Tutorial: Configuring throttle-hold and Expo/DR
- sbstnp
02 Jul 2013 06:04 - 02 Jul 2013 16:04 #11715
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Tutorial: Configuring throttle-hold and Expo/DR was created by sbstnp
This was moved here from another thread. This instructions were initially done for a Devo 12 owner. If somebody needs different screnshots, for 7e/10 say so please.
1. Throttle hold
There are at least 2 ways of implementing TH in Deviation.
You can do it like I did and use the channel safety method, or you can use the complex mixer. Since I didn't want to complicate things with the complex mixer, I used the channel safety.
In the first pic below, the 3 columns you see are:
channel number and name - clicking on this bring up channel properties, 1-ELE
actual source for this channel THR
type of mixer used - clicking this brings up the mixer page, Simple
First, click on the channel associated with THR. Channel 1 in this case.
You will see a screen like below. The 2 important settings are "Safety" and "Safety value"
Safety selects a condition (a switch) on which Deviation will only output the Safety Value on this channel.
In this case, whenever the Hold switch IS NOT (note the ! character) in the zero position, Deviation should output a value of -110 on this channel. I chose -110 and not -100 just to be on the safe side, this value depends on the ESC.
1. Throttle hold
Devo 10 + 4in1
Last edit: 02 Jul 2013 16:04 by sbstnp.
- sbstnp
02 Jul 2013 06:24 #11716
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Replied by sbstnp on topic Tutorial: Configuring throttle-hold and Expo/DR
2. Expo and D/R
So, how do you implement Expo and D/R for a channel? Well, you can do this again in multiple ways. I'll start with the simplest one.
First, choose the channel. I chose ELE, click on the mixer type on the right.
This window will show, notice in the upper left side the mixer type and the arrows.
Click on the right arrow to change the mixer type to "Expo&DR"
Now you can choose which switch will act on this channel rates. I chose ELE DR, but there is no limitation imposed here. You can choose FMODE for example and have the rates change together with THR and PIT when you switch to IU1 or IU2.
The next thing I did was to change the curve type to EXPO. The pic above shows this. Next, click on the curve's button to bring up this page:
Use the arrows to change the desired expo value. Note you can have different expo settings for negative/positive values, but I'll skip this, I want symmetric expo. Click ok when done.
This screen will show:
Now you basically added DR and Expo to your ELE channel.
If you want different EXPO settings for low and high rates, you need to decouple (or unlink) the current EXPO by clicking on this button:
Now you can have individual expo values. I rarely use this as it can change dramatically the way the heli flies.
Well, hope I did explain everything clearly, let me know if you have questions.
Next probably the complex mixer, but that should have it's own thread really.
Devo 10 + 4in1
- weijnri
28 Aug 2013 01:26 #13343
by weijnri
Replied by weijnri on topic Tutorial: Configuring throttle-hold and Expo/DR
Thank you for this tut.
I would love to see it with screenshots for the Devo 7e if that is possible.
- gwrivest
09 Sep 2013 18:42 #13669
by gwrivest
Replied by gwrivest on topic Tutorial: Configuring throttle-hold and Expo/DR
I would really like to see this with Devo 10 screenshots if possible.
Thanks in advance!
Gerard.
Thanks in advance!
Gerard.
- billmester
10 Sep 2013 07:51 #13684
by billmester
Replied by billmester on topic Tutorial: Configuring throttle-hold and Expo/DR
Gerard,
please look at my posts, I have shared 2 .ini`s for Devo 10, all fully configured. Just load them and you can see how I built them.
it is easy, do not worry
bm
bm
- gmcquet
12 Oct 2013 07:34 #14513
by gmcquet
Replied by gmcquet on topic Tutorial: Configuring throttle-hold and Expo/DR
Hi guys, Im brand new with deviation, never actually used it yet. Im now just trying this tutorial. I've noticed on the mixer screen I don't see "Pos 0" "Pos1" etc, I see "High rates" "Med rates". Where am I going wrong?
G
G
12 Oct 2013 09:21 - 12 Oct 2013 09:22 #14517
Replied by rbe2012 on topic Tutorial: Configuring throttle-hold and Expo/DR
At first a big small WELCOME (EDIT: 18 posts and still new?)
The Pos0... result from the Romanian language file and is simply the translated text for "High-Rate". You have done nothing wrong.
In the English version they are called High-Rate, Mid-Rate and Low-Rate.
Last edit: 12 Oct 2013 09:22 by rbe2012.
- gmcquet
12 Oct 2013 15:43 #14529
by gmcquet
Hi there,
thanks for the welcome!
Aha yes, I joined a while ago as I was always planning on using deviation. I had my first deviation flight this morning with a Blade 350 qx... worked great! Thankfully, someone had posted a model config for the blade. There is no way I would have been able to create a model template for it, I have soooo much to learn!
G
G
- gmcquet
12 Oct 2013 15:44 #14530
by gmcquet
Im wondering how I can set up some dual rates for ele, aile and rudd as well expo too for FMOD 0, then Higher rates and less expo for FMOD 1, and then finally highest rates with very low expo for FMOD 3. I am struggling!
G
G
12 Oct 2013 17:41 #14534
Change the mixer type to EXPO/DR and you have all you need on one page.
- gmcquet
12 Oct 2013 17:47 #14536
by gmcquet
I got that far but then got a little stuck.
I have a Durafly Spitfire MK 24 with an RX802 inside. I will try again tomorrow and mess around to see if I can get the right settings...
Has anyone done any youtube type tutorials for deviation with regards to expo/mixing etc?
G
G
12 Oct 2013 17:53 #14538
You have three columns, define a switch for the middle and right row.
Choose a curve for the normal mode (in my example: not FMODE1 and not FMODE2 = FMODE0), like EXPO, configure the expo amount and a scale (=DR) value. For the other flight modes use other scale / expo values which better fit to the flight mode:
- sbstnp
12 Oct 2013 21:58 #14542
by sbstnp
I use Pos0,1,2 in order to match the labeling on the case, because I personally use Pos0 for low rates usually and at some point Deviation had it backwards. No idea if this is still the case though.
Devo 10 + 4in1
Spektrum Dx9
gmcquet wrote: Hi guys, Im brand new with deviation, never actually used it yet. Im now just trying this tutorial. I've noticed on the mixer screen I don't see "Pos 0" "Pos1" etc, I see "High rates" "Med rates". Where am I going wrong?
Devo 10 + 4in1
- carlnoki
02 Mar 2014 01:32 #21057
by carlnoki
Replied by carlnoki on topic Tutorial: Configuring throttle-hold and Expo/DR
I NEED IT for my DEVO 10 please.
thanks in advance.
Carl
thanks in advance.
Carl
- Solmer
16 Mar 2014 18:00 #21596
by Solmer
Replied by Solmer on topic Tutorial: Configuring throttle-hold and Expo/DR
Hi, thank you so much for the info. Could you post 7e screen shoots?.
Thanks in advance.
Thanks in advance.
- Rkozak99
25 Apr 2014 13:29 #22713
by Rkozak99
Replied by Rkozak99 on topic Tutorial: Configuring throttle-hold and Expo/DR
Would love to the same screens for the dev10
Thanks in advance.
Thanks in advance.
Time to create page: 0.496 seconds
