need model config for walkera v200d03
- 1heli
- Topic Author
22 Feb 2013 06:18 #6762
by 1heli
need model config for walkera v200d03 was created by 1heli
- domcars0
22 Feb 2013 09:09 - 22 Feb 2013 09:10 #6778
by domcars0
Replied by domcars0 on topic need model config for walkera v200d03
I think if you say a little "hello", there may be more answers ...
Last edit: 22 Feb 2013 09:10 by domcars0.
- Hexperience
22 Feb 2013 11:34 #6785
by Hexperience
Did you read the How-To setup Fbl helis post?
I think if you try to configure a model first then ask questions if you get stuck with a problem most people here will try to help.
Replied by Hexperience on topic need model config for walkera v200d03
1heli wrote: need model config for walkera v200d03
22 Feb 2013 11:51 #6787
Replied by rbe2012 on topic need model config for walkera v200d03
Have you read vlad's answer in your other thread? Maybe the V200d02-config will work for d03 too (don't know the differences). You can find it in the model config area (link in other thread).1heli wrote: need model config for walkera v200d03
- 1heli
- Topic Author
22 Feb 2013 16:45 #6827
by 1heli
Replied by 1heli on topic need model config for walkera v200d03
Hello i appologize i am new to helis and new to this site. i wasnt sure how this worked, it looked like other people were posting requests i posted a simular post.if there is anyone out there that can help me it would be much appreciated thank you 1heli
- 1heli
- Topic Author
22 Feb 2013 17:35 #6835
by 1heli
thank you i will give both a try
- shadow
24 Feb 2013 13:48 - 24 Feb 2013 21:26 #6947
by shadow
Replied by shadow on topic need model config for walkera v200d03
Wish I still had my v200d03 and I would send you the config file. But I can say the v200d02 will not work for the 03 so don't try it...the 02 is a 4Chanel fixed pitch and 03 is 6ch collective. The simplistic way is just disconnect the motor and bind it and move the controls and watch what channels move. Then go from there with tweaking.
Also DO NOT fly it without doing a complete check of all controls and movement in all switch settings first. Other wise it might end very bad.
Good luck
edit: I attached a basic config not sure if the channels line up and cant remember if there is a rate mode on that Heli but this should get you started
Good luck
Last edit: 24 Feb 2013 21:26 by shadow.
- 1heli
- Topic Author
25 Feb 2013 02:37 #7006
by 1heli
thanks for the config i will give it a try
- Stef
28 Mar 2013 18:00 - 28 Mar 2013 18:15 #8206
by Stef
Replied by Stef on topic need model config for walkera v200d03
Hello, your firmware deviation is very nice !
But I would like to know the procedure to parameter AVCS rudder lock function?
It does not work now.
Last edit: 28 Mar 2013 18:15 by Stef.
Time to create page: 0.037 seconds
- Home
- need model config for walkera v200d03
