Release 3.1.0 Screen Shots
- WheresWaldo
- D10Menus are the top level menu screens from the Devo10.
- D10Mixer are all the mixer screen from the Devo10.
- D10ModelSetup contains all screen for Model setup from Devo10.
- D10OtherScreens contains Trims, Timers, Telemetry, Main Screen Configuration.
- WheresWaldo
I think this is everything but language selection and calibration screens. I cannot get the screen calibration screens to display on my Windows system. Each time the emulator tries it crashes back to the MinGW prompt (this is with beta 11 and all recent commits).
I will try this. I can take the picture from my Linux pc:WheresWaldo wrote: I cannot get the screen calibration screens to display on my Windows system. Each time the emulator tries it crashes back to the MinGW prompt (this is with beta 11 and all recent commits).
- kreidler
1. Even if I do not use the 'Standard GUI' there are no screenshots from this interface with the different sub screens included. So, ModelMenu.png should be renamed to ModelMenuAdvanced.png.
2. Adding ModelSetupCopy, ModelSetupReset and ModelSetupTemplate with a screenshot of the templates would be fine.
3. I am not sure, but some screens from PPMin like a sub screen with stick mode I cannot find.
4. On the TelemetryConfig at least one line with some input data would be helpful.
5. Do plan to show the channel monitor and telemetry monitor?
Waldo, if you want, I can add all during the next days?
- WheresWaldo
rbe2012 wrote: I will try this. I can take the picture from my Linux pc:
Thanks, is the mouse pointer really there on the Devo8 or should I remove it from the screenshot.
kreidler wrote: I do not have my Devo or the emu on hand yet. So, may be a bit confusing:
- I have never used Standard GUI so I will need to figure out two things, first how to enable it and then what screens are changed.
- If there is a screen for it, we will need it. I tried to go through most of the GUI but obviously I have missed a few screens.
- Some protocols do not have sub menus.
- We can always add data where it explains a setting, but I wanted to get all the screenshots first and only used the default settings. The default on this screen is no data.
- Yes.
Here is where my head is on this. The images should be of the default settings, the accompanying text should explain the options. If we try to use screenshots for every permutation then we might as well make a video rather than written documentation. Or do what Mikado does with the Vbar and have the docs as a series of HTML screen and web based only. I am open to all suggestions if we need a screen to clarify a complex setting.
I am not opposed to a web only version, it could easily lend itself to an epub version that could be sort of interactive. My big problem is that I am not good at all with HTML code.
I have removed it from one picture, but seem to have overseen some... please remove it, we have no pointer on Devo6/8/12.WheresWaldo wrote: is the mouse pointer really there on the Devo8 or should I remove it from the screenshot.
In model menu go to model config and change Mixer GUI to "Standard". Many screens change (including the model config screen).need to figure out two things, first how to enable it and then what screens are changed.
Maybe we should make extra docs (or chapters) for the different protocols and their options. I believe they might be good to separate.
The idea of creating an "interactive" documentation sounds good, but I would highly appreciate to have also a documentation on paper. Maybe we can put links in the document itself which lead to other sections? This should be possible with many formats.
- kreidler
- Yes.
1. Accessing like written before from rbe. I also never use this but through the main page config menu 1 to 4 you can open most or even all of them. New D10Menu.zip attached. I will go through the menus to see what is still missing. Name proposal D10ModelMenuStandard.zip
2. I already did the shots and will add them with next post.
3. Misunderstanding NOT protocol I meant PPMin Teacher mode. I will do the shots and add them to ModelSetup.
4. Understood. Please reconsider if one line might be helpful for all explanations.
5. Your turn
- kreidler
D10ModelSetup attached with 6 new screens. The Reset screen is not a real screen but in my opinion necessary to understand how to reset a model.kreidler wrote: 2. I already did the shots and will add them with next post.
EDIT:
Now attached.kreidler wrote: 1. Accessing like written before from rbe. I also never use this but through the main page config menu 1 to 4 you can open most or even all of them. New D10Menu.zip attached. I will go through the menus to see what is still missing. Name proposal D10ModelMenuStandard.zip
- WheresWaldo
- WheresWaldo
PhracturedBlue wrote: you should zip the psd file to upload it
Won't let me upload the zip either. Even tried it in a new post. Is there a physical limit to the amount of space for attachments?
- WheresWaldo
That's it, it's 1.2 MB. Still sucks.FDR wrote: It is probably over the allowed 1Mb limit...
FYI, while I really appreciate the help, I'll likely need to convert your psd files int xsd (GIMP) before taking them. It is the same reason I use Open-Office instead of Word for the documentation. I strongly believe the entire design system should be open-source such that proprietary software isn't needed to do things like update documentation (even when the free tools are worse as they are in these cases)
Why do you need all the screens in one file as layers?
Split them into separate files, and you can pack them into more less then 1Mb zip files...
- WheresWaldo
PhracturedBlue wrote: probably hitting the size limit then.
I will split each screen out, but it is easier to work with one file and not 100. Why .xsd and not a more universal graphics format like .png (which could also be used on any type of web page).
FDR wrote: Why do you need all the screens in one file as layers?
The first sentence above explains my rational. don't really want to keep track of 100+ different files for all included versions, Also easier to find duplicates. Consider the differences on some of the Standard vs. Advanced mixer screens, in may cases it's the same screen with the addition of a left and right arrow button at the top right corner.
A quick question, why are the stick calibrations on separate pages rather than a modal dialog box?
I just wanted to get a quick sanity check to make sure I didn't forget any screens without saving each and every one.
For the same reason you use psd. The primary source (used for editing) is what I want in an open-source format. The final files will be compiled to whether is necessary (pdf, web, whatever)WheresWaldo wrote:
I will split each screen out, but it is easier to work with one file and not 100. Why .xsd and not a more universal graphics format like .png (which could also be used on any type of web page.
- Release 3.1.0 Screen Shots
