Updating and internationalizing documentation
- Moeder
- Topic Author
vlad_vy wrote: I have a problem with transifex. I can't scroll down "ch_model", it become frozen at half way down, nearby "Available curves".
The problem confirmed and routed to transifex development team.
Why PPM has asterisk (‘*’) before the protocol name?
- Moeder
- Topic Author
By default, channel outputs are displayed as [-100, 100]%. This may be tweaked by modifying the following values in the corresponding channel section in model.ini:
[channel1]
display-scale=100
display-format=%3d%%
Before being displayed, outputs have raw values in the range [-10000, 10000]. The displayed text is generated via sprintf(s, display_format, raw/display_scale)
If display-scale is omitted, the default value of 100 will be used.
If display-format is omitted, the default value of %3d%% will be used. See Wikipedia for more details on the format string.
9.15. Frsky and FrskyX Extended Telemetry
9.16. Protocol: *Skyartec
9.17. Protocol: *Futaba S-FHSS
9.18. Protocol: *V202
9.19. Protocol: *SLT
It looks like Devo8 manual skipped last update. Or there is any error.
- Moeder
- Topic Author
update: it seems like a travis issue, now all builds are failing, please be patient
- Moeder
- Topic Author
NOTE: This protocol requires the addition of an ‘A7105’ hardware module to function. See the following document for more information:
NOTE: This protocol requires the addition of an ‘CC2500’ hardware module to function. See the following document for more information:
NOTE: This protocol requires the addition of an ‘NRF24L01’ hardware module to function. See the following document for more information:
NOTE: This protocol requires the addition of an ‘NRF24L01+’ hardware module to function. Note the “plus” version of the nRF device is required to support the 250kbits/s data rate. See the following document for more information:
.. |a7105-note| replace:: **NOTE: This protocol requires the addition of an ‘A7105’ hardware module to function. See the following document for more information**:
.. |cc2500-note| replace:: **NOTE: This protocol requires the addition of an ‘CC2500’ hardware module to function. See the following document for more information**:
.. |nrf24l01-note| replace:: **NOTE: This protocol requires the addition of an ‘NRF24L01’ hardware module to function. See the following document for more information**:
.. |nrf24l01p-note| replace:: **NOTE: This protocol requires the addition of an ‘NRF24L01+’ hardware module to function. Note the "plus" version of the nRF device is required to support the 250kbits/s data rate. See the following document for more information**:
It looks like these notes can't be translated.
- Moeder
- Topic Author
Now the problem fixed by transifex development team.
- Moeder
- Topic Author
- Moeder
- Topic Author
- Morlacus
Would it be possible to have a warning when the manual is updated in order to update the translation accordingly ?
Regards
- Home
- Development
- Development
- Updating and internationalizing documentation
