Telemetry Page on Devo 10 with FrSky G-RX8
  • Schiefy01
  • Schiefy01's Avatar Topic Author
  • Devo10 / Devo F7 / Devo F7DS
29 Nov 2017 19:17 #66264 by Schiefy01
is there a possibility to reduce the Telemetry Info Page only to the received Data ?
I´d Like to use the FrSky G-RX8 with Vario and Altitude Telemetry.
For me Only this Info is needed on the Telemetriy Page during Flight.
Thanks in advance
Sven
29 Nov 2017 20:32 #66268 by Moeder
Replied by Moeder on topic Telemetry Page on Devo 10 with FrSky G-RX8
Don't you have room to put the 2 telemetry values on the main page?
  • Schiefy01
29 Nov 2017 21:22 - 29 Nov 2017 21:24 #66269 by Schiefy01
Replied by Schiefy01 on topic Telemetry Page on Devo 10 with FrSky G-RX8
Cool, Thanks for this Tipp...
Did not checked to add Boxes and the Value for this Boxes :-)
Know it´s Fine :-)
sometimes it´s so easy, but to be at a loss ...
Last edit: 29 Nov 2017 21:24 by Schiefy01.
15 May 2018 08:06 - 15 May 2018 08:06 #69232 by pulpfiction15
Replied by pulpfiction15 on topic Telemetry Page on Devo 10 with FrSky G-RX8
I would like to add a question, to the use of the G-RX8.
Is it possible to configer to have a voice announcement for the altitude (that I can do) but to get a low pitch sound when vario is negative and a high pitch sound when vario is positive ?
Last edit: 15 May 2018 08:06 by pulpfiction15.
15 May 2018 10:09 #69236 by Moeder
Can't you set up two telemetry alarms for negative and positive vario and then assign each a different custom voice alert in the voice config menu (like "negative vario rare" and "positive vario rate") ?
15 May 2018 11:29 #69238 by pulpfiction15
@Moeder,
Thanks for the suggestion, but flighing with a glider it will be a continous repetition of 'Telemitri alarm positive or negative'. Need something very short.
15 May 2018 12:20 #69239 by FDR
You can add simple tones as well...
15 May 2018 12:44 #69240 by Moeder
Or define a very short low tone music for the according telemetry alarm in sound.ini (refer to the manual) and add the entry "device=buzzer". Do the same for another alarm with a high tone. This will use the buzzer for vario beeps and keep voice free for other things.
15 May 2018 17:54 - 15 May 2018 17:55 #69246 by pulpfiction15
@moeder,
I am affraid I do not understand :blink:
Creating a short sound MP3 I understand, but when you speak about sound.ini and add an entry 'device=buzzer' I am lost.
In sound.ini I see entries like ;
[telem_alarm1]
volume=100
f3=150
f2=100
c3=100
But those are never 'played' because I use voice.ini.
Could yo explain a little more, thanks.
Last edit: 15 May 2018 17:55 by pulpfiction15.
15 May 2018 18:21 #69247 by Moeder
You can force the buzzer to be used on specific sounds in sound.ini, for example:
[telem_alarm1]
device=buzzer
volume=100
f3=50
should create a short beep on telemetry alarm 1 even though you are using voice (of course no voice will be played on this alarm).
This feature has been there since the very beginning of the voice feature (mwm's work IIRC), it's one of the things I want to move into voice menu 2.0 (see my other thread).
16 May 2018 19:17 #69259 by pulpfiction15
Thanks again Moeder for your explanation.
I modified the sound.ini in Media directory (see attachment) as ;
[telem_alarm5]
device=buzzer
volume=100
f3=50
[telem_alarm6]
device=buzzer
volume=100
c3=100
Tried with and without setting a message in the voice menu.
But I still get a voice message.:blush:
(Tested on my devo6)
16 May 2018 19:39 - 16 May 2018 19:42 #69260 by Moeder
You're right.... I introduced a bug when switching to telemetry and timer value announcements... I'll have to fix it, but it'll be more than just a single line of code, so it'll probably be a week or so to get it done, as I'm busy next week. I'll post a devo6 test build in this thread as soon as possible.
Edit: voice config 2.0 will take better care of thesesthings... But that's still a month to go or so
Last edit: 16 May 2018 19:42 by Moeder.
17 May 2018 14:36 #69278 by pulpfiction15
thanks Moeder for all your work, no hurry, it can wait one week ;)
17 May 2018 18:31 #69281 by Moeder
Sometimes weeks can be really short :woohoo:
device=buzzer should work now as expected. if you put device=all you will get voice without numeric announcement together with the buzzer.
File Attachment:
File Name: deviation-...4d0d.zip
File Size:858 KB
18 May 2018 18:22 - 21 May 2018 17:53 #69302 by pulpfiction15
@moeder,
Something is still wrong :S
With device=buzzer I have the buzzer sound and voice message 'telemetry alarm nr'
With device=all I have the buzzer sound and voice two times the message 'telemetry alarm nr'
Last edit: 21 May 2018 17:53 by pulpfiction15.
29 May 2018 09:46 #69457 by pulpfiction15
@moeder,
Did you have a chance to look at the issue, or should I wait for 'voice config 2.0'.
30 May 2018 13:07 #69480 by Moeder
I just did a quick test using the emulator before posting this build and I thought it worked. I'll work on fixing this, but you'll need to have some patience, just got back from vacation and the weather is nicer to spend outside flying than inside programming ;)
30 May 2018 22:45 #69483 by Moeder
My fix was fine, just had to move it a couple of lines up in the code ;)
Try the build attached on your devo6 please. With device=buzzer or all it should work now, but when selecting a voice on this alert in the voice config menu, this will get overridden and only voice will be played.
File Attachment:
File Name: deviation-...5-30.zip
File Size:858 KB
31 May 2018 18:07 #69490 by pulpfiction15
@Moeder,
Positif and negative 'news' ;)
The positive: with 'device=buzzer', I hear only the buzzer => OK
with 'device=all' I hear the buzzer and then 'Telemetry alarm nr' but no value afterwards ?
What is strange is that when there is an alarm, the screen switches automaticaly from the 'main screen' to the 'telemetry monitor' screen. Not seen that before.
Because of the telemetry alarms comming in slowly i treed to set in the 'telemery configuration' screen the alarms to '1s@xxx', but then I get no alarms at all ?:huh:
31 May 2018 19:26 #69491 by Moeder
That no values are announced are announced for device=all is expected behavior and will only be solved in the next evolution of voice config menu (please stop adding stuff to my to-do list :P )
I don't understand you last question.
Time to create page: 0.068 seconds
