Single-Board Universal Module
09 May 2014 22:58 - 13 May 2014 03:05 #23090 by PhracturedBlue
Single-Board Universal Module was created by PhracturedBlue
Over the past few weeks, I've talked to a few folks about designing a single-board Universal module. This would differ from the 'MultiMod' design in that it would be a single board with 4 transceivers populated on it.
It would be much smaller than an assembled MultiMod, and require signifcantly less power. It would also only have a single antenna, and would likely be directly swappable with the stock module in the Devo6/8/10/12 (sorry 7e folks, you'd need to do some soldering)
It sounds great, right? Well there are some downsides:
a) It is not something that can be hand assembled (well maybe by someone crazy, but not me). The chips are miniscule, and use leadless packages
b) Because it must be sold assembled, it will need to go through FCC compliance testing which is many thousands of dollars (assuming it passes the 1st time through)
c) development is costly due to the high cost of protocotypes. Mistakes are expensive.
That said, I've talked to some folks who have experience in designing RF boards, and getting them through FCC. I DO NOT at this time have any commitments that someone with experience will actually help, but there has been some interest.
So the 1st step was to get a feel for the design. To do that, I put together a circuit diagram. The board has a similar concept to the MultiMod board. I use a uC to act as a smart-switch todirect SPI signals to one of 4 transceivers. But whereas the MultiMod has 4 different boards attached to it, for this design, the 4 transceiver chips are directly mounted on a single PCB. The output of each transceiver is directed through a 4:1 multiplexer, and then into a single PA/LNA chip, finally terminating in a single U.FL antenna plug.
Because of the cost of FCC testing, it makes sense to build a multipurpose board. So instead of the ATTiny used in the MultiMod, I've chosen an STM32F0 uC. When used in a Devo Tx, the programming would be very similar to the MultiMod, and this would be hugely overkill (though it adds very little additional cost). However, this design allows for attaching an LCD screen and rotary-encoder to enable using the same board as a stand-alone PPM-in design (like the MagicCube or Anylink) that would work with any transmitter. In this configuration, the board would be packaged in its own enclosure. The Deviation protocol stack would be loaded onto the uC, and you would select a protocol via a knob on the enclosure.
While I've done a little work on this, I want to stress that there is no guarantee this will ever see production. I don't have any experience in RF design, and unless I can find someone who has done it, this won't get off the ground. But I'm putting my work so far out there. I know a few of you have some RF experience, and could possibly give some feedback. I will start work on the circuit board next, and we'll see how that goes. Note that I decided to use Eagle for this design. It should make it easier for others to contribute should they desire.
It also has virtually no bearing on the MultiMod work. I'm going to continue to refine the software on that with the hope we can get all known issues with it resolved.
BOM
Part Value          Device         Package         Description        DIGIKEY#             MANF               MANF#              MOUSER#               PROD_ID    VALUE
C1   33nF           C_0402         C0402           NON-POLARIZED CAP        490-6333-6-ND        Murata             GRM155R71C333KA01J 81-GRM155R71C333KA1J
C2   10nF           C_0402         C0402           NON-POLARIZED CAP        490-1313-6-ND        Murata             GRM155R71C103KA01D 81-GRM155R71C103KA1D
C3   1nF            C_0402         C0402           NON-POLARIZED CAP        490-3244-6-ND        Murata             GRM1555C1H102JA01D 81-GRM1555C1H102JA1D
C4   22pF           C_0402         C0402           NON-POLARIZED CAP        490-8173-6-ND        Murata             GRM1555C1E220GA01D 81-GRM1555C1E220GA1D
C5   22pF           C_0402         C0402           NON-POLARIZED CAP        490-8173-6-ND        Murata             GRM1555C1E220GA01D 81-GRM1555C1E220GA1D
C6   2.2nF          C_0402         C0402           NON-POLARIZED CAP        490-6358-6-ND        Murata             GRM155R71H222JA01D 81-GRM155R71H222JA1D
C7   4.7pF          C_0402         C0402           NON-POLARIZED CAP        490-6244-6-ND        Murata             GRM1555C1H4R7BA01D 81-GRM1555C1H4R7BA1D
C8   1.5pF          C_0402         C0402           NON-POLARIZED CAP        490-6212-6-ND        Murata             GRM1555C1H1R5BA01D 81-GRM1555C1H1R5BA1D
C9   1.0pF          C_0402         C0402           NON-POLARIZED CAP        490-6206-1-ND        Murata             GRM1555C1H1R0BA01D 81-GRM1555C1H1R0BA1D
C10  680pF          C_0402         C0402           NON-POLARIZED CAP        490-3240-6-ND        Murata             GRM1555C1H681JA01D 81-GRM1555C1H681JA1D
C11  10nF           C_0402         C0402           NON-POLARIZED CAP        490-1313-6-ND        Murata             GRM155R71C103KA01D 81-GRM155R71C103KA1D
C12  0.1uF          C_0402         C0402           NON-POLARIZED CAP        490-1318-6-ND        Murata             GRM155R61A104KA01D 81-GRM155R61A104KA1D
C13  27pF           C_0402         C0402           NON-POLARIZED CAP        490-6224-6-ND        Murata             GRM1555C1H270GA01D 81-GRM1555C1H270GA1D
C14  33pF           C_0402         C0402           NON-POLARIZED CAP        490-6232-6-ND        Murata             GRM1555C1H330GA01D 81-GRM1555C1H330GA1D
C15  2.2uF          C_0402         C0402           NON-POLARIZED CAP        399-7375-6-ND        Kemet              C0402C225M8PACTU   80-C0402C225M8P
C16  2.2uF          C_0402         C0402           NON-POLARIZED CAP        399-7375-6-ND        Kemet              C0402C225M8PACTU   80-C0402C225M8P
C17  2.2uF          C_0402         C0402           NON-POLARIZED CAP        399-7375-6-ND        Kemet              C0402C225M8PACTU   80-C0402C225M8P
C18  120pF          C_0402         C0402           NON-POLARIZED CAP        490-8183-6-ND        Murata             GRM1555C1H121GA01D 81-GRM1555C1H121GA1D
C19  1.5nF          C_0402         C0402           NON-POLARIZED CAP        490-6354-6-ND        Murata             GRM155R71H152KA01J 81-GRM155R71H152KA1J
C20  2pF            C_0402         C0402           NON-POLARIZED CAP        490-6226-6-ND        Murata             GRM1555C1H2R0BA01D 81-GRM1555C1H2R0BA1D
C21  47pF           C_0402         C0402           NON-POLARIZED CAP        490-8206-6-ND        Murata             GRM1555C1H470GA01D 81-GRM1555C1H470GA1D
C22  0.1uF          C_0402         C0402           NON-POLARIZED CAP        490-1318-6-ND        Murata             GRM155R61A104KA01D 81-GRM155R61A104KA1D
C23  47pF           C_0402         C0402           NON-POLARIZED CAP        490-8206-6-ND        Murata             GRM1555C1H470GA01D 81-GRM1555C1H470GA1D
C24  0.1uF          C_0402         C0402           NON-POLARIZED CAP        490-1318-6-ND        Murata             GRM155R61A104KA01D 81-GRM155R61A104KA1D
C25  220pF          C_0402         C0402           NON-POLARIZED CAP        490-1293-6-ND        Murata             GRM1555C1H221JA01D 81-GRM1555C1H221JA1D
C26  0.1uF          C_0402         C0402           NON-POLARIZED CAP        490-1318-6-ND        Murata             GRM155R61A104KA01D 81-GRM155R61A104KA1D
C27  0.1uF          C_0402         C0402           NON-POLARIZED CAP        490-1318-6-ND        Murata             GRM155R61A104KA01D 81-GRM155R61A104KA1D
C28  220pF          C_0402         C0402           NON-POLARIZED CAP        490-1293-6-ND        Murata             GRM1555C1H221JA01D 81-GRM1555C1H221JA1D
C29  15pF           C_0402         C0402           NON-POLARIZED CAP        490-6200-6-ND        Murata             GRM1555C1H150FA01D 81-GRM1555C1H150FA1D
C30  15pF           C_0402         C0402           NON-POLARIZED CAP        490-6200-6-ND        Murata             GRM1555C1H150FA01D 81-GRM1555C1H150FA1D
C31  220pF          C_0402         C0402           NON-POLARIZED CAP        490-1293-6-ND        Murata             GRM1555C1H221JA01D 81-GRM1555C1H221JA1D
C32  0.47uF         C_0402         C0402           NON-POLARIZED CAP        490-3266-6-ND        Murata             GRM155R60J474KE19D 81-GRM155R60J474KE9D
C33  22pF           C_0402         C0402           NON-POLARIZED CAP        490-8173-6-ND        Murata             GRM1555C1E220GA01D 81-GRM1555C1E220GA1D
C34  2.2uF          C_0402         C0402           NON-POLARIZED CAP        399-7375-6-ND        Kemet              C0402C225M8PACTU   80-C0402C225M8P
C35  10pF           C_0402         C0402           NON-POLARIZED CAP        490-6186-6-ND        Murata             GRM1555C1H100FA01D 81-GRM1555C1H100FA1D
C36  1.0pF          C_0402         C0402           NON-POLARIZED CAP        490-6206-6-ND        Murata             GRM1555C1H1R0BA01D 81-GRM1555C1H1R0BA1D
C37  100pF          C_0402         C0402           NON-POLARIZED CAP        490-6188-6-ND        Murata             GRM1555C1H101GA01D 81-GRM1555C1H101GA1D
C38  NC             C_0402         C0402           NON-POLARIZED CAP
C39  1.0pF          C_0402         C0402           NON-POLARIZED CAP        490-6206-6-ND        Murata             GRM1555C1H1R0BA01D 81-GRM1555C1H1R0BA1D
C40  1.0pF          C_0402         C0402           NON-POLARIZED CAP        490-6206-6-ND        Murata             GRM1555C1H1R0BA01D 81-GRM1555C1H1R0BA1D
C41  100pF          C_0402         C0402           NON-POLARIZED CAP        490-6188-6-ND        Murata             GRM1555C1H101GA01D 81-GRM1555C1H101GA1D
C42  100pF          C_0402         C0402           NON-POLARIZED CAP        490-6188-6-ND        Murata             GRM1555C1H101GA01D 81-GRM1555C1H101GA1D
C43  1.0pF          C_0402         C0402           NON-POLARIZED CAP        490-6206-6-ND        Murata             GRM1555C1H1R0BA01D 81-GRM1555C1H1R0BA1D
C44  1.0pF          C_0402         C0402           NON-POLARIZED CAP        490-6206-6-ND        Murata             GRM1555C1H1R0BA01D 81-GRM1555C1H1R0BA1D
C45  1.8pF          C_0402         C0402           NON-POLARIZED CAP        490-6215-6-ND        Murata             GRM1555C1H1R8BA01D 81-GRM1555C1H1R8BA1D
C46  1.5pF          C_0402         C0402           NON-POLARIZED CAP        490-6212-6-ND        Murata             GRM1555C1H1R5BA01D 81-GRM1555C1H1R5BA1D
C47  15pF           C_0402         C0402           NON-POLARIZED CAP        490-6200-6-ND        Murata             GRM1555C1H150FA01D 81-GRM1555C1H150FA1D
C48  2pF            C_0402         C0402           NON-POLARIZED CAP        490-6226-6-ND        Murata             GRM1555C1H2R0BA01D 81-GRM1555C1H2R0BA1D
C49  1.5pF          C_0402         C0402           NON-POLARIZED CAP        490-6212-6-ND        Murata             GRM1555C1H1R5BA01D 81-GRM1555C1H1R5BA1D
C50  2pF            C_0402         C0402           NON-POLARIZED CAP        490-6226-6-ND        Murata             GRM1555C1H2R0BA01D 81-GRM1555C1H2R0BA1D
C51  1uF            C_0805         C0805           NON-POLARIZED CAP        490-1695-6-ND        Murata             GRM21BR71A105KA01L 81-GRM40X105K10L
C52  10uF           C_0805         C0805           NON-POLARIZED CAP        490-1709-6-ND        Murata             GRM21BR61A106KE19L 81-GRM21BR61A106KE19
C53  10uF           C_0805         C0805           NON-POLARIZED CAP        490-1709-6-ND        Murata             GRM21BR61A106KE19L 81-GRM21BR61A106KE19
D1   LSM115J        LSM115J        DO214BA        LSM115JE3/TR13DKR-ND Microsemi          LSM115JE3/TR13
D2   LSM115J        LSM115J        DO214BA        LSM115JE3/TR13DKR-ND Microsemi          LSM115JE3/TR13
IC1  STM32-M-48     STM32-M-48     LQFP48          STM32F103 Medium Density 48pins                                                     497-14645-ND         STMicroelectronics STM32F072CBT6
IC2  3.3V           LD1117SOT223   SOT223          Voltage Regulator LM1117                                                            497-1241-1-ND        STMicroelectronics LD1117S33CTR       511-LD1117S33C
J1   U.FL           U.FL           U.FL            SMD antenna connector- WRL-09144                                                    WM5587DKR-ND         Molex              0734120110                               CONN-09193 U.FL
JP1  2X5            2X5            2X5
JP2                 JST-PH7        JST-PH7
JP3                 JST-PH6        JST-PH6
JP4                 JST-PH4        JST-PH4
JP5                 JST-PH4        JST-PH4
JP6  USBSMD         USBSMD         USB-MINIB       USB Connectors        670-1190-6-ND        JAE                DX2R005HN2E700                           CONN-08193
L1   8.2nH          L_0402         L0402           INDUCTOR        PCD1909DKR-ND        Panasonic          ELJ-RF8N2ZFB       667-ELJ-RF8N2ZFB
L2   3.9nH          L_0402         L0402           INDUCTOR        PCD1905DKR-ND        Panasonic          ELJ-RF3N9ZFB       667-ELJ-RF3N9ZFB
L3   3.9nH          L_0402         L0402           INDUCTOR        PCD1905DKR-ND        Panasonic          ELJ-RF3N9ZFB       667-ELJ-RF3N9ZFB
L4   1.2nH          L_0402         L0402           INDUCTOR        PCD1899DKR-ND        Panasonic          ELJ-RF1N2ZFB       667-ELJ-RF1N2ZFB
L5   4.7nH          L_0402         L0402           INDUCTOR        PCD1906DKR-ND        Panasonic          ELJ-RF4N7ZFB       667-ELJ-RF4N7ZFB
L6   22nH           L_0402         L0402           INDUCTOR        PCD1914DKR-ND        Panasonic          ELJ-RF22NGFB       667-ELJ-RF22NGFB
L7   1.2nH          L_0402         L0402           INDUCTOR        PCD1899DKR-ND        Panasonic          ELJ-RF1N2ZFB       667-ELJ-RF1N2ZFB
L8   1.2nH          L_0402         L0402           INDUCTOR        PCD1899DKR-ND        Panasonic          ELJ-RF1N2ZFB       667-ELJ-RF1N2ZFB
L9   1.2nH          L_0402         L0402           INDUCTOR        PCD1899DKR-ND        Panasonic          ELJ-RF1N2ZFB       667-ELJ-RF1N2ZFB
L10  1.8nH          L_0402         L0402           INDUCTOR        PCD1901DKR-ND        Panasonic          ELJ-RF1N8ZFB       667-ELJ-RF1N8ZFB
L12  1.5nH          L_0402         L0402           INDUCTOR        PCD1900DKR-ND        Panasonic          ELJ-RF1N5ZFB       667-ELJ-RF1N5ZFB
L13  2.7nH          L_0402         L0402           INDUCTOR        PCD1903DKR-ND        Panasonic          ELJ-RF2N7ZFB       667-ELJ-RF2N7ZFB
R1   1M             R_0402         R0402           RESISTOR        P1.0MJDKR-ND         Panasonic          ERJ-2GEJ105X       667-ERJ-2GEJ105X
R2   22k            R_0402         R0402           RESISTOR        P22KJDKR-ND          Panasonic          ERJ-2GEJ223X       667-ERJ-2GEJ223X
R3   200            R_0402         R0402           RESISTOR        P200JDKR-ND          Panasonic          ERJ-2GEJ201X       667-ERJ-2GEJ201X
R4   56.2k          R_0402         R0402           RESISTOR        P56.2KLDKR-ND        Panasonic          ERJ-2RKF5622X      667-ERJ-2RKF5622X
R5   10k            R_0805         R0805           RESISTOR        P10KADKR-ND          Panasonic          ERJ-6GEYJ103V      667-ERJ-6GEYJ103V
R6   NC             R_0402         R0402           RESISTOR
R7   NC             R_0805         R0805           RESISTOR
U$1  A7105          A7105          QFN20        Amiccom
U$2  NRF24L01       NRF24L01       QFN20           nRF24L01        1490-1033-6-ND       Nordic             NRF24L01P-R7
U$3  CC2500         CC2500         QFN20        296-19586-2-ND       TI                 CC2500RTKR
U$4  CYRF6936       CYRF6936       QFN40-6X6        428-2962-ND          Cypress            CYRF6936-40LTXC
U$5  RFX2401C       RFX2401C       QFN16        RF Axis            RFX2401C
U$6  SKY13384-350LF SKY13384-350LF QFN16        863-1456-6-ND        Skyworks           SKY13384-350LF
Y1   26MHz          CRYSTAL5X3     CRYSTAL-SMD-5X3 Various standard crystals. Proven footprints. Spark Fun Electronics SKU : COM-00534 887-1716-6-ND        TXC                AB-26.000MAGE-T    717-AB-26.000MAGE-T
Y2   12MHz          CRYSTAL5X3     CRYSTAL-SMD-5X3 Various standard crystals. Proven footprints. Spark Fun Electronics SKU : COM-00534 887-1701-6-ND        TXC                AB-12.000MALE-T    717-AB-12.000MALE-T
Y3   16MHz          CRYSTAL5X3     CRYSTAL-SMD-5X3 Various standard crystals. Proven footprints. Spark Fun Electronics SKU : COM-00534 887-1707-6-ND        TXC                AB-16.000MAGE-T    717-AB-16.000MAGE-T
Y4   16MHz          CRYSTAL5X3     CRYSTAL-SMD-5X3 Various standard crystals. Proven footprints. Spark Fun Electronics SKU : COM-00534 887-1707-6-ND        TXC                AB-16.000MAGE-T    717-AB-16.000MAGE-T
Last edit: 13 May 2014 03:05 by PhracturedBlue.
10 May 2014 00:30 #23093 by Freezywilly
Replied by Freezywilly on topic Single-Board Universal Module
PB I would like your permission to bring this topic up in professional engineering forums. There many talented people that do not either know about the RC hobby or just have other interests. This is important enough that getting some real experts in RF
could be so big none of us know just where it may go.
10 May 2014 01:43 #23097 by cmpang
Replied by cmpang on topic Single-Board Universal Module
sounds great. How about a module that can be plug into FrSky Transis?
10 May 2014 02:53 #23098 by PhracturedBlue
Replied by PhracturedBlue on topic Single-Board Universal Module
FreezyWilly,
The hardware design will be entirely open-source. For various reasons, it is extraordinarily unlikely I will ever sell them myself, or try to make any profit on this design. My goal is to provide a robust design, and work with a manufacturer to build and sell the boards. I am open to any and all assistance I can get to make that happen.
cmpang,
the multimod board will (soon) work in the Taranis, but unfortunately it requires some soldering in tight spaces.
The design of this board could make it possible to plug into the Taranis with no hardware modifications. I don't know what sort of interface will be necessary for that to happen. My priority will likely be to make a drop-in module for the Devo 1st.
But again, I expect this to be a long process, and there is no guarantee it will ever come to fruition.
10 May 2014 04:10 #23099 by Fixy
Replied by Fixy on topic Single-Board Universal Module
This is a great idea many people would be interested. I think companies(and probably many users too) might be more interested in a JR type module rather than DIY one. Anyway a few comes to mind that might be interested.
Hobbyking/Turnigy/OrangeRX and the like are always interested in making easy money on open source projects.
FrSky is already in the open source hardware development so they might want to continue the adventure after the Taranis success.
Also HiSky seems to be very interested in the deviation project, they might want to get invested in this.
Good luck with this very nice project.
10 May 2014 05:35 #23102 by victzh
Replied by victzh on topic Single-Board Universal Module
The existing design is slightly problematic from the point of view of nRF24L01 and several protocols running on it. The problem is in PA switch from transmit to receive. In this design it is controlled from the MCU, while there is an auto-acknowledgement mode in nRF which is used by some protocols, when the radio switches to receive to get an incoming packet automatically. To catch this exact moment and switch the PA fast enough from the MCU seems unfeasible. I am not aware of the situation with other chips, I don't know them enough, but if there is an auto-acknowledgement mode or its analogue there it will be problematic also.
Other than that I think your schematic is a very good start.
10 May 2014 12:47 - 10 May 2014 13:27 #23112 by PhracturedBlue
victzh I actually thought of that. It is why the VDD_PA signal is sent back to the MCU from the NRF24L01. My plan is to use that pin as an interrupt to switch the tx/rx enables. The ARM core will run at 48MHz, and has ~1instruction per cycle. It should be plenty fast enough to react to the Rx/Tx change. The other option was to use some logic gates to achieve the same behavior. I like this better, because it is overall simpler. We can also be smarter. All nrf24l01 designs I've seen always have either the PA or LNA enabled. with this setup we have the option to disable both when the chip is idle.
One thing I need to check is that 1.8V (the value on VDD_PA) is sufficient to trigger a logic change on the stm32. Otherwise I'll run it through an nfet to get a full-rail transition
Edit: I took a look, and I'm skeptical that 1.8V will flip the Shmitt trigger input, so I've rerouted VDD_PA to PA1 which has a comparator function with an adjustable internal reference
Last edit: 10 May 2014 13:27 by PhracturedBlue.
10 May 2014 12:56 #23113 by PhracturedBlue
Fixy,
The JR modules are just PWM devices in a different package. It isn't really any different than an Anylink module which I discussed above. I agree that there are many more users who'd like such a thing, but as I've said in the past, it isn't really something I'm interested in. The problem is that many of the protocols have options that provide control of them, and it will require some sort of interface to provide access to those. It adds complication and expense.
So I'm focusing on radios that use Deviation.
The Taranis is a special case, because it is open source, we can (hopefully) use Deviation to run an I2S protocol over the PWM line and use the STM32 as a i2s to spi translator. Without understanding the technical side, it means that with some software changes, it should be possible to allow Deviation to use one of these boards plugged into the Taranis's module socket, and have full access to telemetry and all protocol controls.
10 May 2014 17:56 #23117 by Fixy
Ok I think I understand. PWM is not enough to unlock the full potential of all protocols but on the taranis you can run I2S(the protocol taranis uses!?) through it which is then translated to SPI(the deviation protocol!?) :huh: it surely make it less interesting from a business point of view except for frsky.
So this means that the taranis won't run deviation but a tweaked opentx with a "deviation module" right?
Anyway taranis/devo users will love this, I wonder if frsky next gen tx will be compatible cause I'm not really interested in a taranis but the horus might be tempting if it ever gets released.
Out of curiosity is there any other open source radio this might be compatible with like the 9X/9XR series?
10 May 2014 19:07 #23118 by victzh
PhracturedBlue, I noticed that circuit, but I am not sure when the VDD_PA becomes active - if at the end of transmission then you have 130 microseconds for PLL lock to switch the PA, but if after PLL lock then it may be very fast for interrupt handling. Unfortunately, datasheet is not clear about this. What I've seen in PA-enabled nRF implementations is that it is connected through low pass filter to TXEN of (typically) RFAXIS RFX2401c PA. May be it's possible to figure out it's time constant, otherwise I don't know how to reliably measure it.
10 May 2014 20:41 - 10 May 2014 20:42 #23119 by PhracturedBlue
I have an nrf24L01 with RFX2401C that uses some sort of switch to set the PA_EN/LNA_EN signals. It is labeled as 'V4' and in SOT23-6, but I have no idea how to figure out what it actually is. I don't know how fast it reacts. I'd be really surprised if they don't leave enough time to transition the amplifier, but figuring that out would be challenging. I really don't want to add the discrete components to bypass the uC control unless it is necessary.
One possibility would be to test it on an existing board by cutting the enable traces to the PA, and routing them (and VDDPA) through a STM32 board, and see if the ACK can still be detected.
That shouldn't be too hard to do, and is probably a good mitigation plan.
Last edit: 10 May 2014 20:42 by PhracturedBlue.
10 May 2014 22:23 #23123 by victzh
This 'V4' chip is not always present - RFX2401C does not need it, it interprets RXEN and TXEN both active as TXEN, so RXEN is always set to Vdd. They used the chip as either a precaution, or as a diversity guarantee that they can use some other PA which does not have this behavior.
Cutting it and passing through the board is a good idea, though soldering is not very easy.
10 May 2014 22:35 #23124 by PhracturedBlue
I know it isn't needed, but I thought if I knew what it was, it could provide another data point on switching speed. I've been looking around, and while most PA/LNA are 16-pin QFN packages, they don't seem to use a common pinout. At least of the ones I've looked at so far, every one has unique I/O locations. It is a good point on the rfx2401c not needing PA_EN and LAN_EN to be mutex though. If we end up using some boolean logic to control the PA when using the nrf24L01, it would simplify things a bit.
11 May 2014 03:38 #23125 by PhracturedBlue
victzh wrote: This 'V4' chip is not always present - RFX2401C does not need it, it interprets RXEN and TXEN both active as TXEN, so RXEN is always set to Vdd. They used the chip as either a precaution, or as a diversity guarantee that they can use some other PA which does not have this behavior.
I think I'll just pull off the resistor (or the V4) on one of my boards. That will leave me with nice (but small) pads to attach to. I also ordered a F072 discovery kit (since they are pretty cheap) so I can play with programming it. I want to make sure I know how all pins need to be tied off to properly initialize.
For the Devo, it makes sense to Hook BOOT0 to the USB VBUS. I believe doing so would allow programming without any jumpers. However, it may make it harder to use in PWM mode where it may be necessary to be able to access a filesystem for model configuration. for that you'd need to 1st power on the module and THEN connect the USB cable (like the Taranis)
I was thinning about the 'PWM' variant, and am now thinking that a bluetooth module may be the best option. It could provide a full interface without the complication of a a screen interface. The downside is, of course, that you'd need to have a smartphone to configure the module (and probably switch protocols)
11 May 2014 03:49 #23126 by victzh
Choices, choices. Bluetooth is probably better than separate screen. Who doesn't have a smartphone these days? Did you program for Android or iPhone? I know that interface should not be that complex as for Deviation - you probably don't need any curves, all that fancy stuff, you have a host TX for this. But anyway, it should be coded ;-)
11 May 2014 04:21 - 13 May 2014 03:07 #23128 by PhracturedBlue
I've done a little work for Android. I have never even attempted iPhone (and don't have one to test with).
Ihave gone through the schematics again and fixed a few issues, as well as verifying all the packages are right (I still need to check all of the RF packages since apparently not all QFN20 packages are the same size).
The BOM is pretty long, but I don't think the parts costs will be too high.
Edit: See 1st post
Last edit: 13 May 2014 03:07 by PhracturedBlue.
11 May 2014 05:56 #23131 by victzh
Wow! 84 small parts! I would not like to put so many of them to the board manually. It will take ages! I put around 40 parts sometime ago, I cursed the design all the way.
I talked with MassiveOverkill sometime ago - he has friends, RF engineers at a factory, he was considering them for the RF design if the need arises. They can probably correct the RF part of the design, do the matching, prototype it. May be it make sense to talk to him about it.
13 May 2014 03:38 #23169 by PhracturedBlue
I've spent some more time cleaning up the schematic, and updated the 1st post. I've also detailed the BOM there.
Pricing of the BOM for a single unit is ~$40. That would go way down with even a small amount of volume, but still not cheap.
I've updated the schematic to support a Bluetooth adapter, and power over USB.
This should allow programming without setting any jumpers.
I'm about ready to start work on the circuit board now. We'll see how it goes.
13 May 2014 05:18 #23171 by SeByDocKy
Replied by SeByDocKy on topic Single-Board Universal Module
PhracturedBlue wrote: I've spent some more time cleaning up the schematic, and updated the 1st post. I've also detailed the BOM there.
Around 40 USD, it's still very interesting ... coz actually with MM I am not sure that BOM is much lower than 40 USD when you add extra pins headers, extra uFL cables, wires ... it should be close to 35 USD. By the way, If I can order one of this single board, I will do ...
13 May 2014 07:16 #23177 by Mmon77
Replied by Mmon77 on topic Single-Board Universal Module
Yes, but to sell the assembled boards, you would also have to add the cost of assembly and FCC certification (at least for sale in the US). So that would change the price accordingly. Unless of course you have the means to assemble one yourself.
It is still an interesting proposition and hopefully it goes somewhere.
Time to create page: 0.348 seconds
