Turinigy 9XR 11.1v lipo battery in a devo-10
19 Apr 2014 14:27 #22571 by Hondawasaki
If this is the wrong place to put this please move it .
I recently purchaced a Turinigy 9XR 11.1v 1.5c 2200mah tx battery and am using it in my Devo -10 ... It is a very tight fit into the battery bay but works great. I have not attempted to use the onboard charger yet ( I do not have a proper powersupply ) 12v 50ma .... so im charging it with a lipo charger outside of the tx ...
the tight fit makes it where i need to pry the battery out gently using a butter knife .
20 Apr 2014 05:22 #22592 by sbstnp
Do not use the onboard charger, it is not meant to be used with lipos, only nimh.
Other than that maybe wire a diode in series to drop the voltage 1V in order to not put stress on the power supply side of the TX. 1N4001 works great;
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
20 Apr 2014 16:19 - 20 Apr 2014 16:20 #22601 by Hondawasaki
Replied by Hondawasaki on topic Turinigy 9XR 11.1v lipo battery in a devo-10
K i will not use the stock charger
... and i plan to do a bit of dremel work to make the battery fit better. If I remove the peices that stick out to lock the original battery pack .. the lipo will slide right in ...
it barley goes over 12v charged and fresh akaline batts are a full 12v so i figure it will be fine voltage wise ... I do need to change my LV alarm to protect the lipo. ( the lipo is supposed to have built in over/under current protection ... but it is turnigy so... )
Last edit: 20 Apr 2014 16:20 by Hondawasaki.
Time to create page: 0.028 seconds
