Need config for 4G3 (RX2605A)
- -=Hubi-Dirk=-
- Topic Author
23 Feb 2013 19:36 #6909
by -=Hubi-Dirk=-
Need config for 4G3 (RX2605A) was created by -=Hubi-Dirk=-
i tryed the config from here: www.deviationtx.com/forum/model-configs/1206-walkera-4g3#4618
All Servos working fine, Gas and Pitch also. But unfortuantely the BL-Tail wont work, may the ESC didnt initialise. With my 2801Pro the 4G3 do his job (2801 Protokoll).
Who can help?
Thanks,
Dirk
Who can help?
Thanks,
Dirk
- dehalo
23 Feb 2013 22:30 - 23 Feb 2013 22:37 #6913
by dehalo
Replied by dehalo on topic Need config for 4G3 (RX2605A)
Same problem here: everything seems to be fine, except the tail (brushed!) tailmotor won't work.
4G3/RX2605A, deviation-devo7e-5b6a882e48b5.dfu, WK2801 protocol
Edit
SOLVED: Throttle trim needs to be all the way down on startup (sounds familiar? Same thing for WK2601/2801)
Edit
Last edit: 23 Feb 2013 22:37 by dehalo.
- -=Hubi-Dirk=-
- Topic Author
24 Feb 2013 06:31 #6923
by -=Hubi-Dirk=-
Replied by -=Hubi-Dirk=- on topic Need config for 4G3 (RX2605A)
Thanks for the hint dehalo,
trim down I had tried already, but without success. The solution was to set Subtrim to -10. The Tail starts up now.
- -=Hubi-Dirk=-
- Topic Author
24 Feb 2013 06:46 #6927
by -=Hubi-Dirk=-
To the config in the first post.
Rudd was reversed, I must set it to Normal.
- -=Hubi-Dirk=-
- Topic Author
25 Feb 2013 20:26 - 09 Mar 2013 21:16 #7049
by -=Hubi-Dirk=-
The RX2605A surprised me.
So far I use RUD DR for Safety (-100) to stop the Main und Tail. This setting will only stop the Mainmotor, the Tail wont stop.
In addition, also the Safety of the Rudder has to be enabled and set to the value of +100.
Once the config for the 4G3 running well, will I upload it here.
Last edit: 09 Mar 2013 21:16 by -=Hubi-Dirk=-.
- -=Hubi-Dirk=-
- Topic Author
09 Mar 2013 21:16 #7567
by -=Hubi-Dirk=-
As promised the config.
WK2801 Protocol, 8 channels.
Tail Gyro = Mix Switch
Throttle Hold = Rudd DR Switch.
Have fun
Have fun
Time to create page: 0.038 seconds
- Home
- Need config for 4G3 (RX2605A)
