Devo8 with vibration (updated for deviation 4.0.1)
  • rbe2012
  • rbe2012's Avatar Topic Author
26 Mar 2013 15:54 - 20 Jan 2014 13:34 #8113 by rbe2012
EDIT: new version based on deviation 3.0.0 4.0.1
This build needs a hardware mod described here . To use it you have to set manually a parameter "has_vibration=1" in the tx.ini file (after having done the mod, for sure). (Edit: not longer necessary)
It does not work for the Devo12 because the used output pin is in use there.
In the tx config there is a new option to switch vibration on or off (sets parameter in tx.ini accordingly).
EDIT:
Build for Deviation 3: see next post.
2nd EDIT:
Build for Deviation 4.0.1 attached here (unzip and flash). You will find a button on the third tx config page where you can switch vibrating off or on and test it (by pressing the button).
Last edit: 20 Jan 2014 13:34 by rbe2012.
  • rbe2012
08 Apr 2013 18:38 #8756 by rbe2012
Corrected an error in initializing (if vibration was set off when the tx was switched on, it could only changed when the tx was switched off and on).
Here is the new version:
File Attachment:
File Name: deviation-...3618.zip
File Size:235 KB
09 Apr 2013 19:26 - 09 Apr 2013 19:27 #8804 by RandMental
Replied by RandMental on topic Devo8 with vibration (updated for deviation 3.0)
Hi RBE
Do you have the V3 with vibration source somewhere in a repo where I can get it and try to make a patch file that I can apply when we build PB's latest V3.x.x source files?
Last edit: 09 Apr 2013 19:27 by RandMental.
  • rbe2012
10 Apr 2013 06:33 #8818 by rbe2012
Yes, you can take it from my repo here: rbe-vibrating . I have sent PB a pull request (#55).
10 Apr 2013 14:32 #8827 by RandMental
rbe2012 wrote: Yes, you can take it from my repo here: rbe-vibrating . I have sent PB a pull request (#55).
04 Jan 2014 22:06 #17951 by crasy666
Will the vibration work on V4. Or can somebody make a build with the vibration mod on V4?
I like the vibration feature on my Devout 8S especially in the winter time with a transmitter glove, where you don't hear the buzzer too good
Thx in advance
Btw, I am using a vibration motor from a cell phone, works great and is designed for 3V so just a transistor BC548 a 100 Ohms resistor and a diode...
05 Jan 2014 07:56 #17971 by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Devo8 with vibration (updated for deviation 3.0)
Hi rbe2012,
would you be so kind and provide a version of the firmware 4.01 for the Devo 8s with the vibration feature?
Thanks in advance,
Dirk
05 Jan 2014 08:55 #17972 by RandMental
Hi RBE,
I would also appreciate the AUX4/AUX5 and Vibration patch files for the latest V4.01
RM
06 Jan 2014 15:50 #18079 by richardclli
Replied by richardclli on topic Devo8 with vibration (updated for deviation 3.0)
I am about to work out the vibration mod as well. Any update on this?
  • rbe2012
06 Jan 2014 16:08 #18080 by rbe2012
Yep, I have seen your requests. I have lost it out of sight due to other priorities for a while, but I still have mounted the vibrating motor in my Devo8.
Time to get it rumbling!
  • rbe2012
06 Jan 2014 18:59 #18089 by rbe2012
Ok, I have updated the first post with the new build. Attached here you can find the patch file (patch -p 1 -i diff_Vibration_4.0.1.txt).
Some gui elements have changed since 3.0 so I had to make it completely new, but there are only a few changes.
  • rbe2012
06 Jan 2014 19:15 #18092 by rbe2012
RandMental wrote: Hi RBE,
RM
The last thing I herad from this AUX4/AUX5-mod was "let's have some testing" ...
Do you thing it works now?
Have I provided a version for 3.0 or even 2.1.1? I don't remember.
I think I have lost what I have done before (since I did not find a patch file...). But I will surely be able to redo this.
06 Jan 2014 19:23 #18093 by -=Hubi-Dirk=-
Hi rbe,
thank you very much for your work. I can no longer imagine the time with my the Devo 8s without vibration.
For those who still have not heard from this great Mod, follow this link:
deviationtx.com/forum/how-to/1501-Devo-8...vibration-motor#8710
  • rbe2012
06 Jan 2014 19:38 #18094 by rbe2012
RandMental,
I sent you a PM with link to test-version.
07 Jan 2014 20:20 #18158 by crasy666
Hi rbe,
Thank you so much, great job!
I have updated today my Devo 8S all including the vibration alarm is working great.
Regards
  • rbe2012
23 Jan 2014 10:05 #18982 by rbe2012
Since adding a vibrating motor to a Devo8 is supported by the main deviation code in the actual nightlies no further patches are necessary.
AUX4/5 is not yet supported.
Time to create page: 0.073 seconds
