color writting
02 Jun 2017 09:57 #62757 by jejeg
color writting was created by jejeg
Hello everyone
I would like to change the color of the writing (see photo). In media -> config, what corresponds to this line of writing.
Thanks in advance.
Bonjour à tous
Je voudrais modifier la couleur de l'ecriture (voir photo) . Dans média ->config ,a quoi correspond cette ligne d'écriture .
D'avance merci
02 Jun 2017 10:55 #62758 by FDR
Replied by FDR on topic color writting
There is a config.ini file in the media folder, which has this section by default:
[font-label]
  font=15normal
  font_color=000000
  align=left
Change the font_color value for example to FFFFFF for white, or FF0000 for red, etc in RRGGBB hexadecimal format...
02 Jun 2017 17:42 #62772 by jejeg
Replied by jejeg on topic color writting
Thanks FDR
The name of this line is [font-label]
02 Jun 2017 17:57 #62774 by jejeg
There is no [font label] in the config.ini folder :(
; avaliable fonts:
; 5x7, 10normal, 10narrow, 15normal, 14bold, 18bold, 23bold, 48normal
;colors are specified as RGB888: ff0000 is red, 00ff00 is green, 0000ff is blue
[general]
;bat_icon=1
header_time=1
[font-default]
font=15normal
font_color=FFFFFF
[font-bold]
font=14bold
font_color=FFFFFF
[font-section]
;font=15normal
font=14bold
font_color=FFFFFF
box_type=underline
[font-narrow]
font=14bold
font_color=FFFFFF
box_type=center
[font-small]
font=10normal
font_color=FFFFFF
box_type=center
[font-tiny]
;Channel display
font=5x7
font_color=FFFFFF
box_type=center
[select]
color=404040
width=2
[keyboard]
font=14bold
bg_color=000000
bg_key1=E2E4E6
fg_key1=000000
bg_key2=8F95A1
fg_key2=FFFFFF
;bg_key3=3270DF
bg_key3=EE0000
fg_key3=000000
[listbox]
bg_color=000000
fg_color=FFFFFF
bg_select=FFFFFF
fg_select=000000
[scrollbar]
bg_color=555555
fg_color=CCCCCC
[bargraph]
fg_color=EE0000
outline_color=FFFFFF
transparent=1
[xygraph]
bg_color=303030
fg_color=FFFF00
grid_color=FFFFFF
axis_color=FFFFFF
point_color=FF0000
[trim]
fg_color_pos = 0000EE
fg_color_neg = 0000EE
fg_color = EE0000
outline_color= FFFFFF
transparent = 1
[font-title]
font=14bold
font_color=FFFFFF
[font-smallbox]
;Timer
font=18bold
font_color=FFFFFF
bg_color=000000
box_type=fill
[font-smallboxneg]
;Timer
font=18bold
font_color=000000
bg_color=FFFFFF
box_type=fill
outline_color=000000
[font-modelname]
font=14bold
font_color=FFFFFF
box_type=center
[font-bigbox]
;Throttle
font=23bold
font_color=FFFFFF
bg_color=303030
box_type=fill
outline_color=808080
[font-bigboxneg]
;Throttle
font=23bold
font_color=FFFFFF
bg_color=EE0000
box_type=fill
[font-battery]
;Battery
font_color=000000
font=14bold
[font-batt_alarm]
;Battery
font_color=EE0000
font=14bold
[font-dialogtitle]
font_color=000000
bg_color=FFFFFF
font=14bold
[font-dialogbody]
font_color=FFFFFF
bg_color=303030
font=15normal
[font-normalbox]
font=15normal
font_color=000000
bg_color=FFFFFF
box_type=fill
[font-normalboxneg]
font=15normal
font_color=FFFFFF
bg_color=000000
box_type=fill
[font-textsel]
font=15normal
font_color=000000
[font-button]
font=15normal
font_color=FFFFFF
02 Jun 2017 18:09 #62777 by FDR
What version do you use? It is only in the latest builds, the v5.0.0 doesn't have it.
However if you use a nightly build, then it means that you haven't updated your filesystem...
02 Jun 2017 18:18 #62779 by jejeg
I use : devo12-v5.0.0-58e29b0 (voice)
02 Jun 2017 18:32 #62781 by FDR
That's a preatty old one from 28/03.
It doesn't even contain the extended custom voices.
Try to use the nightly build, it does contain the most recent voice alerts...
02 Jun 2017 18:42 #62782 by jejeg
I am French and I use voiceFR and not voiceEN-wide
I have to do the translation for Moeder; That's why the last nightly build does not interest me.
In this version one must be able to modify it also no?
02 Jun 2017 18:55 - 02 Jun 2017 18:57 #62783 by Moeder
Replied by Moeder on topic color writting
font-label has been added to nightlies on Feb 24 2017, so you could just go ahead and add it to your config ini.
BUT: you are running the last test build from my downloads folder. Since then there have been some small bugfixes and most importantly the number of possible custom alerts has been increased, which will be necessary if you want to use large voice packs. All nightly builds starting April 1st 2017 have included voice feature, so I really suggest PLEASE go ahead and install the current nightly!
edit: please note that none of the voice sets is included in the firmware downloads - they have always been kept seperately. But I repeat myself - I suggest not using my test build anymore as it is depreciated.
Last edit: 02 Jun 2017 18:57 by Moeder.
02 Jun 2017 19:13 #62785 by jejeg
Ok I will modify my "firmware" but I am not forced to load also the "gallery". I do not want to change my screen.
Or it is better that I wait for the future nightlybuids with the news announced vocal French ...;)
Ps: Why do not I get new notifications on topics ???
02 Jun 2017 19:40 #62787 by FDR
jejeg wrote: Ps: Why do not I get new notifications on topics ???
Probably because you haven't subscribed, or already unsubscribed.
Which button do you see up there under the title of the topic "Subscribe" or "Unsubscribe"?
02 Jun 2017 19:44 #62788 by Moeder
No just update your firmware and I suggest also config.ini as there have been some changes to fonts introduced. Other than that I can't think of any changes outside the firmware itself.
off topic:
I don't think voice sets for all languages will be included in the builds....although theoretically we could make the language of the voice sets selectable. You'd still have to put the right mp3s on the dfplayer sd card anyways so, it doesn't make too much sense to me. Most users will probably just install voice sets once for their desired language and stick with it then. Or maybe create custom voice mp3s for there needs and modify voice.ini by hand.
02 Jun 2017 20:07 #62791 by jejeg
Unsubscribe
02 Jun 2017 20:13 #62792 by jejeg
Moeder wrote: No just update your firmware and I suggest also config.ini as there have been some changes to fonts introduced. Other than that I can't think of any changes outside the firmware itself.
off topic:
Yes it makes sense, there will be a new "voiceFR"
I started the translation, I send you my work tonight on the good topic;) .
The suite from Tuesday (vacancy without pc:( )
02 Jun 2017 20:25 #62793 by FDR
Unsubscribe
Strange, because then you should receive notifications...
02 Jun 2017 20:31 #62794 by jejeg
always not :P
Time to create page: 0.062 seconds
