V977 for adventurous!
- 3D Ambitions
29 May 2015 06:20 #33167
by 3D Ambitions
Replied by 3D Ambitions on topic V977 for adventurous!
how do i install this into my devo 8s?
- aMax
29 May 2015 10:54 #33172
by aMax
Replied by aMax on topic V977 for adventurous!
Easy to find at the main menu.....
www.deviationtx.com/user-manual
" moduleinstallation.pdf"
docs.google.com/spreadsheet/ccc?key=0Any...kE&usp=sharing#gid=0
"modules and supported modells"
29 May 2015 15:58 #33183
Replied by mwm on topic V977 for adventurous!
Start with
bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation
, it's an overview of the process. It includes links to the list of supported modules, which lists all the connections for the various different modules. It also has links for each Tx, which tells you how to connect the module.
Last time I looked at moduleinstallation.pdf, it wasn't as recent as the wiki entry above.
- Artus
13 Feb 2016 15:02 #43092
by Artus
Align TREX 100 (3) Hubsan Q4
Walkera QRX 350 PREMIUM
Replied by Artus on topic V977 for adventurous!
Is this still actual ?
Next week I have a V977 and i want to try .. If it's possible
- wukong
14 Feb 2016 10:26 #43106
by wukong
Replied by wukong on topic V977 for adventurous!
The KN protocol is already implemented in the latest nightly and have been working fine for quite a while now.
I have been using it without any issue.
Let me know if you need my model file.
- Artus
20 Feb 2016 15:51 #43363
by Artus
Hello wukong,
I would be glad if you want to share your model.ini I am a newbee in deviation and I need any help a can get. Thanks a lot in advance
- Birdman
22 Feb 2016 08:46 #43451
by Birdman
Replied by Birdman on topic V977 for adventurous!
- wukong
22 Feb 2016 14:10 #43458
by wukong
Sorry for the late reply.
Here you go.
Channel Mapping
1. Throttle/Pitch
(Mixing is onboard Helo. i.e. Actual Throttle/Pitch curves are stored in the Helo, but you can make use of ch 9 to adjust the Throttle/Pitch curve as necessary).
2. Aileron
3. Elevator
4. Rudder
5. Dual Rates: -100 normal, 100 double
(Not sure which channel this affects, but I suspect it affects channel 1-4)
6. Throttle Hold: -100 Off, 100 On
7. Idle Up: -100 Off, 100 On
8. 3D/6G Mode: -100 6G mode, 100 3D mode
(In 6G flies like V911, centering Ail/Elevator will cause heli to hover)
9. Pitch Travel Adjust
10. Aileron Trimmer
11. Elevator Trimmer
Artus wrote: Hello wukong,
Here you go.
Channel Mapping
1. Throttle/Pitch
2. Aileron
3. Elevator
4. Rudder
10. Aileron Trimmer
Time to create page: 0.041 seconds
- Home
- Development
- Builds
- V977 for adventurous!
