7e/Ultimate7e, adding the devo version 4in1
- HappyHarry
01 Jun 2016 23:56 - 06 Sep 2017 01:45 #49788
by HappyHarry
7e/Ultimate7e, adding the devo version 4in1 was created by HappyHarry
[EDIT]The deviation version 4in1 board is now available at banggood
here are links to the 4in1, a ufl to sma pigtail and a 3dbi dipole antenna that will work for this modification.
Deviation 4in1 >> www.banggood.com/CC2500-NRF24L01-A7105-C...itter-p-1096707.html
ufl<sma pigtail >> www.banggood.com/10cm-PCI-UFL-IPX-to-RPS...-Cable-p-924933.html
3dbi dipole antenna >> www.banggood.com/2_4GHz-3dBi-RP-SMA-Conn...Router-p-979407.html
after photobucket's awful service change (they want $400 a year to allow showing your pictures on a 3rd party site/forum/blog etc!) my pictures are no longer showing properly. So i will need to swap all images to another provider and then update all forum links etc, I have a lot of hobbies/forums/posts to cover so in the interim here is a link to the album where the photos from this thread are stored >> Photobandit u7e 4in1 swap album
[/EDIT]
thanks to cmPang I was able to get a hold of one of the new 4in1 modules that have a daughterboard specifically for use with deviation, they are pretty much plug and play bar 3 wires in the d10 (possibly the d6/8/12 also?) as it uses the same 10pin 2mm pitch header. unfortunately the 7e's rf board is soldered in so we have to do a little more work. first up as this module contains all 4 rf chips we no longer need the stock rf board so I removed it, as it was soldered in the factory using lead free solder you will make life much easier for removal if you add a bit of leaded solder before wicking the solder off the 3 corners. be careful when desoldering the 7 hookup points as it's easy to lift a trace (I thought I had got away with it but when I went to solder the 5v line it just lifted off :/ ) here's the board with the rf module removed.
once that's done it's time for the trickiest part, we need to solder a wire to the mcu to use to enable the 4th rf module, if you have a look at silpstreams great howto on adding pots to the ult7e here >> Ultimate7e adding pots you will find a nice method of singling out the required pin using kapton tape. use pin 50 on the mcu, this equates to A15 in hardware.ini. in the following picture the yellow wire is the one in question, the other 2 wires soldered to the mcu are for the pots (see above tutorial by silpstream) and are not part of the 4in1 install.
[/EDIT]
Last edit: 06 Sep 2017 01:45 by HappyHarry. Reason: added links for the picture album
- HappyHarry
02 Jun 2016 00:05 #49789
by HappyHarry
Replied by HappyHarry on topic Ultimate7e, adding the devo version 4in1
next up is wiring in the actual module, I removed the 10pin header and soldered directly to the board, following the wiring diagram shared by cmPang (I've copied to this post) hook up the 4in1 to the 7e's pads
wiring guide and module hookup pics
(note that I had to use an alternate point to source 5v, it would usually be taken from pin6 of the rf board pins)
and that's the difficult part done, all that's needed now is to modify the hardware.ini to suit the wiring points, fit an antenna and go fly. though as I'm not keen on the rf path used on this daughterboard I'm going to modify it slightly, I'll be doing that tomorrow so I'll post details on that when it's completed.
- dc59
02 Jun 2016 00:30 #49793
by dc59
Fantastic , HH.
Replied by dc59 on topic Ultimate7e, adding the devo version 4in1
- Cereal_Killer
02 Jun 2016 04:07 #49804
by Cereal_Killer
Replied by Cereal_Killer on topic Ultimate7e, adding the devo version 4in1
Nice! Is there a product link yet? I have like 1400 BG points saved up, I want one!
- silpstream
02 Jun 2016 08:09 #49814
by silpstream
Replied by silpstream on topic 7e/Ultimate7e, adding the devo version 4in1
Nice one HappyHarry! I'll add it to the wiki.
- HappyHarry
02 Jun 2016 23:40 - 27 Oct 2016 21:35 #49844
by HappyHarry
Replied by HappyHarry on topic 7e/Ultimate7e, adding the devo version 4in1
thanks guys, CK it's not fully available yet, why I don't know but I'm sure it'll show up on taobao and banggood soon.
ok to carry on from yesterday it's time to sort the antenna, although the module has an ufl antenna connector I'm not keen to use it, being as the trace that comes from the side of the 4in1 to that ufl is unsheilded, and measures ~32mm it's almost a perfect 1/4 wave monopole antenna! after some discussion and then reading up on this matter it turns out that the existing ufl connector and it's trace are perfectly fine to use, there is no reason to modify as i have done and you can find links in the first post for a ufl to sma pigtail that you can use instead.
so to get rid of this I just broke the trace where it connects to the 4in1 board, I just used a hobby knife and scored the copper away as below
I could have reused the antenna from the stock 7e module but I'm taking the opportunity to mount an sma header so I can use a proper removeable dipole antenna, so I prepared and soldered the antenna header direct to the 4in1 contact points
next up I took my lathe with a parting tool (
) and modified the stock antenna tube by cutting it off about 2-3mm above the point where it changes from the thick part to the thin, this leaves enough of a ridge for the sma header to sit against without pulling right through
after cutting
with that done it was simply a case of feeding the header through and tightening the holding nut, fitting the antenna and placing it on the tx
and that's the job done. I'm almost to the point of having the 7e I always wanted, multi protocol with a single repositionable antenna, and enough switches and a few pots to fully utilise deviations available channels, when it gets to that point it will be able to replace my dsm9x!
thanks to PB and Silpstream all i have to do is just finish wiring up the extra switches and pots and it's all the way there
, the ultimate 7e, the $100 cost tx with capabilities way way above it's price point!
after cutting
Last edit: 27 Oct 2016 21:35 by HappyHarry.
- silpstream
03 Jun 2016 17:02 #49884
by silpstream
That looks really sweet! Gotta get myself one of those boards. I love the antenna mod. Any idea how range was affect pre and post mod?
- HappyHarry
03 Jun 2016 17:21 - 03 Jun 2016 17:22 #49887
by HappyHarry
it does make it a clean looking install compared to the separate modules eh, though the main thing i like about it is that all 4 rf chips now have a good antenna without making my tx look like a porcupine lol. the range between using the stock 7e antenna and this antenna shouldn't be any different as they are both 2db gain dipole's, (though with the sma header i can use larger gain antennae if i wanted) but now i can position the antenna for the best polarisation direction instead of it being in a fixed position. as for the difference between using the stock ufl and my modded version i'm not sure, like i said above that trace is 1mm longer than a perfect 1/4 wave monopole antenna and there's no way i'd have flown with it as such, although i'm no rf guru i'm pretty sure a lot of the tx power would have radiated away before even reaching the ufl connector. and while the pcb trace might work well as an antenna on it's own, i didn't want to take that chance
as for range vs using separate modules cmPang and dc69 have both posted favourable reports, and as i now have another ult7e that does have all 3 separate modules i'll be able to test back to back, though they are all using internal antennae so the results should be slightly skewed in the 4in1's favour. i just hope he's addressed the pa/lna and telemetry issues with the nrf and a7105 in this recent 4in1 board.
Last edit: 03 Jun 2016 17:22 by HappyHarry.
- silpstream
03 Jun 2016 17:51 #49890
by silpstream
I probably know less than you about RF. Thanks for the info! I'll probably modify the antenna the same way once I get my hands on the new 4in1.
- cmpang
03 Jun 2016 18:15 #49891
by cmpang
Replied by cmpang on topic 7e/Ultimate7e, adding the devo version 4in1
good job hh..
now that i have been flying and boating for 3 weeks, i can say that i see no difference in rf performs from the stock cyrf and the previous cc2500 (frsky) add on module.
since i have no long range models in nrf2401 and a7105, i cannot be certain on these two. but i do tested my v911 (flysky)and v931 (kn)and all is fine,( on version 4.01)
- victzh
03 Jun 2016 22:02 #49898
by victzh
Replied by victzh on topic 7e/Ultimate7e, adding the devo version 4in1
@HappyHarry, if you are talking about the trace from RF module to the U.FL connector, its length can't be taken in consideration in isolation. What is important that's the impedance of the trace - it should match the impedance of the RF module and impedance of the antenna. This trace is so called "transmission line" and if all impedances match everything is OK. They should all be 50Ohm. Does this trace have impedance of 50Ohm - I don't know. It looks like one of the possible type of transmission lines - edge coupled microstrip, but the sizes don't look like valid 50Ohm line. Also, there is a rule that if some line is less than 1/10 of wavelength you shouldn't bother. If more - impedances better match. So everything shorter than 1.2cm is OK.
- cmpang
04 Jun 2016 00:18 #49899
by cmpang
the key is everything is matched along the whole length.
for those pcb that uses a short length of wire as antenna then the length of the pcb trace would comes into play.
with a proper rf connector and antenna then the trace can be any length as long as its physical charastic matches as a transmission line
- dc59
04 Jun 2016 05:48 #49902
by dc59
Replied by dc59 on topic 7e/Ultimate7e, adding the devo version 4in1
Hi HH,
Is there any power issue about 7E+4in1 module ?
LDO has enough current for 4in1 module?
Thanks.
Thanks.
- SeByDocKy
04 Jun 2016 07:32 #49903
by SeByDocKy
Replied by SeByDocKy on topic 7e/Ultimate7e, adding the devo version 4in1
Amazing modding want the same ....
-256Ko
-4in1
-2x3 extra switches
- 2 pots ....
OMG... I think I will buy a new 7E to build such project
-256Ko
-4in1
-2x3 extra switches
- 2 pots ....
- silpstream
04 Jun 2016 09:05 #49910
by silpstream
You can actually do 4x 3-way with 2x 2-way switches and 2x pots.
If you do do this, please record it into one of your amazing tutorial videos.
SeByDocKy wrote: Amazing modding want the same ....
-256Ko
-4in1
-2x3 extra switches
- 2 pots ....
- HappyHarry
04 Jun 2016 10:10 #49912
by HappyHarry
victzh and cmPang thanks for the info, like I said I'm no rf guru so I appreciate that my thinking may have been off. but as my setup now matches the 4in1/jr daughterboard antenna position it should be ok?
dc59 the 4in1 devo version doesn't use the 3.3v line it takes 5v, so the ldo isn't being used to power it
yeah thanks to pb and silpstream 2pots, 4x3ways and 2x2ways are now possible, and that's where this birds nest of wires is heading
and you can lay bets i'll never have the idea to crimp kynar wire into servo connectors again :/
that was not fun to do lol
- HappyHarry
04 Jun 2016 12:40 - 04 Jun 2016 12:43 #49918
by HappyHarry
well she's now complete, the ultimate7e I've always wanted! here's how the switch and pot wiring ended up
and the completed tx (minus it's sticks
it's a beautiful sunny day and I was away to go flying, till I remembered that I lost all my model ini's when my original 7e turned up it's toes, so I'm away to do some programming first lol
again I want to thank pb for developing the ult7e, and silpstream for improving it and giving us nice easy to follow howto's
Last edit: 04 Jun 2016 12:43 by HappyHarry.
- TheMadCADer
04 Jun 2016 23:03 #49928
by TheMadCADer
Replied by TheMadCADer on topic 7e/Ultimate7e, adding the devo version 4in1
How can I get one of these as quickly as possible?
I just killed my stock module after trying out the range mod today (too much heat, so things around started floating out of place) and I'd like to use one of these, so I can get back to flying asap
- SeByDocKy
05 Jun 2016 06:30 #49934
by SeByDocKy
How beautiful is the final result .... Want one want one want one
Question? Why you didn't use the original uFL/IPX connector ?
- HappyHarry
05 Jun 2016 08:58 #49937
by HappyHarry
TheMadCADer the devo 4in1 is not readily available yet, I was only able to source it due to the kindness of another member of this forum. I'm sure they will turn up on taobao and banggood soon enough though, but if you can't wait there is always the 3in1 board which is compatable with the 7e.
seby I didn't use it due to my ignorance of rf antennae, I thought the bare copper trace from the 4in1 to the ufl would act as an antenna due to it being ~32mm long, but victzh and cmPang informed me that that's not the case and it would be fine using it
Time to create page: 0.608 seconds
