7e +telem +layout ed +perm timer, weekly updates
- HappyHarry
22 Jan 2014 22:48 - 09 Jan 2015 17:47 #18950
by HappyHarry
7e +telem +layout ed +perm timer, weekly updates was created by HappyHarry
Thanks to PhracturedBlue's great work on combining the switch additions for the 7e into the main Deviation build i no longer need to create build for all the different possible switch combinations. i will however still provide a build with the layout editor, the permanent timer and telemetry all enabled, and this will be that thread containing those builds, this thread will follow the updates in PB's repo but i will only do a new build once a week or so, this will allow people to test the newest code and still have all the options enabled.
as i said all the common switch combinations are now covered in the main code (1 x 3way, 2 x 2way and 2 x 3 way) and along with that there is also a new way of enabling your hardware mods, instead of being in the tx.ini file there is a new file called hardware.ini, and as well as the switch mods the added modules are also enabled in there now.
//********************************************************************************* build updated 9th of August to [url=hhttps://bitbucket.org/deviationtx/deviation/commits/9dae026534bc3cef82aadf607790f0aa452571e4]9dae026[/url], thereare three are two is one build attached, see this post >>
www.deviationtx.com/forum/builds/2661-7e...ates?start=100#22336
see this post >>
www.deviationtx.com/forum/builds/2661-7e...ates?start=140#27581
for details and be sure to download the correct file
Last edit: 09 Jan 2015 17:47 by HappyHarry.
- dianjing
23 Jan 2014 01:09 #18962
by dianjing
Replied by dianjing on topic 7e +telem +layout ed +perm timer, weekly updates
thank you for your firware.
- dianjing
23 Jan 2014 01:15 #18963
by dianjing
i have saw that switch_types: 3x2, 3x1, 2x2 in the hardware.ini.
can it do in 3*2 mode??
i still wait for two 3sw.
- Shanman3us
23 Jan 2014 01:37 #18964
by Shanman3us
If it's not working 100% right this moment then it will be in the next day or two. It is still a work in progress but all the tweaks will be made and we all get to benefit from it soon.
Thanks to PhracturedBlue and all the others helping him for the continued work on Deviation!
Shanman3us
Replied by Shanman3us on topic 7e +telem +layout ed +perm timer, weekly updates
dianjing wrote: i have saw that switch_types: 3x2, 3x1, 2x2 in the hardware.ini.
Shanman3us
- HappyHarry
23 Jan 2014 11:06 #18985
by HappyHarry
Replied by HappyHarry on topic 7e +telem +layout ed +perm timer, weekly updates
i have updated the build early as a few bugs in the switch settings have been found and quickly fixed, the new build is in the first post.
yes it now can do 3x1, 2x2 and 3x2 switch combinations in the main code, no need for patches anymore
- blackmoon
23 Jan 2014 12:36 #18990
by blackmoon
Replied by blackmoon on topic 7e +telem +layout ed +perm timer, weekly updates
There is no build in the op.
Latest version is available in the nightly builds but I don't think it has the layout editor nor permanent timer.
- HappyHarry
23 Jan 2014 12:49 #18991
by HappyHarry
i've just re-attached the build, don't know what happened?
and yes that's right, this is just the same code as the nightly's but with the perm timer and the layout editor enabled
- blackmoon
23 Jan 2014 12:59 #18992
by blackmoon
Thank you Phil, as I can't build with all the whistles and bells, with the VM I have.
Should update it but so much to do...
- HappyHarry
23 Jan 2014 14:32 #18994
by HappyHarry
no problem
and yeah time is a valuable resource that needs managed with care
- hongm1212
24 Jan 2014 12:19 #19021
by hongm1212
Replied by hongm1212 on topic 7e +telem +layout ed +perm timer, weekly updates
Waiting for the test.thank you
- HappyHarry
24 Jan 2014 20:29 #19043
by HappyHarry
which test? i have got this working on my devo7e and flying heli's fine, i only have one 3way switch set up just now but i will hook up the second over the weekend and test those too. but you are safe to use this build yourself
- southtirol32
24 Jan 2014 21:13 - 24 Jan 2014 21:20 #19045
by southtirol32
Replied by southtirol32 on topic 7e +telem +layout ed +perm timer, weekly updates
hi i don´t understand an example:
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches= 2x2
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable_switch = A13
it´s correct???or
; enable_switch = 2x2 or 1 //
;enable-haptic=1
[modules]
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
it´s correct???or
Last edit: 24 Jan 2014 21:20 by southtirol32.
- HappyHarry
24 Jan 2014 21:18 #19046
by HappyHarry
if you have 2 extra 2 way switches added to your 7e (not the original 2 switches, but 2 extra switches) then it would be like this
;enable-haptic=1
extra-switches=2x2
;- southtirol32
24 Jan 2014 21:21 #19047
by southtirol32
aha okay, what is with enable switch?? a13?? i hav the nrf module
- HappyHarry
24 Jan 2014 21:45 - 24 Jan 2014 21:46 #19048
by HappyHarry
the enable switch is for the new multi protocol board that PB is creating, you won't need to bother with that. for enabling your nrf module you just enable it in the hardware.ini file the same way as you did when it was in the tx.ini file
enable-nrf24l01=A14 (or A13, depends on if it's connected to TMS or TCK)
has_pa-nrf24l01=1 (or 0, depends if your module has a power amp)
Last edit: 24 Jan 2014 21:46 by HappyHarry.
- hongm1212
25 Jan 2014 01:05 #19058
by hongm1212
I am not a developer, I'm just D7E users, according to the method of GALEE I change the three sections of the switch, and use the firmware, but because he has no to mixed control switch firmware, so I hope you can be developed on the basis of the Deviation can be mixed in possession of the three sections of the switch firmware.
Thanks again.
English is very poor, translation software, forgive me.
Thanks again.
- southtirol32
25 Jan 2014 19:25 #19098
by southtirol32
hi
; enable_switch = A13,
in the last line, what you mean? it´s this okay i don´t must change the last line?? the nrf module have A13
- HappyHarry
25 Jan 2014 20:28 - 25 Jan 2014 20:31 #19102
by HappyHarry
as long as you don't uncomment the line it wont be read, here is how my hardware.ini looks, i have a 3x1 switch as well as an nrf module and an a7105 module
as you can see only the lines without the semicolon ';' at the start are read by the Tx
;enable-haptic=1
extra-switches=3x1
[modules]
has_pa-cyrf6936=1
enable-a7105=A14
has_pa-a7105 = 1
; has_pa-cc2500 = 1
enable-nrf24l01=A13
has_pa-nrf24l01=1
; enable_switch = A13as you can see only the lines without the semicolon ';' at the start are read by the Tx
Last edit: 25 Jan 2014 20:31 by HappyHarry.
- blackmoon
25 Jan 2014 20:42 #19104
by blackmoon
enable_switch A13 is for the multi-protocol module PB is designing leave it as is.
- HappyHarry
25 Jan 2014 20:43 - 25 Jan 2014 20:44 #19105
by HappyHarry
i also am not a developer, i am just a user like you
no need to apologise for your english.
as you have the two 3 way switches added like galee then you will just have to set your switch option to 3x2 so it would be
then if you go into your switch settings you will find 2 new switches available to choose, SW A and SW B and 3 positions for each switch. then you can use them as you see fit in your setup
hongm1212 wrote: I am not a developer, I'm just D7E users, according to the method of GALEE I change the three sections of the switch, and use the firmware, but because he has no to mixed control switch firmware, so I hope you can be developed on the basis of the Deviation can be mixed in possession of the three sections of the switch firmware.
Thanks again.
extra-switches=3x2then if you go into your switch settings you will find 2 new switches available to choose, SW A and SW B and 3 positions for each switch. then you can use them as you see fit in your setup
Last edit: 25 Jan 2014 20:44 by HappyHarry.
Time to create page: 0.175 seconds
Builds
- 7e +telem +layout ed +perm timer, weekly updates
