Devo 7e DSMX wont bind with orangeRX R720x v2
14 Feb 2016 22:06 #43128 by Radmor
Hello everyone,
Its quite some time since I have deviation on my devo7e, already faced many problems, but this one I can't find the answer anywhere.
So DSM2 works fine, but DSMX wont bind with the new orangerx. Strangely enough, with the released 4.0.1 it works just fine, but any nightys I tried failed to bind (I found only the newer nightys).
Since the file size is different under the protocol folder, I did try to replace it with the old file, but ofc I get the protocol error as soon as I start. I can't go back to 4.0.1 because I need the newer features.
Do you think that changes in the protocol causing it to fail in this case? Can I use the old DSMX protocol somehow with a nightly? :dry:
Thanks in advance!
Btw, awesome work!
14 Feb 2016 22:59 #43129 by Thomas.Heiss
Replied by Thomas.Heiss on topic Devo 7e DSMX wont bind with orangeRX R720x v2
Just an idea: Have you tried switching the DSMx option (A1, B1 or what it is now) in the popup dialog?
14 Feb 2016 23:34 #43130 by Radmor
No, and I am unable to find it in the latest nightly. Where should it be? DSMX and ENT button?
15 Feb 2016 00:13 #43131 by Radmor
ohh and iam using the devo-s module, maybe its relevant.
15 Feb 2016 07:05 #43139 by Cereal_Killer
Replied by Cereal_Killer on topic Devo 7e DSMX wont bind with orangeRX R720x v2
I use the same rx's and NEVER had a single issue with my 7E or 10...
First question, did you enable telemetry before attempting to bind?
15 Feb 2016 07:20 - 15 Feb 2016 07:20 #43140 by Radmor
No, Ive never touched the telemetry before. Now I have tried to add an alert event to see if it makes a difference somehow, but unfortunately no.
Last edit: 15 Feb 2016 07:20 by Radmor.
15 Feb 2016 07:20 - 15 Feb 2016 07:30 #43141 by vlad_vy
Replied by vlad_vy on topic Devo 7e DSMX wont bind with orangeRX R720x v2
I think if OrangeRX R720x can output 12 channels for CPPM and S.Bus, it's really more that 7 channels receiver and has to be bind with number of channels >7, i.e. 8 channels or more.
By the way, at nightly builds for bind packet added only:
if(Model.protocol == PROTOCOL_DSMX) {
#ifdef MODULAR
packet[12] = 0xb2;
#else
packet[12] = num_channels < 8 && Model.proto_opts[PROTOOPTS_TELEMETRY] == TELEM_OFF ? 0xa2 : 0xb2;
I don't know why it needed and what is it.
Last edit: 15 Feb 2016 07:30 by vlad_vy.
15 Feb 2016 07:25 - 15 Feb 2016 07:39 #43142 by Radmor
vlad_vy wrote: I think if OrangeRX R720x can output 12 channels for CPPM and S.Bus, it's really more that 7 channels receiver and has to be bind with number of channels >7, i.e. 8 channels or more.
Yes! You nailed it, thank you so much! ;) Even tho I am using PWM at the moment, just tried to bind with 10 channels, and whoala!
Thanks again! :woohoo:
Maybe just the channel number on default was higher in 4.0.1 thats why it worked, or that piece of code caused it somehow, i dont know..
Last edit: 15 Feb 2016 07:39 by Radmor.
20 May 2016 11:38 #48854 by IKKI
I have some problems with orange R620x and sbus with dsmx protocol. I use Devo 7e and 5.0 firmware
26 Nov 2016 11:02 #56295 by kaligola
Replied by kaligola on topic Devo 7e DSMX wont bind with orangeRX R720x v2
i binded once one of this, if not remember wrong have to play with number of channels, didnt get more than 8 anyway and endpoints of tx
28 Nov 2016 04:39 #56331 by Cereal_Killer
What flight control board? Did you need to run an extrrnal S.Bus inverter?
Time to create page: 0.823 seconds
