Help setting up a 450
- ffvamp69
Nevermind.
So you want this simple config to program:
ffvamp69 wrote: REVERSE:
Ruder----REV
Pitch----REV
Rest all in NORM
TRAVEL AJUST:
All in 100%
SUB TRIM:
Elev/ +26,5%
Aile/ +8%
Throt/ 0%
Rudd/ 0%
Gyro/ 0%
Pitch/ -7,5%
DUAL RATE:
Elev----60%/60%
Aile----60%/60%
Rudd----100%/100%
THROTTLE HOLD:
Active -20
THROTTLE CURVE:
L----0%
1----INH
2----80%
M----80%
3----80%
4----80%
H----80%
MIX TO THROTTLE:
Todos a 0%
GYRO SENSOR:
swich----Gear/sw
0----60%
1----40%
SWASH MIX:
Aile---- +100%
Elev---- +100%
Pith---- +70%
PITCH CURVE:
L: -20%
1: INV
2: INV
M: +40%
3: INV
4:INV
H: +100%
Is it an already working config? Because it doesn't look to be complete, for example there are no different flight modes at all...
There are some information missing, for example what swash type do you have? Is that really a flybarred heli?
Which switch do you want to use for throttle hold?
Anyway here is my first attempt attached...
You should first try it with the blades removed.
Fine tune the subtrims, and later probably the gyro values on channel 7...
Links:
- Doc: see here
- good descripton for mixer: comes from Hexperience
BTW: Cannot open the zip file (results in an error).
Edit: there is every time somebody faster than me...
rbe2012 wrote: Edit: there is every time somebody faster than me...
Actually he asked me in PM to do that for him, so it wasn't a fair play...
- ffvamp69
The helicopter is a 6 channel normal NO Flybarless.No flight modes that do not use them, just do stationary.
I had the same setup for fMode 0, fMode 2 fMode 2 to avoid problems of mistake.
thank you for the help you are giving me.
Missing data:
SWASH TYPE: 120
THROTTLE HOLD is in GEAR switch
The receiver is a devo 802:
ELEV
rear cyclic
AILE
cyclic right front
THRO
ESC
RUDD
GEAR
AUX1
Pitch,cyclic left front
I put a photo of the helicopter.
Thanks again for the assistance
It has no sense to apply the throttle hold to the same switch.
I've set up the thottle hold to the RUD DR switch, and the swash type to 120 (bingo
- ffvamp69
- domcars0
For me , your swashmix values are totally crazy (100%,100%,70%)
That's why you have AIL/ELE DR/exp very low values (60%/60%, 60%/60%)
I think that you have to lower the swashmix AIL/ELE values (for example to 50%)
and then turn up (slowly) the DR/Exp (for exemple 70%/40%)...
But it's very difficult (impossible in fact) to well setup an heli without it in front of you.
Did you ever seen the Bob Finless Videos ?
You should take a look on the 'CPPM Setup' for a 450 FB here:
www.helifreak.com/showthread.php?s=8fad0...eac9061405df&t=11373
- ffvamp69
- ffvamp69
- domcars0
Yes (cause FDR said :" bingoffvamp69 wrote: Hello,sorry to bother you, I can install the file with the new data before missing??
- ffvamp69
- ffvamp69
In my little understanding, when the AILE and ELEV PITCH rises down, like when you move the right stick to the right the low AILE servo and pitch climbs.
Is my explanation correct?
The default is all 60%.
Are you sure, that this config was right in the original firmware?
- ffvamp69
Aile
+100%
Elev
+100%
Pitch---- +70%
what happens is that the swashplate does not move when I give gas, just move the PITCH servo
- domcars0
Yes .. you are right ... in the FDR model.ini , there is no cyclic at all !ffvamp69 wrote: what happens is that the swashplate does not move when I give gas, just move the PITCH servo
set the previous mixers (set to ch 1, 2 & 6 ) respectivly to the cyclic_ele, cyclic_ail and cyclic_col
- ffvamp69
Sorry, I forgot the CCPM part...
Here is the version 2.
- ffvamp69
What does not work is the tail of the lock, I give gear switch but the light does not stay lit gyro is blinking and by giving the tail stick the tail servo does not work.
The throttle hold working???
It should...ffvamp69 wrote: The throttle hold working???
Try increasing the gyro values:
click on the heli icon, click on the second button in the channel 7's row (Expo&DR is written on it), and change both scale values way larger, say +60% and +40%. (They were recalculated from the 0..100% scale to our -100%..+100% scale.)
Model Configs
- Help setting up a 450
