Parkzone Ultra Micro T-28 Trojan
- sbstnp
- Topic Author
23 Mar 2013 13:17 - 23 Mar 2013 13:19 #8012
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
FrSky Taranis + TBS Crossfire
Parkzone Ultra Micro T-28 Trojan was created by sbstnp
At the request of someone here the .ini file for the UM T-28 Trojan.
Settings:
Protocol: DSMX
THR trim all the way down (-110)
GEAR1 - throttle cut, value -110
1. ELE 65%, 100%, EXPO 15%
MIX THR -> ELE, 3 point 0-8-18 to prevent pitch up on full THR
2. AIL 65%, 100%, EXPO 15%
3. RUD 100% 1-to-1 (rudder is weak on this one)
Timers:
1. Countdown 6:00, CH1 (THR)
2. Countdown 4:30, CH1 (THR)
4. Permanent, CH1 (THR)
Important note:
If you have an older version with AR6400 instead of AR6410, you will need to change protocol to DSM2.
Settings:
Protocol: DSMX
Timers:
Important note:
Devo 10 + 4in1
Last edit: 23 Mar 2013 13:19 by sbstnp.
- EVERNIN
25 Apr 2013 00:27 #9181
by EVERNIN
Replied by EVERNIN on topic Parkzone Ultra Micro T-28 Trojan
would this setup work for a umx beast as3x?? Thanks.
- sbstnp
- Topic Author
25 Apr 2013 04:31 - 25 Apr 2013 04:31 #9186
by sbstnp
Devo 10 + 4in1
Spektrum Dx9
Replied by sbstnp on topic Parkzone Ultra Micro T-28 Trojan
Probably. Load it up and bench test it. You will probably have to change D/R and EXPO settings but everything else is straightforward.
Devo 10 + 4in1
Last edit: 25 Apr 2013 04:31 by sbstnp.
- EVERNIN
25 Apr 2013 16:52 #9206
by EVERNIN
OK, I will try. Thank you.
Time to create page: 0.030 seconds
- Home
- Parkzone Ultra Micro T-28 Trojan
