Devo 7E not working after upgrading firmware
- is fpv
- Topic Author
23 Oct 2020 02:58 #76912
by is fpv
Devo 7E not working after upgrading firmware was created by is fpv
Hi All, I'm really need help. I just wondering if there is any solution to fix my devo 7e. I just bought it last month, upgrade to the latest nightly build last week, after the program update successful to my devo 7e. it suddenly turn off.. now it I cant even switch it on.. try to enter programming and USB mode also nothing happen like there is no power at all.. I have multimeter but the board seem nothing damage not even have burn smell. does anyone have been this situation before? is there any solution to fixed this?
I only mod the bypass diode and added 3 position switch to my devo 7e. others still in normal and still using AA battery for power supply.
23 Oct 2020 05:37 #76914
Replied by vlad_vy on topic Devo 7E not working after upgrading firmware
What software do you use for update?
- is fpv
- Topic Author
23 Oct 2020 06:06 #76915
by is fpv
Replied by is fpv on topic Devo 7E not working after upgrading firmware
im using deviations dfuse usb upgrade tool.
23 Oct 2020 06:18 #76916
Version?
- is fpv
- Topic Author
23 Oct 2020 06:52 #76917
by is fpv
the latest one 2.31... my devo 7e firmware is deviation-devo7e-v5.0.0-c84450e
23 Oct 2020 07:15 #76918
Walkera Dfuse V2.31 can't damage bootloader, so it looks like you have hardware problem.
- is fpv
- Topic Author
23 Oct 2020 07:24 #76919
by is fpv
how to troubleshoot something like that? my TX is really new
23 Oct 2020 08:37 - 23 Oct 2020 08:38 #76920
Last edit: 23 Oct 2020 08:38 by vlad_vy.
- is fpv
- Topic Author
23 Oct 2020 09:27 #76921
by is fpv
actually I'm not really good at this.. hopefully there is more explanation and conclusion for this.
- is fpv
- Topic Author
24 Oct 2020 15:16 #76928
by is fpv
hi vlad_vy, i already try to connect two pin on the bypass it seem no power at all.. so i confirm that it was not about firmware but it something on my circuit any solution to fix this.. i don't have to much experience on this but I'm willing to fix it if somebody explained to me.
- is fpv
- Topic Author
25 Oct 2020 11:17 #76932
by is fpv
hi this is my board.. seem everything look okay.. i have multimeter but i only have basic knowledge.. wish to get more help.
- chinderdelis
14 Feb 2021 06:59 #77248
by chinderdelis
Replied by chinderdelis on topic Devo 7E not working after upgrading firmware
hi, i don't know if you solved it, it's been a while since the last post.
cmq I try to tell you lamia even if I'm not an expert.
I don't think the firmware upgrade could have damaged everything and not even make it turn on. I think you considered charging the battery, right? at this point have you tried to enter usb mode?
Time to create page: 0.066 seconds
- Home
- Development
- Builds
- Devo 7E not working after upgrading firmware
