publishing an intermediate release 3.1.0?
- WheresWaldo
12 Nov 2013 19:35 #15546
by WheresWaldo
Replied by WheresWaldo on topic publishing an intermediate release 3.1.0?
I did clone PB's repo but I can dump it and clone yours that way everything goes up to one spot. It only takes a few seconds to do that. I like the idea of stringing the screens together as one image. I will play a bit with Photoshop after pulling images from the emulator. I am going to start with the D10 as that is the TX I have and I can verify all the screens. I would like to also create a menu hierarchy chart, likely in Visio so that all the menu choices appear on one page.
I can pull all the screen shots, you have enough on your plate as it is.
The topic has been locked.
- kreidler
13 Nov 2013 20:14 #15555
by kreidler
Replied by kreidler on topic publishing an intermediate release 3.1.0?
Where can I find your output to help with my input. I also have a D10 only.
- Birdman
17 Nov 2013 05:05 #15633
by Birdman
Replied by Birdman on topic publishing an intermediate release 3.1.0?
Dummies question. Want to make sure this goes smoothly.
Upgrading from v3 to 3.1 on 8S
Have backed up models and tx.ini.
Do i only install fs download?
Bm
Bm
- Birdman
17 Nov 2013 05:15 #15634
by Birdman
is there a tutorial or vid for upgrading deviation?
TIA
Bm
TIA
Bm
- Birdman
17 Nov 2013 05:35 #15635
by Birdman
What is the DFU file for?
Bm
Bm
- Birdman
17 Nov 2013 05:42 #15636
by Birdman
DFU to firmware
FS to Library
Bm
FS to Library
Bm
- Birdman
17 Nov 2013 05:47 #15637
by Birdman
What is the easiest way to copy fs without tx.ini and currently configured models?
TIA
Bm
TIA
Bm
- Birdman
17 Nov 2013 05:52 #15638
by Birdman
Ignore previous posts, got it now.
Still half asleep, late night.
Bm
Bm
- Topic Author
17 Nov 2013 09:00 #15642
Replied by rbe2012 on topic publishing an intermediate release 3.1.0?
Birdman,
could you do me a favor and aggregate those post in a few? You can edit posts you have written before and in this forum it is usual to mark such additions with "Edit: ".
I would not do this with posts which do hardly belong to each other and not with those longer time ago or which have answers, but in this particular thread here it would have reduced the number probably to 1.
- DavidT
17 Nov 2013 10:35 #15647
by DavidT
Replied by DavidT on topic publishing an intermediate release 3.1.0?
Hi, Thanks for your efforts. When I upgraded from 300 to 310-b11 on a Mode1 Devo8s, I saved then deleted and replaced the file system. I then copied my model1.ini from v300 to the Tx but Left/Right sticks were reversed (Elevator operated Throttle). As a broader question is it possible to transfer models between these versions?
Thanks, David.
Thanks, David.
17 Nov 2013 11:06 #15648
Replied by FDR on topic publishing an intermediate release 3.1.0?
You probably just have to set the tx to be Mode1 again, because it changed to the default Mode2 when you overwritten the filesystem...
- DavidT
17 Nov 2013 11:19 #15649
by DavidT
Thank you. That fixed it.
Regards, David.
Regards, David.
- WheresWaldo
17 Nov 2013 15:18 - 17 Nov 2013 15:23 #15651
by WheresWaldo
@FDR - Do you think it might be a good idea to create a separate thread on 3.1 usage?
@RBE2012 - See attached files and tell me if this is what you were thinking.
It is definitely not as easy as I thought trying to stitch these images together. You can see from the Mixer.png that the spacing is off, it was the first one I did and I don't like it but wanted to progress. I may fix it later.
I am only about half way through the menus and I did not include the splash screen since my source has a different screen than the original. I do not like the swirly font, it doesn't fit with the industrial look of the rest of deviation (but that is a discussion for another time).
Last edit: 17 Nov 2013 15:23 by WheresWaldo.
17 Nov 2013 15:46 #15654
I think every separate subject should have it's own thread. That's what the threads are for...
WheresWaldo wrote: @FDR - Do you think it might be a good idea to create a separate thread on 3.1 usage?
- Topic Author
17 Nov 2013 21:22 #15658
When your Devo10-pictures are ready we can walk through the Devo7e menus and see what is different. This will be easier...
As I offered above I can take the pictures for other tx. I will start tomorrow with Devo12 and see how far and fast I come through. You should place this at the end of your list...
Yes, looks good. Maybe some pictures (like the mixer) are too long to fit in the text structure, but we (you!) will see this later when text and pictures are put together. Perhaps they should be shortened, but a decision is necessary for every single case.WheresWaldo wrote: @RBE2012 - See attached files and tell me if this is what you were thinking.
- WheresWaldo
18 Nov 2013 00:12 - 18 Nov 2013 00:31 #15662
by WheresWaldo
Replied by WheresWaldo on topic See new thread for documentation screen shots.
I have started a new thread in Development for the screen shots.
www.deviationtx.com/forum/7-development/...e-3-1-0-screen-shots
Last edit: 18 Nov 2013 00:31 by WheresWaldo.
- blackmoon
18 Nov 2013 20:17 - 18 Nov 2013 20:21 #15685
by blackmoon
Replied by blackmoon on topic publishing an intermediate release 3.1.0?
Don't know if I can post this here, if not I'll move.
Was playing whit devo10 and latest commit compiled this evening with VM, when the tx rebooted.
I was using my old model.ini files for Dev 3.0, maybe it's why...
I changed to model menu to load a new model, nothing on screen, hit ext or ent (don't remember well) key, reboot...
Is datalog.bin needed to ?
First time ever I had a reboot on the 10.
EDIT: just fell on this :
So sorry for the noise.
It's because I never looked into this part of code and it seems to me to need a huge effort - and I am not sure if it is worth this now. I think that PB is the only one who could read the error.txt and he seems to be still absend - so there is no use of the errors.txt at all.
Last edit: 18 Nov 2013 20:21 by blackmoon.
- Topic Author
18 Nov 2013 20:50 #15687
I will look into, but please upload your devo10.elf and devo10.map. Maybe I can "read" the errors.txt now...
- blackmoon
18 Nov 2013 21:41 - 18 Nov 2013 21:44 #15690
by blackmoon
The files as requested.
I should add that the sources were patched with babay's HiSky patch, just in case.
I remember that i was going from a PPM based model to the model menu.
Last edit: 18 Nov 2013 21:44 by blackmoon.
- richardclli
18 Nov 2013 23:55 #15691
by richardclli
Replied by richardclli on topic publishing an intermediate release 3.1.0?
Did you replace the filesystem completely with the new one? I found that replacing the whole filesystem is essential when upgrading from 3.0 to 3.1, however you may reuse the old model files afterwards.
Time to create page: 0.118 seconds
- Home
- Development
- Development
- publishing an intermediate release 3.1.0?
