Carn't upgrade my Devo12s
- Berryman
- Topic Author
WHO CAN HELP?
- -=Hubi-Dirk=-
1. do you want to install your Devo 12s with a new firmware or
2. do you want to save an ini file in the Devo for a new model?
- Berryman
- Topic Author
- -=Hubi-Dirk=-
Use the latest version of the DfuSe tool.
walkera-fans.de/download/tools/dfuse/Dfu...rade-Tools-3.0.5.zip
Read and follow the instructions for installing Deviation on the 12s. Please note the special installation of the library file.
deviationtx.com/user-manual/user-manual-6-8-12
Use Dfuse USB Upgrade Tools v2.31
walkera-fans.de/download/tools/dfuse/Dfu...e%20Tools%202.31.zip
If you have USB logo on screen, you need format the transmitter USB drive and copy the filesystem from firmware archive.
- Berryman
- Topic Author
- -=Hubi-Dirk=-
vlad_vy wrote: Do not use DfuSe 3.0.5, it's DfuSe Demo. You can destroy bootloader with it.
Thanks for the information, Vlad!!!
- Berryman
- Topic Author
- Mack775
- Berryman
- Topic Author
It's stuffed !
Any other suggestions.
- -=Hubi-Dirk=-
You can NOT use DfuSe for this action.
- Mack775
- aMax
for this transmitter and tested a model upload. All this worked with the Walkera Firmware.
Then I started new with Deviation and how should I say, it worked this time. Fortunately I had a current backup of the models.
- Mack775
- -=Hubi-Dirk=-
Mack775 wrote: You have to get the file system on the 12s before it will work. The 8s and 12s have to be flashed with media.dfu under the media tab. Go back and read the forum about all flashing. I got and f7 stuck in usb sometime back and got it to work. Don't give up when you get it right it will work. Study the forum.
This is only right for the Devo 12s, not for the Devo 8s.
