DSC PPM output
07 Mar 2021 10:27 #77291 by Maco33
DSC PPM output was created by Maco33
Hi, I tried all the options to set the DSC output as PPM (Deviation10UserManual.pdf), but the signal still doesn't show. Do you have any idea how to help me with this? I also performed the HW measurement of the transmitter ;-)
Thank you.
07 Mar 2021 15:16 #77302 by Maco33
Replied by Maco33 on topic DSC PPM output
I finally got the PPM signal from the DSC connector. It was necessary to press the Re-Init button for the PPM protocol. However, I would need the transmitter to transmit an RF signal at the same time and there is also a PPM signal on the DSC connector. Is this possible with Deviationtx firmware?
Time to create page: 0.033 seconds
