Script to build devo12-lib.dfu (for themers)
- Topic Author
It won't break anything, but it may not actually work.
you need to point it at the media directory from the devo12 filesystem.
This is a compiled autoit script. the src can be found in the 'scripts' dir if you are interested)
Mklib 0.1 (for 32 and 64 bit):
www.deviationtx.com/downloads-new/catego...make-devo-12-library
4.0.1 Devo12 Filesystem
Instructions for use:
1) download MkLib-0.1-32bit.zip from the 1st post in this thread
2) download devo12-media.zip from the 1st post in this thread
3) unzip MkLib-0.1-32bit.zip
4) unzip devo12-media.zip
5) copy your new bitmap to media/devo12.bmp (from step 4)
6) open the MkDevo12Lib directory and run MkDevo12Lib.exe
7) select the 'media' directory (from step 4)
8- this will create a new devo12-media.dfu file and tell you what directory it is in
9) 'upgrade' this dfu via the 'Library' (NOT the 'Firmware' tab!)
- eraf
Can it be the reason for missing output file?
- Topic Author
If someone has python installed on a windows32 machine as well as the development environment, here are instructions to make the exe:
Install py2exe from here: www.py2exe.org/
in the deviation dir:
create utils/setup.py with contents
from distutils.core import setup
import py2exe
setup(console=['dfu.py'])
cd mkfat
create setup.py with contents
import py2exe
setup(console=['mkfat.py'])
now copy all files from utils/dist and utils/mkdat/dist into he Mklib-0.1/scripts/ directory and try the script again.
- Topic Author
- eraf
I'd like to say thank u for the great firmware and forum.
- pulpfiction15
I have tried to create the dfu, without luck.
I tried 32 bit vista , 64 bit Win 8.1 and on my linux system with Wine.
Nothing worked, script is running. But also got the file path with double slash
- pulpfiction15
I removed the space and all is working perfectly .
Thanks to all of you for having Deviation.
- cropduster
I just tried it and it worked. Now, for the Devo 12s, is the media directory the only contents of the devo12-lib.dfu file?
How is this library related to the firmware version? Where can I get the /media folder related to the proper firmware release?
Thanks,
Michael
- cropduster
Great!
- unclecrash
- Topic Author
- unclecrash
- Topic Author
Here are the steps:
- bruiser
- -=Hubi-Dirk=-
@ PB: Can you please fix this problem.
- Topic Author
- Home
- Custom Skins
- Script to build devo12-lib.dfu (for themers)
