Assigned Channel to a Switch
08 Oct 2014 17:04 #26012 by Torch
Assigned Channel to a Switch was created by Torch
I would like to add channel (Safe or panic mode ) to a switch for UM airplane using AS3x along with Safe and panic mode. Since airplane don't have Simple Configure how do I do it under Advance?
09 Oct 2014 22:14 #26020 by mikemacwillie
Replied by mikemacwillie on topic Assigned Channel to a Switch
After setting the advanced mixer, pick the channel you need to assign in the mixer, use the 'Simple' type, set the Src to the switch you want to use. If you only need a 2 position switch, use Min/Max for the curve. Save it, and you're done.
Time to create page: 0.028 seconds
