FlySky V911 module on Devo 10, with pics.
08 Dec 2012 11:18 - 15 Dec 2012 22:01 #3781 by sbstnp
I just finished installing the module in my Devo 10 and it's working great. Pics below.
Screws on the back:
Wires & plugs for the switches and buttons. Need to unplug these as you don't have the space otherwise:
Locate the header you need to solder to. It is found right next to the Devo module. As marked, top is TMS pin, bottom is VDD. I put a bit of solder on the points, tinned my wires and the rest was easy. Plenty of space, didn't needed to dismantle the Devo module.
I unsoldered the v911 module together with the header it was attached to, then bent the pins of the header in order to gain some vertical clearance when mounting:
Then I put some double-sided tape on the Devo module and attached the v911 module after putting some heatshrink around it.
Afterwards, I just routed the v911 antena inside the Devo antena cover, this way it is oriented towards top and held in place:
Well, that's it. Took me around an hour, since I wasn't in a hurry. Easy job.
Hope I helped someone. Have a nice evening folks.
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Last edit: 15 Dec 2012 22:01 by sbstnp.
08 Dec 2012 16:50 #3798 by sbstnp
Replied by sbstnp on topic V911 FlySky module with Devo 10
Updated with pics. If someone wants to do a guide/document/howto, you have my permission to use these pics.
Devo 10 + 4in1
Spektrum Dx9
02 Feb 2013 00:10 #5898 by Mullson
Replied by Mullson on topic V911 FlySky module with Devo 10
What's your range?
02 Feb 2013 04:57 - 02 Feb 2013 04:58 #5901 by sbstnp
Replied by sbstnp on topic FlySky V911 module on Devo 10, with pics.
I haven't formally do a range check. Will do one as soon as possible cause I'm very curious myself too,
Devo 10 + 4in1
Spektrum Dx9
Last edit: 02 Feb 2013 04:58 by sbstnp.
11 Feb 2013 04:49 #6243 by kingiggy
Replied by kingiggy on topic FlySky V911 module on Devo 10, with pics.
Just installed the A7105 module in my Devo 10 but it doesn't seem to be working with the Hubsan protocol.
When I turn on the transmitter I get an alert popup that is empty and doesn't say anything and I can't bind to my X4. If I change to the FlySky protocol I no longer get the empty alert popup but I don't have any flysky compatible receiver to bind to so I'm not sure if it's working.
Anyone have the Devo 10 working with Hubsan on the latest 2.1.1 firmware?
14 Jun 2013 12:40 #10950 by Krit
Could you please explain the solder diagram? I can't understand from pictures.
14 Jun 2013 12:43 #10951 by sbstnp
You can find it very well described here:
deviationtx.com/repository/Documentation...uleInstallation.pdf/
If there's any confusion let me know.
Devo 10 + 4in1
Spektrum Dx9
14 Jun 2013 12:48 #10952 by Krit
sbstnp wrote: You can find it very well described here:
Thanks for your prompt reply. I will try then.
14 Jun 2013 12:57 #10953 by Krit
I try to study how to do with it, but my less skill make confuse. If show more diagram of Devo10 with picture is better for me.
16 Jun 2013 04:42 #11001 by Krit
I finish my mod already. Thanks all.
17 Jul 2013 06:24 #12283 by Damo
I now have two gutted WLToys Tx's, and a 2 module modified Devo 10 with nightly Deviation build.
The hardware install wasn't too bad, I made sure to check the shared wiring between the two new modules, the hardest part was dropping just enough solder onto the debug port pads on the Devo 10 PCB. Then soldering the joined wires onto the CYRF module (Next time I would join the shared wires away from the module).
Notes:
I bridged the three pins CE, Vcc & TXEN (as labeled on the module from the v222 Tx) together on the other side of the module PCB, and run one wire to Vdd on the Devo PCB. (possibly not recommended)
I wrapped my modules with electrical tape instead of heatshrink, I ran out of anything big enough.
I tucked my modules under the looms both sides near the top of the devo PCB, and ran both antennas up alongside (but only just in) the CYRF antenna.
Test both the v222 and the v911, and both worked fine first go (with model configs found on this forum). The amount of control around middle stick position was very noticeable.
Ran out of time, but will try the extra functions (camera etc) later tonight.
Here's a pic or two.
All soldered, just about to hide the modules:
File Attachment:
All tucked away (in front of the USB connector!):
File Attachment:
17 Jul 2013 08:26 - 17 Jul 2013 08:26 #12284 by minimad
My V22 is flying great with the devo10, and its so much easier to control than with the basic stock tx !
But so far, I did not had any luck with triggering camera and leds, so I'm quite impatient to see if it works for you !!!
Could you post a link to the model profile you used ?
Last edit: 17 Jul 2013 08:26 by minimad.
28 Jul 2013 23:18 #12578 by Martian
Replied by Martian on topic FlySky V911 module on Devo 10, with pics.
Just completed this tonight - It's working great! Really enjoying my WLToys 929 again!
For anyone using a A7105 from Ali Express or for anyone having range problems see this thread:
www.deviationtx.com/forum/6-general-disc...-range-problem#11977
On the A7105 you will need to short pin 8 to GND and pin 9 to VCC.
HELIs: V929, MCX2, MSR, Nano CP X
TX: Devo 10 (Deviation 3.0.0)
05 Oct 2013 19:52 #14269 by matrixFLYER
Replied by matrixFLYER on topic FlySky V911 module on Devo 10, with pics.
Where is the tck pin in Devo10?
06 Oct 2013 04:43 - 06 Oct 2013 04:44 #14280 by vlad_vy
Replied by vlad_vy on topic FlySky V911 module on Devo 10, with pics.
To the right from MCU and module - from the top: NRESET, TMS, TCK, GND, VDD
Last edit: 06 Oct 2013 04:44 by vlad_vy.
27 Jul 2015 08:11 #36131 by PITCH13
Replied by PITCH13 on topic FlySky V911 module on Devo 10, with pics.
Hello, nice job but the pictures don't show clearly the connections, and the link for the connections doesn't work, would anybody have pics and names of connectors on original devo 10 module? and connections to V911 module?
Thanks ;)
29 Jul 2015 04:48 - 29 Jul 2015 04:51 #36287 by Doug40
Replied by Doug40 on topic FlySky V911 module on Devo 10, with pics.
There is a very detailed page on how to wire up modules into various Devo transmitters somewhere on this site. I couldn't find it now and didn't know it existed when I went through the same thing. Maybe the page is down for updating. If you can't find it, it's probably best to post the question in the FEEDBACK and QUESTIONS thread, now that you know it does exist.
Last edit: 29 Jul 2015 04:51 by Doug40.
29 Jul 2015 07:07 #36289 by dc59
Download section:
www.deviationtx.com/user-manual
Installation guide:
29 Jul 2015 11:36 #36296 by mwm
The PDF linked to in the user manual section is outdated. If you follow the links link in the menu on the left, that will take you to the module installation guide, which is both up to date and actively maintained.
29 Jul 2015 12:19 #36302 by stevecox
Replied by stevecox on topic FlySky V911 module on Devo 10, with pics.
Followed the links on the left, selected RF Module Installation Guide which opened up this page bitbucket.org/PhracturedBlue/deviation/wiki/ModuleInstallation then for the 8e module install at the bottom I get this.
<paste>
Wiki
Clone wiki
Oops, it looks like that file doesn't exist
You can go back Home or create this wiki page.
Create /Devo8ModuleInstall
</paste>
It would be handy if there was a working link to a single place for the instructions and the non relevant material/links removed to avoid confusion.
Adelaide
Time to create page: 0.075 seconds
