Walkera Quads - Beginner Settings
- Tom Z
08 Apr 2013 23:52 - 30 Apr 2014 15:28 #8765
by Tom Z
Walkera Quads - Beginner Settings was created by Tom Z
This model will work on the following quads.
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Flight Mode 1 = 6 axis mode
Flight Mode 2 = 3 axis mode
Flight Mode 3 = 3 axis mode
DR/EXPO
Switch Position
0- ELEV D/R = 50% EXP +30%
0- AILE D/R = 50% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 70% EXP +30%
1- AILE D/R = 70% EXP +30%
Turn up RUD Scale -/+ to 150 if you want faster piros.
Install the configuration settings file into your models folder.
Example: The file you downloaded is named model5 so change the “5? to another slot
See my video:
- Walkera QR Ladybird V1/V2
- Walkera Hoten X
- Walkera QR Infra X
- Walkera QR Spacewalker
- Walkera QR Scorpion
- Walkera QR W100/100S
- Walkera UFO MX400S
- Walkera QR X400
Model 12 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 20 is for deviation firmware v2.1 and the Devo 8/8S/12.
Model 21 is for deviation firmware v3 and the Devo 8/8S/12.
Model 17 is for deviation firmware v2.1 and the Devo 10.
Model 18 is for deviation firmware v3 and the Devo 10.
I have test flown this model using deviation firmware v2.1, v3, v4 in my Devo 10.
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
- Throttle Hold is active on RUDD D/R switch.
DR/EXPO
Switch Position
Switch Position
See my video:
Last edit: 30 Apr 2014 15:28 by Tom Z.
- Lachemou
17 Feb 2015 21:42 #28759
by Lachemou
Replied by Lachemou on topic Walkera Quads - Beginner Settings
Hello i have a devo 7e and a W100S.
I don t find the file for my transmitter can i use an other ?
Time to create page: 0.801 seconds
Model Configs
- Walkera Quads - Beginner Settings
