Ultimate7e tutorial: Adding 2 potentiometers
16 May 2016 19:44 - 11 Jul 2016 16:56 #48543 by silpstream
The tutorial for adding 2 potentiometers to the Ultimate7E is ready at:
Ultimate7e tutorial: Adding 2 extra potentiometers
Video of it:
This modification requires upgrading of the Devo7E processor. The link for how to do it is below.
Test builds are available on the deviationtx site (Downloads -> Test Builds ). There you'll find:
  • [silpstream]Ultimate7e-v5.0.0: Test Builds - Build based on BRANCH_5.0.0 (Latest stable release with bug fix updates only).
  • [HappyHarry]Ultimate7e Deviation5.0.0-xxxxxxxx - Build based on nightlies (Latest and greatest deviationtx features get tested here).
HappyHarry's Ultimate 7e-256k builds thread: Ultimate 7e-256k builds
Processor upgrade thread: Ultimate7e tutorial: Processor upgrade
Extra switches thread: Ultimate7e tutorial: Four 3-way + two 2-way switch
Last edit: 11 Jul 2016 16:56 by silpstream.
16 May 2016 21:38 #48553 by Fernandez
Replied by Fernandez on topic Ultimate7e tutorial: Adding 2 potentiometers
Thanks Great Job !!!
16 May 2016 22:10 #48556 by HappyHarry
Replied by HappyHarry on topic Ultimate7e tutorial: Adding 2 potentiometers
awesome work as usual bud, thanks for sharing 8)
16 May 2016 22:54 #48559 by Cereal_Killer
Replied by Cereal_Killer on topic Ultimate7e tutorial: Adding 2 potentiometers
Woo-hoo! My RCT6 just got here and plus I was waiting on this one most. Can't wait to have some time to get these mods all done! Thanks for all your work with these three great tutorials.
16 May 2016 23:43 #48561 by Toxuin
Hey,
What potentiometers did you use? Did you buy them off BG?
17 May 2016 00:10 - 17 May 2016 00:32 #48563 by Cereal_Killer
Hello SlipStream, on this page your link to PB's 256k bootloader is not working for me. Where can I find a copy?
Edit: I was able to find it here so I'm good but note I even tried clearing my catch and the link still didnt work, it throws a strange looking error, just FYI.
Last edit: 17 May 2016 00:32 by Cereal_Killer.
17 May 2016 02:51 - 17 May 2016 03:01 #48566 by HappyHarry
it's throwing an error because the location of the downloads has changed since the time the howto was posted is all.
as for the pots it seems bangood has every taranis spare part bar the front pots (they have the side slider pots but these have only 90deg of throw) but you can get taranis front pots from aliexpress here >>
taranis x9d pots
as well as lots of other places that sell taranis spare parts. you can also use the hobbyking pots for the turnigy x9r, but they are out of stock atm>>
turnigy 9xr pots
and these are the ones silpstream linked me too when I asked him previously
5kohm pots
but afaik any 5kohm pot in this size range will work, so perhaps any of these might work >>
BG 5k pot
and these (if they fit as they are slightly bigger than the rest) BG 5k pot 2
Last edit: 17 May 2016 03:01 by HappyHarry.
17 May 2016 10:33 #48583 by silpstream
Replied by silpstream on topic Ultimate7e tutorial: Adding 2 potentiometers
Cereal_Killer wrote: Hello SlipStream, on this page your link to PB's 256k bootloader is not working for me. Where can I find a copy?
Thanks for the heads up! I've corrected the links.
19 May 2016 02:23 - 19 May 2016 02:24 #48670 by Cereal_Killer
Am I the second one done (after SS's)?
Took a old socket / plug and glued it in place then ran my 4 wires to that (yes I know I could of gotten GND from the rear cover but I had enough pins so why not).
BTW who can spot my stupid mistake and how I fixed it? Hint: no pictures are mirrored....
File Attachment:
File Attachment:
File Attachment:
File Attachment:
Last edit: 19 May 2016 02:24 by Cereal_Killer.
19 May 2016 02:31 - 19 May 2016 02:49 #48671 by Cereal_Killer
BTW another huge thank you to SlipStream for ANOTHER great tutorial. TBH this soldering job was much more time consuming than the whole proc swap!
Edit: Where can I report bugs in your custom build? I've found a big one (not complaining, just wanting to be as helpful as I can).
Last edit: 19 May 2016 02:49 by Cereal_Killer.
19 May 2016 05:19 #48680 by silpstream
You would be except PB was the first to come up with this solution. ;)
As for your booboo, it seems your pot wiring had to change sides...lol
Do report bugs please. The thread is here Ultimate 7e-256k builds .
19 May 2016 07:13 #48687 by Fernandez
Stil waiting for my parts, than indeed want to do the full mod.....
You need two cpu pins for the pots and one pin for the cns line of the 4th Rf module, were did you connect that one?
The extra switches do not need addional I/O just re-wiring and diodes.
Next step would be to add the DFplayer, voice module,? I assume the new cpu should be able to handle it, would be tight and compact unit.....
19 May 2016 08:48 #48691 by silpstream
Let us know when you get the mods done. :)
The 4th module connections are the same as the stock devo7e. There has been success with PB3 and PA15 from what I remember. Either should be fine as long as you update hardware.ini.
The voice module will probably need the modification for the DSC port. I'm not sure if it is ready yet. It will definitely fit on the u7e processor, but I'm not sure if anyone on that project has tried implementing for the u7e. I'll take a quick look later at the code.
01 Jun 2016 12:24 #49735 by phantom8
Replied by phantom8 on topic Ultimate7e tutorial: Adding 2 potentiometers
silpstream, thanks for the tutorial. I've added 2 potentiometers, but didn't do the four 3-way & two 2-way mods. I've the original two 3-ways mods. I downloaded your "Ultimate7e Dev5.0.0-fcfdb6e-Switchmods 25th May", but it was not working properly. My two 3-way switches no longer work. Maybe caused by the different wiring that your new switch mod used. The strange thing is the 2 potentiometers also didn't work. I've checked all connections and didn't see anything wrong. Does the potentiometers only work with your four 3-way & two 2-way mods?
01 Jun 2016 12:33 #49738 by Cereal_Killer
The pots REQUIRE calibration before working but they should work, even with the incorrect switch wiring.
01 Jun 2016 13:11 #49747 by phantom8
Cereal_Killer wrote: The pots REQUIRE calibration before working but they should work, even with the incorrect switch wiring.
Just found out re-calibration requirement before seeing your post. The pots are working fine now. Thanks you!
BTW, the build "[HappyHarry]Ultimate7e Deviation5.0.0-fcfdb6e-Switchmods 25th May" didn't work properly with original 3x2 switch mods. I changed to "[silpstream]Ultimate7e-v5.0.0: Test Builds" and everything is working fine, including 3x2 switch mods.
01 Jun 2016 15:10 - 01 Jun 2016 15:10 #49757 by silpstream
@phantom8, would you mind testing HappyHarry's 31st may build and let me know if it works. That's the latest after the mods were added to the main trunk. I only have 1 7e configured for 6 switches so can't physically test it. Thanks for the help! :)
Last edit: 01 Jun 2016 15:10 by silpstream.
01 Jun 2016 16:25 #49763 by phantom8
silpstream wrote: @phantom8, would you mind testing HappyHarry's 31st may build and let me know if it works. That's the latest after the mods were added to the main trunk. I only have 1 7e configured for 6 switches so can't physically test it. Thanks for the help! :)
Just tested the "[HappyHarry]Ultimate7e Deviation5.0.0-720b78f 31st May" built. It's working fine with the original 3x2 switch mod. :)
01 Jun 2016 16:26 #49765 by silpstream
Thanks for that! At least there isn't a bug to track down... lol!
01 Jun 2016 16:33 #49766 by phantom8
silpstream wrote: Thanks for that! At least there isn't a bug to track down... lol!
I should be the one who says thank you. Your tutorials are tremendous help. Great work!
Time to create page: 0.688 seconds
