FS-A8S / SPRACING F3 / DEVO10 AUX not moving in BF
- flyngobanana
- Topic Author
16 Aug 2017 05:38 #63813
by flyngobanana
FS-A8S / SPRACING F3 / DEVO10 AUX not moving in BF was created by flyngobanana
I'm finishing the rebuild of my X210 with a new PDB and FS-A8S receiver.
The receiver is bound with the DEVO10 using IBUS, I can see the sticks moving in BF but AUX switches do not react. Any idea?
Thanks for your help.
16 Aug 2017 06:08 #63814
Replied by vlad_vy on topic FS-A8S / SPRACING F3 / DEVO10 AUX not moving in BF
Do you calibrate AUX pots along with sticks?
- flyngobanana
- Topic Author
16 Aug 2017 09:21 #63817
by flyngobanana
Replied by flyngobanana on topic FS-A8S / SPRACING F3 / DEVO10 AUX not moving in BF
Just did it but remains the same.
- Deal57
16 Aug 2017 12:12 #63819
by Deal57
Replied by Deal57 on topic FS-A8S / SPRACING F3 / DEVO10 AUX not moving in BF
Check your Devo 10 transmitter menu Channel monitor to see that channels 5 and 6 are active... note, you may be a able to see movement in the Input monitor, which shows you which switches are in being used, but movement in the Channel monitor shows what the Devo is actually transmitting.
If you are seeing movement on the aux channels, then the problem is in the BF settings. If you are not seeing movement, then post your model.ini file.
Let us know either way. I had my 110 set up that way so I can check your BF settings.
- flyngobanana
- Topic Author
16 Aug 2017 17:11 - 16 Aug 2017 17:33 #63823
by flyngobanana
I can see pods movements in the stick input of the DEVO. What could be the problem in BF?
CLI in attachment.
CLI in attachment.
Last edit: 16 Aug 2017 17:33 by flyngobanana.
- Deal57
16 Aug 2017 19:26 - 16 Aug 2017 19:27 #63824
by Deal57
Not sure what you mean by "pods movement"? I don't see anything in the CLI dump that stands out, and it looks like your BF receiver and modes are set up. So something isn't communicating between the Devo and the FC... could be the Devo model.ini settings, or it could be your receiver.
In the channel monitor on the Devo, you should see ch5 and ch6 and as you change the switches the values will change. If that's not happening, post your model.ini.
Last edit: 16 Aug 2017 19:27 by Deal57.
- flyngobanana
- Topic Author
17 Aug 2017 08:00 #63840
by flyngobanana
Well, CH5 and CH6 are actually missing in the mixer output of the channel monitor. It's not from the receiver, I tried with another new FS-A8S I've got as spare, still have only 4 channels.
I'm struggling to find the way to get the .ini file, I have installed drivers but nothing appears in the devention usb upgrade tool.
- M8A4X
- M8A4X
17 Aug 2017 08:55 - 17 Aug 2017 08:55 #63841
by M8A4X
Replied by M8A4X on topic FS-A8S / SPRACING F3 / DEVO10 AUX not moving in BF
Hi!
You have to assign switches to channels by crating a mixer in order for them to be transmitted to the receiver.
Please find attached a .zip file containing a picture series showing the assignment.
The screenshots are taken from a Devo F12E but the procedure should be the same for your Devo 10.
Best regards,
Max
Best regards,
Max
Last edit: 17 Aug 2017 08:55 by M8A4X.
- flyngobanana
- Topic Author
17 Aug 2017 13:23 #63844
by flyngobanana
Great step by step instructable, can't be more easy to understand.
I've got the 7 channels I need but I have choosen a 3 position switch for channel 7. I can have only position 0 and 1 working, how can I get also position 2?
Thanks a lot.
Thanks a lot.
- M8A4X
- M8A4X
17 Aug 2017 14:17 #63846
by M8A4X
Good to hear you almost got it going!
For a 3 way switch I used another mixer type for one channel.
You can find it attached as screenshots.
- flyngobanana
- Topic Author
17 Aug 2017 14:29 #63847
by flyngobanana
I tried 3 different ways with complex mixers since an hour without any success, got it to work in 2 minutes with yours.
Thanks again.
Thanks again.
- M8A4X
- M8A4X
17 Aug 2017 15:23 #63848
by M8A4X
You´re welcome and glad that it works
Time to create page: 0.066 seconds
