Walkera CP Helicopters - Beginner Settings
06 Apr 2013 22:12 - 30 Apr 2014 14:43 #8658 by Tom Z
UPDATE:
I corrected the switch icon issue that RandMental posted about below this post.
The models have been updated and the switch icon assignments are now correct
for the models that had the problem.
This model will work on the following helicopters.
  • Walkera V120D02S
  • Walkera V120D02S V2
  • Walkera Mini CP
  • Walkera Super CP
  • Walkera Genius CP V1/V2
  • Walkera V100D08
*If you are using the V120D02S, V120D02S V2, Genius CP V1 with the WK-2801 Pro compatible Receiver change Protocol=DEVO to Protocol=WK2801.
Model 7 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 7-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 7 instead.
Model 15 is for deviation firmware v3 and the Devo 8/8S/12.
Model 7v3 is for deviation firmware v3 and the Devo 10.
See my post here for the Devo 6S model.
http://www.deviationtx.com/forum/model-configs/1665-walkera-cp-helicopters-beginner-settings?start=20#8861
I have test flown this model using deviation firmware v2.1, v3, v4 in my Devo 10.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
  • No negative pitch for normal mode so you don’t slam the heli down if you pull the stick down to fast.
  • Don’t fly outside in wind in normal mode. You won’t be able to pull the heli down if the wind takes the heli.
    If you fly outside in wind use ST- 1 or ST- 2 which have full pitch curves which can pull the heli down in wind.
  • Lower Pitch Travel Adjustment to make the heli more tame.
  • Low dual rates and positive expo to tame the heli down.
  • Throttle hold on the RUDD D/R switch.
  • 7 Point Throttle and Pitch Curves.
  • TX Power=100mW
  • Channels=7
  • Protocol=DEVO
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Throttle Curve
Normal Mode: Linear Curve
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: No negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Last edit: 30 Apr 2014 14:43 by Tom Z.
07 Apr 2013 19:44 #8709 by RandMental
Replied by RandMental on topic Walkera CP Helicopters - Beginner Settings
Hi Tom
Please have a look at these changes to the Models file to correctly display the Switch status icons the 3 x D/R and Gear switches. The changes are in red:
[gui-qvga]
trim=4in
barsize=half
box1=Timer1
box2=Timer2
box3=Ch3
bar1=Ch1
bar2=Ch2
bar3=Ch3
bar4=Ch4
toggle1=ELE DR
tglico1=2
toggle2=AIL DR
tglico2=1
toggle3=RUD DR
tglico3=3
toggle4=GEAR
tglico4=4
07 Apr 2013 20:18 - 07 Apr 2013 21:09 #8715 by Tom Z
Replied by Tom Z on topic Walkera CP Helicopters - Beginner Settings
What Tx are you using?
I made and tested the model for the Devo 10 but it sounds like there is an icon display issue with another Tx model?
If I just need to open the file and change what you have in red I can try it if you can test it for me.
Also what version deviation firmware are you using?
Last edit: 07 Apr 2013 21:09 by Tom Z.
07 Apr 2013 20:32 - 07 Apr 2013 20:36 #8717 by RandMental
Tom Z wrote: Hi,
Hi Tom, sorry for not furnishing the necessary info...
I am using a Devo8s and tested these changes suggested on both Devo8s and the Devo8 emulator. Firmware is the latest 3.00 source, built from bitbucket for the Devo8, but is should be the same as the V3.00 release in this regard. Protocol is Devo, 8 channel.
Last edit: 07 Apr 2013 20:36 by RandMental.
07 Apr 2013 21:48 - 08 Apr 2013 14:02 #8719 by Tom Z
Replied by Tom Z on topic Deleted
Thanks for letting me know about the icons and testing the file.
Here is a screen shot of my Devo 8 emulator v2 without the changes made you have in red, my original model posted. The icons are working correctly.
Last edit: 08 Apr 2013 14:02 by Tom Z.
08 Apr 2013 09:59 - 08 Apr 2013 10:04 #8743 by RandMental
Replied by RandMental on topic Screen samples with model14.ini
Hi Tom
Strange - using Emu_devo8 V3.0.0 and your Model14.ini file, I get the following:
1) When enabling ELE and RUD DR's, they enable incorrect icons.
2) Gear enables the F icon correctly
3) AIL Dr does not enable any icon.
All D/R off
Now with just AIL DR on, there is no Icon
Now with just RUD DR on, there is an ELE Icon
etc.
Last edit: 08 Apr 2013 10:04 by RandMental.
08 Apr 2013 13:35 - 08 Apr 2013 13:39 #8750 by Tom Z
Replied by Tom Z on topic Walkera Models
I just tried the Devo 8 emulator v3 and the icons do not work correctly
with the model I first posted but they work correctly in the Devo 8 emulator v2.
I made the changes you have in red to my file and now the icons do not work correctly with the Devo 8 emulator v2 but they work correctly with the Devo 8 emulator v3.
Is this a bug then? There is a problem with the icons displaying correctly in V2 and V3 using the same settings file.
What should I do? I would like to post the model again for people but need to figure out this issue first.
Thanks again for your help on this issue.
Last edit: 08 Apr 2013 13:39 by Tom Z.
08 Apr 2013 14:13 - 08 Apr 2013 14:21 #8752 by RandMental
Replied by RandMental on topic Walkera Models
Hi Tom
PB has since corrected his (model template) source file for a V3 build, so I guess it is because of changes between V2 and V3 modelx.ini formats.
bitbucket.org/PhracturedBlue/deviation/i...elsxini-files-devo8s
Last edit: 08 Apr 2013 14:21 by RandMental.
08 Apr 2013 14:41 #8754 by Tom Z
If I understand correctly this is a bug that has been fixed?
Can I re-post my model again, the first version of it, or do I need to post the modified version of it with the changes you listed in red?
And does this now mean I have to make models in both V2 and V3 emulators
for people to use in there Tx using the V2.1 and V3 firmware?
Sounds like one model will not work for both versions of the firmware.
Thanks.
08 Apr 2013 15:35 #8755 by PhracturedBlue
Replied by PhracturedBlue on topic Walkera CP Helicopters - Beginner Settings
I'll look at it, it appears we may have unintentionally broken compatibility between 2->3. If that is the case, we may be stuck since I can't revert back the behavior now that 3.0 is out. Generally I don't have the resources to support v2 and v3 concurrently, so I certainly recommend folks just move to 3.0.. I understand it hasn't been tested as thoroughly though and that some folks will decide to keep v2 for a while longer.
08 Apr 2013 20:05 #8757 by holywest
Replied by holywest on topic Walkera CP Helicopters - Beginner Settings
I tried the way to insert the [gui-qvga] section in a modelx.ini created in emu V2 to use it in V3. When I use the icon for gyro and the icon for DR the program breaks down.
Is there any way to use model files createt in V2 in V3? What kind of modifications will I have to do in the ini-files?
Thanks a lot for support!
Btw: the V3 emu quits when I try to change the advanced GUI to standard GUI in the model settings. This effect does not depend on the model.ini. It´s the same effect when I use a model.ini fresh from the downloadarea.
08 Apr 2013 20:38 #8758 by Tom Z
holywest,
I took the model I created in the V2 emulator and changed the values that are in red posted by RandMental. I then opened up the model in the V3 emulator and the icons all work correctly.
So you should be able to make a model in the V2 emulator and make the changes
posted in red and you will have a fully working model to use in V3.
Did your gyro icon break down in the emulator or in your transmitter?
I now have V2 and V3 of the model ready to to post.
I test flew both versions and they work great.
I only have a Devo 10 so I can't see if the icons work correctly in the Tx
but they work correctly in the emulators.
08 Apr 2013 20:43 #8760 by Tom Z
PhracturedBlue wrote: I'll look at it, it appears we may have unintentionally broken compatibility between 2->3. If that is the case, we may be stuck since I can't revert back the behavior now that 3.0 is out. Generally I don't have the resources to support v2 and v3 concurrently, so I certainly recommend folks just move to 3.0.. I understand it hasn't been tested as thoroughly though and that some folks will decide to keep v2 for a while longer.
Thanks.
As a workaround to this issue I will make and post models for both V2.1 and V3.
08 Apr 2013 20:47 - 08 Apr 2013 20:48 #8761 by RandMental
Thanks Tom, I was was just about to confirm the same for Holywest. I have done exactly that with my V2 models.
I would just add that you should load the v2 models into the filesystem and open it in the gui. Then let the V3 firmware save the model by exiting or loading another model. This I understand writes the model in V3 format before you then update the [gui qvga] section.
Hope this make sense.
Last edit: 08 Apr 2013 20:48 by RandMental.
08 Apr 2013 21:05 #8762 by Tom Z
Your welcome.
Thanks for posting this. I will do this before I post the models.
I just opened up the V2 in windows note pad and made the changes
then opened it in the V3 emulator, did an exit and save.
Your method sounds better so the file is saved in a V3 format first before you edit it.
So open the V2 file in V3, save, then edit it.
08 Apr 2013 21:42 #8764 by holywest
I´ll try that way. But not today. It´s to late. :)
@TomZ: On my TX is the 2.1.1. I tested the 3.0 only with the emulator yet. I want to run my models in the emu correctly first. After that, I will upgrade the Devo8s.
Thanks for support!
09 Apr 2013 14:31 #8783 by Tom Z
@RandMental,
Just noticed this for the V3 model and removed it for now.
The switch letters do not display correctly in the Devo 10 Tx or V3 emulator
with the changes I made in red that you posted. The switch icons work correctly for the Devo 8 though.
Here is what the Devo 10 shows.
Rudd D/R switch shows the letter A
ELEV D/R switch shows the letter R
ALIE D/R switch shows the letters TH
Gear switch shows the letter E
What do you think about this?
09 Apr 2013 14:55 #8785 by RandMental
Hi Tom
This is in deed strange, especially that the V3 TX and Emulator seem to have different responses. I have only my Devo8s to test on tonight, my Devo7e is on loan. I'll also have a look at the V3 emulators.
FDR mentioned that in V3 all the switches (due to the 12s 3-way switches) have been given enumerated states, rather the ON/OFF states previously. This change seems to have unintended consequences on how the default icon is assigned (when not specifically listed in the models.ini file). The switch number sequence also seemed to have changed.
I'll try to map this differences out tonight and see if I can find the reason for this in the source code.
09 Apr 2013 15:24 - 09 Apr 2013 15:26 #8790 by Tom Z
I should have posted this part better so I added to it.
The switch letters do not display correctly in the Devo 10 Tx V3 or the Devo 10 emulator V3. I just did a check to see if the switch letters showed up the same or not in the Devo Tx V3 or emulator V3.
So the V3 Tx and V3 emulator have the same results which is good.
The odd thing is that the switch icons work correctly in the Devo 8 but don't work correctly in the Devo 10.
Last edit: 09 Apr 2013 15:26 by Tom Z.
09 Apr 2013 15:35 #8791 by domcars0
Replied by domcars0 on topic Walkera CP Helicopters - Beginner Settings
Model switch icons configuration is not compatible between Colors (Devo 6/8/12) and B&W (Devo 10/7e) screens TX.
This is due to the fact that there is no 'standard' for toggle.bmp other than the null (or blank) icon which MUST be the first.
Time to create page: 2.283 seconds
