Devo Loader. Now working Fully
- SadSack
You'll have to give me while to sort my edits to code. I use IAR ide, free version but could done using codewarrior lite.
i'm guessing serial loader would work without the need to alter Boot pins and Reset, Hold backdoor button and update simples.
- SadSack
- SadSack
Now had a thought about that.
OpenBTL does have other ways it can work, update from flash. Deviation has USB built in all ready and not OS dependent. So what if we could use that instead. And with other Devo Tx's there so much more flash free so make boot area larger if needed and run it so we have option to load different Dev builds and go back to release build at will. Rename 'Protocol' folder to reflect Build number or keep folder for stock setup plus Dev folder. Maybe it could even be away round 7e limited space, remove options as needed but go back when needed.
Now I don't know if this is even doable but I see in Deviation code that bootloader can be deleted. Could deviation be used to replace loader so no need to open Tx or need any extra hardware.
But would mean no going back to Stock Walkera which I know would be a shame.
Oh I wouldn't be able to do any of that
- victzh
Theoretically, you just need to connect BOOT0 to VDD - there is a conveniently broken out header inside of Devo - 2-pin 100 mil between plated holes - just between SWD header and RF module.
- SadSack
- blackmoon
How did you circumvented the software shutdown issue ?
You save the model before shutdown, I would rather not have to implement the power up/down circuit.
But just in case, I know PB posted a schematic some time ago, do you happen to have a link for it ?
- SadSack
Devo10 power circuit can't put my finger to it this sec. When I get to it I'll add it to my eagle circuit and sorry Kicad not happening.
I've been looking at circuit for WK29-2801 and still think this could be very low part upgrade all be it few meters of wire. Will need to replace 16k flash.
- blackmoon
SadSack wrote: Still
But still say "Eagle sucks
- SadSack
Up till yesterday I've been using Rugwarriors build of MinGW DeviationTX and very happy works fine. Until the limited space on 7e showed its face and different builds/Os gave different size code. So I tried sbstnp VM and worked out great and fixed something I still don't get why but I've no idea even how I'm to edited code in there.
So the favor if anyone can using windows mingw could you compile devo7e and convert elf to Srec Please ? OBJCOPY -Osrec devo7e.elf devo7e.srec. I'm hoping my install is just broken though I have tried many combo's today and can even compile to 115.86k. But loader does not like it at all but code works when loaded other ways.
Also I'm wondering even if mine is just one off broken install that I should be using same tool chain as Pb just to be on same page/results?
Thanks, Phil
- sbstnp
SadSack wrote: ...I still don't get why but I've no idea even how I'm to edited code in there
Give the PDF a read, the VM is sharing a folder with the host so you basically can use your favorite Windows editor for code editing (or learn vim, but I guess that's out of the question
Shoot me a PM if you have other questions.
Devo 10 + 4in1
FrSky Taranis + TBS Crossfire
- blackmoon
www.ebay.com/itm/261095318207?ru=http%3A...095318207%26_rdc%3D1
Even cheaper than DX and faster to
- SadSack
arduinosolutions.com/upload/download/Cor...V_107V_207V_407V.pdf
- SadSack
- blackmoon
- Devo Loader. Now working Fully
