Where the Heck is the RF Chip?
- C0ckpitvue 777
- Topic Author
07 Nov 2018 18:41 #71621
by C0ckpitvue 777
Where the Heck is the RF Chip? was created by C0ckpitvue 777
I'm trying to take captures for a bad little micro that's been rebranded,the original name was the yifei Phantom which is called now the the sproutoy Phantom.The tx is different and so is the protocol.I'm trying to take capture but don't see a rf chip to solder the jumper wires.If anyone can assist and is familiar with this kind of t.x please chime in.I attached a few screen shots..
- goebish
- I Void Warranties
07 Nov 2018 20:11 - 07 Nov 2018 22:17 #71625
by goebish
Replied by goebish on topic Where the Heck is the RF Chip?
Last edit: 07 Nov 2018 22:17 by goebish.
- goebish
- I Void Warranties
07 Nov 2018 20:42 - 07 Nov 2018 21:13 #71627
by goebish
Last edit: 07 Nov 2018 21:13 by goebish.
- C0ckpitvue 777
- Topic Author
08 Nov 2018 01:22 #71634
by C0ckpitvue 777
Replied by C0ckpitvue 777 on topic Where the Heck is the RF Chip?
This is a test capture,I followed your pinout and put the ground to the battery ground..
www.mediafire.com/file/oxb2iwnjxaqs2lk/T...Bound.logicdata/file
- goebish
- I Void Warranties
08 Nov 2018 09:12 #71643
by goebish
- C0ckpitvue 777
- Topic Author
10 Nov 2018 01:02 #71693
by C0ckpitvue 777
Mission failed,lol.I must of put to much heat on the pad because when I turn on the t.x. now it's just a solid led,no blinking binding indicator.I destroyed like 3 t.x trying to get captures from this.I will look for another t.x for it although there are 2 different protocols,if anybody has any of them,the sproutoy phantom or the yifei phantom,iI truly encourage you to take captures to get this deviated.It flies like a more bionic durable version of the jj1000.If anyone can link me to a place of purchase it will be greatly appreciated...
- goebish
- I Void Warranties
10 Nov 2018 03:00 - 10 Nov 2018 03:10 #71700
by goebish
Do not turn power on until you are sure there are no solder bridges
Also, better remove the batteries while you're soldering.
Now that you have some dead boards, use them to practice soldering wires to those tiny legs ...
Tip: use 30awg stranded silicone wires (doesn't melt...) and 0.5mm leaded soldering wire (Sn60Pb40).
Always get a good brand for the soldering wire, never buy it from the usual cheap websites
Last edit: 10 Nov 2018 03:10 by goebish.
- goebish
- I Void Warranties
10 Nov 2018 03:00 #71701
by goebish
Anyway, I wouldn't waste too much time on this one, I'm almost sure that's a LT8910 ...
- C0ckpitvue 777
- Topic Author
10 Nov 2018 03:12 #71702
by C0ckpitvue 777
Thanks for the feedback,it's very much appreciated....
Time to create page: 0.090 seconds
