Devo8 with vibration (updated for deviation 4.0.1)
This build needs a hardware mod described here .
It does not work for the Devo12 because the used output pin is in use there.
In the tx config there is a new option to switch vibration on or off (sets parameter in tx.ini accordingly).
EDIT:
Build for Deviation 3: see next post.
2nd EDIT:
Build for Deviation 4.0.1 attached here (unzip and flash). You will find a button on the third tx config page where you can switch vibrating off or on and test it (by pressing the button).
Here is the new version:
- RandMental
Do you have the V3 with vibration source somewhere in a repo where I can get it and try to make a patch file that I can apply when we build PB's latest V3.x.x source files?
- RandMental
rbe2012 wrote: Yes, you can take it from my repo here: rbe-vibrating . I have sent PB a pull request (#55).
- crasy666
Will the vibration work on V4. Or can somebody make a build with the vibration mod on V4?
I like the vibration feature on my Devout 8S especially in the winter time with a transmitter glove, where you don't hear the buzzer too good
Thx in advance
Btw, I am using a vibration motor from a cell phone, works great and is designed for 3V so just a transistor BC548 a 100 Ohms resistor and a diode...
- -=Hubi-Dirk=-
would you be so kind and provide a version of the firmware 4.01 for the Devo 8s with the vibration feature?
Thanks in advance,
Dirk
- RandMental
I would also appreciate the AUX4/AUX5 and Vibration patch files for the latest V4.01
RM
- richardclli
Time to get it rumbling!
Some gui elements have changed since 3.0 so I had to make it completely new, but there are only a few changes.
The last thing I herad from this AUX4/AUX5-mod was "let's have some testing" ...RandMental wrote: Hi RBE,
RM
Do you thing it works now?
Have I provided a version for 3.0 or even 2.1.1? I don't remember.
I think I have lost what I have done before (since I did not find a patch file...). But I will surely be able to redo this.
- -=Hubi-Dirk=-
thank you very much for your work. I can no longer imagine the time with my the Devo 8s without vibration.
For those who still have not heard from this great Mod, follow this link:
deviationtx.com/forum/how-to/1501-Devo-8...vibration-motor#8710
I sent you a PM with link to test-version.
- crasy666
Thank you so much, great job!
I have updated today my Devo 8S all including the vibration alarm is working great.
Regards
AUX4/5 is not yet supported.
Builds
- Devo8 with vibration (updated for deviation 4.0.1)
