T-Rex 450 SE V2 with RX601
- flyguy
10 Nov 2012 16:50 - 10 Nov 2012 17:16 #2841
by flyguy
T-Rex 450 SE V2 with RX601 was created by flyguy
on request, my T-Rex 450 config
hardware:
ESC: Kotronic Jazz 40 LV (Governor Mode and Soft Start configured)
Gyro: GY-401
Motor: Stock (3700KV)
RX: RX601
rx channel assignment:
ch1 (ele): rear swashplate servo
ch2 (ail): right swashplate servo
ch3 (thr): esc
ch4 (rud): rudder gyro
ch5 (gear): left swashplate servo
ch6 (aux1): gyro sensitivity
dual rates:
rud dr: 100% & 80%, no expo set
ail dr: 100% & 80%, no expo set
ele dr: 100% & 80%, no expo set
be careful, heli is kind of agile with these settings, add as much expo as you like.
switches:
gear: autorotaion and/or panic switch, sets throttle to -100%
fmode0: throttle is bound to the throttle stick, min pitch: -3 degrees, max pitch: +10 degrees
fmode1: throttle 80%, min pitch: -10 degrees, max. pitch: +10 degrees
fmode2: throttle 90%, min pitch: -10 degrees, max. pitch: +10 degrees
you might configure some throttle curves, if your esc is not in govenor mode
gyro sensitivity:
GY401 works in AVCS mode, if sens channel is larger than 0% and in normal mode, if smaller 0%. The sens can be modified by using the trim buttons next to the "mix switch", the current value is also shown on the main page. A good startpoint is 80-90%.
basic setup procedure (for those people, who don't know how to do):
1. move sticks to neutral postion, all swashplate servo arms should be aligned perfectly horizontally now, if not, correct the position physically, then use subtrim for fine tuning
2. in this position, pitch should be 0 degrees for both blades, if not, correct it physically
3. to set minimum and maximum pitch (i use +/-10 degrees), use min and max settings of the three "swashplate channels" (ele, ail, gear), but always use the same value for min or max on all three channels (be careful here, gear is inversed, so min = max and max = min!!!)
4. you are done, have fun.
hardware:
Gyro: GY-401
RX: RX601
ch3 (thr): esc
dual rates:
switches:
gyro sensitivity:
Last edit: 10 Nov 2012 17:16 by flyguy.
- QC102
10 Nov 2015 10:53 #39815
by QC102
Replied by QC102 on topic T-Rex 450 SE V2 with RX601
I know this is a very old thread - but I am scouring the forum for information to learn about all the model configuration.
At the bottom of the list in the model.ini attachment are a lot of ������� are these "coe" and not seen as text when pasted - or just junk that can be deleted?
TIA
TIA
- flyguy
10 Nov 2015 11:19 #39817
by flyguy
Replied by flyguy on topic T-Rex 450 SE V2 with RX601
I don't know where these come from, never seen it. You can try removing it and give it a try. If I find some time, I can post my latest config for my t-rex 450, I'm not sure if I changed something important during the last years.
- Deal57
10 Nov 2015 12:15 #39821
by Deal57
Replied by Deal57 on topic T-Rex 450 SE V2 with RX601
When a model.ini is saved in the Devo, it will have these "nul" characters at the end. You can ignore them or erase them.
- QC102
27 Nov 2015 23:47 - 28 Nov 2015 00:50 #40451
by QC102
If you could post your latest config... it would be appreciated. I used the one above and although it will bind with my RX1002 - ( I cannot get the 8768768thing to bind following the "how to's" from a few sources) but the stick dont work!
Tried everything I can to sort it... nothing changes!
First ever build and following youTube vids as helpers...
EDIT: Ignore this.. I am a bigger idiot than first thought!! I "assumed" the "450" referred to a variant of the DJI 450 X quad frame! Which probably explains why cannot get anything on the quad to work! A search for T Rex 450 found a vid on YT - heli's!
Last edit: 28 Nov 2015 00:50 by QC102.
Time to create page: 0.036 seconds
Model Configs
- T-Rex 450 SE V2 with RX601
