Devo10 ESky protocol draft
18 Jun 2014 20:13 #24150 by dremaer
Replied by dremaer on topic Devo10 ESky protocol draft
well, today, i've just installed your .dfu then i picked up the folder "media" from NB and paste over the 4.0.1 with your protocol folder. yesterday i've tryed the Nb complete, i made changes to hardware.ini, result: nothing... then, i've tryed your .Dfu file with folders from Nb, nothing... NB complete with your protocol folder... nothing. and at each time i've changed the hardware.ini file. i've opened the TX case and the solder points are fine...
here is a copy/paste from my .ini file:
[modules]
; enable-cyrf6936 = B12
has_pa-cyrf6936 = 0
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = None
; has_pa-cc2500 = 0
; enable-nrf24l01 = None
; has_pa-nrf24l01 = 0
; enable-multimod = None
i'm waitting for my nrf module. hope it arrives until weekend.
18 Jun 2014 20:21 #24151 by victzh
Replied by victzh on topic Devo10 ESky protocol draft
Ahem, ; before line means comment, that is the line is not active. For your V911 it should have no semicolon before line
enable-a7105 = A13
and if you have A7105 module with PA it should have
has_pa-a7105 = 1
ESky protocol uses nRF24L01 module, so no point to try the protocol without it. When you get the module, you should enable it by replacing line
with line
enable-nrf24l01 = A14
and handle enable-nrf24l01 in the same manner as for A7105.
18 Jun 2014 20:23 #24152 by victzh
As I did not receive any responses for ESky and it works for me, and using my build makes difficulties compared to nightly builds, I will submit it to main trunk.
18 Jun 2014 20:35 #24153 by dremaer
newbie's errors...
tanks for your correction and help. it works fine now. once i have the nrf i'll tell you how it goes...
25 Jun 2014 03:51 #24232 by victzh
OK, I submitted pull request with ESky original protocol. After PhracturedBlue accepts it, it will be available in nightly builds.
If you have ESky original receiver, please check that it works for you and report it.
25 Jun 2014 20:29 #24245 by dremaer
hi everyone
i've received my NRF module today and i've passed 2 hours to solder it but finally i did it, works fine. after that i've tryed to bind my devo 7E with a Esky ek2-0424 receiver and what a joy.... it works... and my Belt Cp works fine. thank you so much guys, but first place thanks to victzh from this work... i'm so glad to use my devo with another extra brand.
25 Jun 2014 21:25 #24247 by victzh
@dremaer, thanks for checking!
30 Jun 2014 18:53 #24315 by SeByDocKy
Replied by SeByDocKy on topic Devo10 ESky protocol draft
I tested the new build on my Devo7E for the Esky150. It's not working but I don't have the double error msg as in the last build. Working fine for the Devo10
31 Aug 2014 04:04 #25437 by Daryoon
Replied by Daryoon on topic Devo10 ESky protocol draft
Hi victzh
Did you get a chance to see SeByDocKy's post above?
I am trying to bind the Devo7e using the Esky 150 protocol with the Esky F150 heli. No success thus far.
I tried turning on the TX and then the heli.
Turning on Heli and then TX
Tried the reinit button.
Tried with and without FixID.
According to SeByDocKy, it works with his Devo 10.
I wonder why Devo 7e isn't work. Any guesses?
Thanks.
17 Nov 2014 20:32 #26446 by SeByDocKy
Ok I received the F300BL from ESKY and in first attempt, I was not able to bind the F300BL with the 150 model...with the F300BL TX. But I discovered, there is a bind procedure for this TX (by pressing the right trim button of the left stick). So now I am sure, when I collected SPI data, I missed this binding sequence. Victzh, if you can I can capture this part. I am sure it can explain why it's not working the DEVO 7E.
13 Mar 2015 10:03 #29633 by Henne22
Replied by Henne22 on topic Devo10 ESky protocol draft
first of all, nice work. Deviation is great.
I use the latest nighly build v4.0.1- 1b6535b, but im unable to bind my belt cp v2. i tried with DSM2, DSMX, ESKY150 and ESKY Protocol... No Binding :(
Whats my fault? The Belt has the Esky ek2-0424 receiver...
Can anyone help me? I use the attached Model Config File
File Attachment:
File Name: BeltCP_Spe....ini.txt
File Size:2 KB
13 Mar 2015 11:42 #29636 by linux-user
13 Mar 2015 14:07 - 13 Mar 2015 14:32 #29643 by Henne22
I'm embarrassed.Stupid Beginner Error :pinch: I have no module installed... arghhh... ok thats my fault... Many Thanks! I also have a blade 130x, did i need another modul for this heli? for the Belt i order now the nRF24L01(is this right?). which module i need for the Blade?
Last edit: 13 Mar 2015 14:32 by Henne22.
13 Mar 2015 16:49 #29651 by victzh
Blade 130x uses DSM2/DSMX which are natively supported by Devo's own radio chip. For ESky Belt CP v2 you need to install nRF24L01+ radio module and use ESky protocol, not ESky 150.
13 Mar 2015 19:21 #29658 by Henne22
Many thanks!!! I think i buy a AR610 reciever for the Belt, then i doesn't need the modul!
very nice forum, go on!!!
Time to create page: 0.053 seconds
