Monitor bargraph text colour?
- RoGuE_StreaK
- Topic Author
23 Dec 2014 01:06 #27155
by RoGuE_StreaK
Monitor bargraph text colour? was created by RoGuE_StreaK
I haven't used my 6s in a while, about to get back into it and started working on a new theme to attempt to improve visibility in sunlight; dark background, high contrast bold text. I've figured out most of it, but can't find anywhere a config for the small black text attached to the Channel- and Input- Monitor screens?
There are a couple of other bits of text that don't seem affected by config changes, but the bargraph text is the main killer for me at the moment (have checked latest nightly in case)
- Indigo
23 Dec 2014 20:20 #27169
by Indigo
Replied by Indigo on topic Monitor bargraph text colour?
The font used there is called "micro".
To change it edit the [Font-micro] section in media/config.ini
Or to change another font to be the same edit which ever font section you want to change and set it to font=04b03
The default [Font-micro] section is this:
[Font-micro]
font=04b03
box_type=center
font_color=ffffff
- RoGuE_StreaK
- Topic Author
23 Dec 2014 22:44 #27174
by RoGuE_StreaK
Replied by RoGuE_StreaK on topic Monitor bargraph text colour?
Hi Indigo
My media/config.ini doesn't have a font-micro (neither 4.0.1 nor 4.0.1-92e1705). I tried adding it, both as Font-micro and font-micro, but no result.
There's a font-tiny, which doesn't specify a colour; I added a colour, but again no result.
- Indigo
23 Dec 2014 23:20 - 23 Dec 2014 23:33 #27177
by Indigo
Sorry, font-micro applies to Devo 10/7e. The 6s has no font-micro because that font would be too small on a screen which has double the resolution. The 6s like the 8 uses the font-tiny setting. If works for me on 4.0.1-92e1705 emulator build, eg. I set the color to red:
[font-tiny]
;Channel display
font=5x7
font_color=FF0000
; font=arial10narrow
box_type=center
The smallest bold font is 14bold so the best you can do is use:
font=14bold
[font-tiny]
;Channel display
font=5x7
font_color=FF0000
box_type=center
font=14bold
Last edit: 23 Dec 2014 23:33 by Indigo.
- RoGuE_StreaK
- Topic Author
23 Dec 2014 23:33 #27179
by RoGuE_StreaK
That's done it, thanks Indigo; I think I may have used a dash instead of an underscore in "font_color" when I tried font-tiny (too used to CSS)
- RoGuE_StreaK
- Topic Author
24 Dec 2014 01:31 #27187
by RoGuE_StreaK
- Indigo
31 Dec 2014 17:30 - 31 Dec 2014 17:58 #27387
by Indigo
I just stumbled across this and remembered your quest for a high contrast theme:
www.rcgroups.com/forums/showpost.php?p=22215763&postcount=803
www.rcgroups.com/forums/showpost.php?p=22283017&postcount=849
Last edit: 31 Dec 2014 17:58 by Indigo.
Time to create page: 0.087 seconds
- Home
- Custom Skins
- Monitor bargraph text colour?
