XK K110 (S-FHSS) build for Devo 7E and Devo 10
- sv650s
24 Oct 2018 04:45 #71479
by sv650s
Replied by sv650s on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
i have a DEVO 12S under deviation with 3 in 1 module since many years and all works very well.
But today I have received a Blast XK 110, and I don't arrive to bind them together...
I have tried to change fréquemment fine from 0 to 50 (1 by 1), but impossible to bind...
Have you got a .ini file for this model on demo 12S ?
Have you got an idea why I can't bind on XK110 and how to resolve this ?
Thanks for your help.
Best regards.
Best regards.
- kudzis
22 Jun 2020 18:43 #76510
by kudzis
Replied by kudzis on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Spend a few hours experimenting and wondering why my K110 won't bind and updating firmware multiple times, after reading this I learned I need to update hardware.ini after installing CC2500 chip. If you see '*S-FHSS' instead of 'S-FHSS' - this means you need to enable protocol in hardware.ini (and install chip, if you haven't done so).
This thread is a goldmine. Thanks to everyone who contributed!
- Donthemon
20 Feb 2021 16:54 #77266
by Donthemon
Replied by Donthemon on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Hi - excuse my complete ignorance, but I've a couple of questions.
I have a Devo7e and am hoping to fly a stock XK K110 with it, so...
1. Is the .ini for a stock XK K110 (as I don't understand the reference to the Orange receiver in the setup description)?
2. I can see the .ini file attached to the posting, but what are the zipfiles for?
Thanks from a newbie.
- freewee4
01 Jul 2023 17:01 - 10 Jul 2023 17:15 #78287
by freewee4
Replied by freewee4 on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Hi
I stay on that old thread because there is not an other interesting about xk k110 and 110s in this forum (or I don' t find)!
I have a DEVO 10, with 3in1 module,a K110s, and I modify the model.ini file taken above (thank you D_an_W ).I changed an inverted some things in order to fit the disposition of Devo 10 case.I had no need to change the Freq-Fine, binding without problem.Only one thing doesn't work: the 6G, when activated, the heli becomes crazy, and impossible to pilot, and the calibration is impossible because of that. I don't know if this comes from the TX or from the RX board??? But in 3D it is very stable! This is the more important! (but I wonder how a beginner could fly with the 6G mode!!!)
With the model.ini file, a modified toogle3.bmp in order to fit my configuration and an icon! I hope it could help! But if you have better model.ini, I' m interested in! Deviation is not very active, and I had difficulties to find one!!
Last edit: 10 Jul 2023 17:15 by freewee4.
- rc manic
19 Jul 2023 04:10 #78290
by rc manic
Replied by rc manic on topic XK K110 (S-FHSS) build for Devo 7E and Devo 10
Read the xk110 instructions. You need to recalibrate the gyros in 6G mode.
- freewee4
20 Jul 2023 19:23 #78291
by freewee4
Thank you!
I did that, but it' s nearly impossible to take off and land, because the cyclic incline,when going from 3D to 6G. And it seems to take seconds for each command: impossible to fly this way and calibrate!
But as I said, I' m not a beginner, and in 3D the heli is stable and reactive!
- rc manic
21 Jul 2023 04:56 - 21 Jul 2023 05:02 #78292
by rc manic
Are you starting in 3G and then trying to switch to 6G while in flight? If the gyros are not calibrated, that will cause erratic flight.
If you switch to 6G when not in flight, initiate calibration and then hover, are you having same issue?
Last edit: 21 Jul 2023 05:02 by rc manic.
- freewee4
21 Jul 2023 07:07 #78293
by freewee4
Hi
No! On ground, when switching from 3D to 6G (and reverse), 2 servos change their position and incline cyclic...In 6G, if I correct the inclination of the cyclic with the rods, I can' t fly in 3D with this setting!!! Switching to 6G before or after or turning on the TX gives the same issue...
Time to create page: 0.080 seconds
- Home
- Development
- Builds
- XK K110 (S-FHSS) build for Devo 7E and Devo 10
