang
cmPang
yep... it works.. thx..
BTW, would you like to go a step further to turn the two additional switches into a three positions type ?
- blackmoon
Thank you for your time if this is possible.
But I am quite sure that the implementation has to be changed because with a three-way-switch there are only 3 positions (right, left, middle) against four with the other solution (right-right, right-left, left-right, left-left).
- blackmoon
A combination of one three and one two way isn't possible.
If you look at the Devo7e hardware connections here: Devo7e-Hardware you can see in the table at the end that only two buttons are not connected. This is where the additional switches are placed. There are simply not more connections for more switches.
- cmpang
About half year ago, I was so surprise to find that a Chinese hobbist who has based on Deviation to provide a variation (sadly GUI in Chinese only) that incorporates two three position switches. Obviously, I too have the query the same as yours as there is only two unused switches left in the stock 7e.
The attached diagram show how it is being connected.
Trust me, ever since then I have used his version since May last year and not a single problem ever since.
After some thought and a hint given by Gale the author, the trick is since we have to use a reverse diode for the usual two switches upgrade anyway, why not add two more diodes to some other input point AND scan the switch matrix one more time but in reverse COL / ROW order. That is, if we did send signal out to COL and listen to switch closure from ROW, then the second scan is to send from ROW and listen to COL and only pay attention to the four target cross points.
It is a pity that there is not much space left on the 7e panel, otherwise I think even more switches can be added.
- cmpang
the two new position Gale added the diodes to is on the "Ail Trim left" and "Elev Trim up" cross point. And the Added switches are named "Ail D/R UP" and "Elev D/R UP". The original twoo added switches are thus "Ail D/R DN" and "Elev D/R DN"
Since there is no such thing as free lunch, it does has a limitation but that is of no border to me during actual usage ...
1. while you are pressing the "Ail Trim left", there would be no instant respose if you flip the "Ail D/R" switch. Not until the time you release the Trim switch then the switching action goes.
2. same for the "Elev Trim UP"
A very clever idea, isn't it?
- blackmoon
Even tough I only need one three way switch and one two way.
I think I read about a patch for this configuration but don't remember where...
- sllewji
So, in the tx_buttons.c scanbuttons() function, could we capture these additional switch values in a second, global variable - say glbl_snottub something like this? :-
static const u8 nuttobmap[] = {
BUT_TRIM_RH_POS, 32, BUT_TRIM_LV_POS, 31,
BUT_TRIM_RH_NEG, BUT_ENTER, BUT_TRIM_LV_NEG, BUT_DOWN,
BUT_TRIM_RV_POS, BUT_RIGHT, BUT_TRIM_LH_NEG, BUT_UP,
BUT_TRIM_RV_NEG, BUT_LEFT, BUT_TRIM_LH_POS, BUT_EXIT,
u32 glb_snottub = 0;
gpio_clear(ROW_PORT, ROW_PORT_MASK);
for(r = row; *r != 0xffff; c++) {
gpio_set(ROW_PORT, *r);
u16 but = gpio_port_read(COL_PORT);
gpio_clear(ROW_PORT, *r);
for(c = columns; *c != 0xffff; r++) {
if((but & *c)) {
glb_snottub |= 1 << (nuttobmap[idx] - 1);
idx++;
And then check for the value of that in channels.c CHAN_ReadRawInput(int channel).
Or am I way off the mark?
Ian
- cmpang
sllewji wrote: So the new connections as pictured in your post overlay the existing ones of c8/b8 and c6/b7, but should be read when the column/row were scanned in reverse to normal.
... static const u8 nuttobmap[] = { BUT_TRIM_RH_POS, 32, BUT_TRIM_LV_POS, 31, BUT_TRIM_RH_NEG, BUT_ENTER, BUT_TRIM_LV_NEG, BUT_DOWN, BUT_TRIM_RV_POS, BUT_RIGHT, BUT_TRIM_LH_NEG, BUT_UP, BUT_TRIM_RV_NEG, BUT_LEFT, BUT_TRIM_LH_POS, BUT_EXIT, ... u32 glb_snottub = 0; ... gpio_clear(ROW_PORT, ROW_PORT_MASK); for(r = row; *r != 0xffff; c++) { gpio_set(ROW_PORT, *r); u16 but = gpio_port_read(COL_PORT); gpio_clear(ROW_PORT, *r); for(c = columns; *c != 0xffff; r++) { if((but & *c)) { glb_snottub |= 1 << (nuttobmap[idx] - 1); } idx++; } } ...
Ian
Ian,
I am now too old to involve in the codings nowadays so just cannot tell.
But on the design level, the keypad scanning must be done in two opposite cycles in order to distinguish the ones with against the others without a diode.
Furthermore, since the original Trim switches are without diodes and so can be detected in both scans, hence the scan order should be first to scan for the no diodes, then secondly the one with diode. Should the switch without diode was found to be closed, then the corresponding diode switch action should be ignor (stay unchanged) during the second scan.
Needless to say, the second reverse scan has only to scan for the two targeted switches and not neccessary to carry out a full keypad scan
It works, I can assure you as I have been using his version for over half a year..
cmPang
- How To apply "two switches" patch for Devo7e soft
