Walkera Quads - Standard Settings
10 Apr 2013 03:11 - 30 Apr 2014 15:28 #8817 by Tom Z
Walkera Quads - Standard Settings was created by Tom Z
This model will work on the following quads.
  • Walkera QR Ladybird V1/V2
  • Walkera Hoten X
  • Walkera QR Infra X
  • Walkera QR Spacewalker
  • Walkera QR Scorpion
  • Walkera QR W100/100S
  • Walkera UFO MX400S
  • Walkera QR X400
  • Model 13 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Model 11 is for deviation firmware v3 and the Devo 8/8S/12.
    Model 24 is for deviation firmware v3 and the Devo 10.
    I have test flown this model using deviation firmware v2.1, v3, v4 in my Devo 10.
Fixed ID
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver
with the Bind Plug then assign any Fixed ID that you want to use.
  • TX Power=100mW
  • Channels=7
  • Protocol=DEVO
  • No Fixed ID
  • Throttle Hold is active on RUDD D/R switch.
  • RUD Scale is set to 150 for faster piros.
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
Flight Mode selects 3 axis mode and 6 axis mode.
Flight Mode 1 = 6 axis mode
Flight Mode 2 = 3 axis mode
Flight Mode 3 = 3 axis mode
DR/EXPO
Switch Position
0- ELEV D/R = 80% EXP +30%
0- AILE D/R = 80% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Turn up RUD Scale -/+ to 150 if you want faster piros.
Install the configuration settings file into your models folder.
Example: The file you downloaded is named model5 so change the “5? to another slot
See my video:
Last edit: 30 Apr 2014 15:28 by Tom Z.
28 Mar 2014 20:18 #21916 by Scav
Replied by Scav on topic Walkera Quads - Standard Settings
Hi Tom, many thanks for your Templates, helped me a lot to get my Hoten X and Super CP in the Air, without any knowledge about howto configure the TX :)
Are they any plans to create also Model Files for the 7E with 2x3 Switch Mod?
I tried to do it on my own, but i failed. So i just asking if they are any plans, cause with the Switchmod we got 4 Addtional Channels for the 7E.
Best Regards
Sascha
29 Mar 2014 15:22 #21934 by Tom Z
Replied by Tom Z on topic Walkera Quads - Standard Settings
Hi Sascha,
Your welcome.
I don't have the Devo 7e with or without the 2x3 Switch Mod so I can't make a model for it.
I often make or customize models for people here or make or customize transmitter setup guides for people on my web site.
I will see if I can find out what needs to be changed in my model file for the 2x3 Switch Mod. If I can find out I will make the changes and post the model for you here.
If you know of any models on this web site for the 2x3 Switch Mod post a link for me and I will take a look at it.
30 Mar 2014 17:18 #21958 by Scav
Hi Tom,
thanks for your quick response. I really appreciate your help.
Unfortunatly i can't find a Ready to Work Model Config with additional Switches, cause the 2x3 Mod is relative new, because PB added it to the latest nightly code one month ago.
Maybe i can help otherwise, and create Screenshots with Switch Positions and how it looks in the Channel Emulator?
01 Apr 2014 04:02 - 01 Apr 2014 04:07 #21989 by Tom Z
Hi Sascha,
Your welcome.
I download the Devo 7e file system and Devo 7e emulator from the nightly builds.
I see the extra switches on the right side.
I tried to modify one of my models and assign the extra switches but no luck...
I tried models I made for both the Standard and Advanced mixer.
One of the Tech guys on this site will need to tell us how to assign the extra switches. Once we know this then you can make models and I can modify my models for the extra switches if needed.
Last edit: 01 Apr 2014 04:07 by Tom Z.
01 Apr 2014 19:58 #22010 by FDR
Replied by FDR on topic Walkera Quads - Standard Settings
You should add this line in your hardware.ini file:
extra-switches=3x2
07 Apr 2014 10:15 #22196 by Scav
Hi Tom,
does FDR's Solution worked for you?
Best Regards
Sascha
07 Apr 2014 21:34 - 07 Apr 2014 21:48 #22212 by Tom Z
Hi Sascha ,
I tried what FDR posted and still no luck...
Here is my Hardware.ini file:
;enable-haptic=1
;switch_types: 3x2, 3x1, 2x2
;extra-switches=3x2
[modules]
; enable-cyrf6936 = B12
; has_pa-cyrf6936 = 1
; enable-a7105 = A13
; has_pa-a7105 = 1
; enable-cc2500 = A14
; has_pa-cc2500 = 1
; enable-nrf24l01 = A14
; has_pa-nrf24l01 = 1
; enable-multimod = A13
I assume the extra switches will be named as the following in the selectable
switch assignment options.
SW A0
SW A1
SW A2
SW B0
SW B1
SW B2
Example: Hold1, FMOD0, CH1, Virt1, PPM1, SW A0, SW B0
Last edit: 07 Apr 2014 21:48 by Tom Z.
07 Apr 2014 21:42 - 07 Apr 2014 21:44 #22213 by stringrazor
Replied by stringrazor on topic Walkera Quads - Standard Settings
The ";" is the comment character. All lines beginning with ";" are ignored. If that's exactly how your ini file looks, you need to edit it and remove the semicolon where appropriate.
Last edit: 07 Apr 2014 21:44 by stringrazor.
07 Apr 2014 21:55 #22214 by Tom Z
That worked, thanks!!!
I did a copy and paste above of my Hardware.ini file.
I removed the ";" on the line for extra-switches=3x2 and now
the extra switches show up as options to assign.
07 Apr 2014 21:58 - 07 Apr 2014 22:04 #22216 by stringrazor
Great! I was almost embarrassed to mention it... :D
I did the switch mode too but can't get the switch to register anywhere. I'm fairly sure I don't have a wiring fault (though the on-hand diode I used was large enough to be overkill) but I guess I'll have to go back in.
Last edit: 07 Apr 2014 22:04 by stringrazor.
07 Apr 2014 23:13 - 08 Apr 2014 14:48 #22221 by Tom Z
Last edit: 08 Apr 2014 14:48 by Tom Z.
08 Apr 2014 09:24 #22240 by Scav
Hi Tom,
I already modified my Hardware.ini and all Switches show up and working in Channel Monitor, but i don't know howto assign them to your functions for the extra Switches of the Devo10, this is why I'm asking for a Devo7E Build with extra Switches Model config.
They are also a lot of other Devo7E users which did the SwitchMod including PB:
www.deviationtx.com/forum/how-to/1436-ad...he-devo-7e?start=100
sorry for the inconvenience.
Best Regards
Sascha
07 May 2014 07:25 - 07 May 2014 07:27 #22962 by Scav
Hi Tom,
i was able to apply the additional Switches from the Devo10 to the soldered Switches from the 7E.
Some Questions are open and i hope you can help me out here.
I can switch the Flight Modes with the FMod Switch. Unfortunately the Devo7e has only a FMod0 and FMod1, in Channel Emulator of the Devo10 i can't see any difference between FMod1 and 2 with your Settings, and also on your Describtion here is only shown that one Mode is 6 Axis and the other two's are 3 Axis.
Also i found following:
What is the M1? I flyed with the 3 Modes but also doesnt found any difference, maybe the Quad turns faster?
One last question, how to perform Flips with your Build? I tried some Switches and Flightmodes but my Hoten-X doesnt performed a single Flip.
Thanks in advance for your response.
Best Regards
Sascha
Last edit: 07 May 2014 07:27 by Scav.
08 May 2014 16:25 - 08 May 2014 23:33 #23019 by Tom Z
Hi Sascha,
There is only 6 Axis mode and 3 Axis mode. The FMOD switch has three positions so I choose to assign 3 Axis mode two times.
I could have assigned 6 axis mode two times instead if I wanted to.
Flight Mode 2 = 6 axis mode
You can assign the 3/6 axis modes any way you like.
Some examples.
Flight Mode 1 = 3 axis mode
Flight Mode 3 = 6 axis mode
6 Axis mode and 3 Axis mode is switched by the gyro amount (scalar=) setting.
scalar=-34 will give you 6 axis mode
scalar=66 will give you 3 axis mode
[channel7]
template=expo_dr
[mixer]
src=Ch7
dest=Ch7
scalar=-34
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=66
usetrim=0
curvetype=fixed
You are good with your Devo 7e and FMod0 and FMod1. This will toggle between 6 Axis mode and 3 Axis mode as long as you have scalar=-34 on one FMOD position and scalar=66 on one FMOD position.
The "M1" icon should be "Mixer Switch Position" but the factory Devo 7e doesn't have a mixer switch.
To flip the quad you "must" be in 3 Axis mode.
For the fastest/tightest flips use full Dual Rates: D/R = 100% to 125%
Here are my first attempts to flip my smallest quad.
I need to be up much higher so I can figure out how to catch it after the flip.
Last edit: 08 May 2014 23:33 by Tom Z.
31 May 2014 21:56 - 01 Jun 2014 00:56 #23795 by Torch
Replied by Torch on topic LadyBird V2 stuck on Flip mode
Deviation v4 with Devo 7E LadyBird V2 only binds and stays in Flip mode (Green lights). How do I setup Flight Mode switch to enable and turn off Flip mode?
Where do I copy this?
;enable-haptic=1
extra-switches=3x2
[modules]
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
Last edit: 01 Jun 2014 00:56 by Torch.
01 Jun 2014 01:37 - 01 Jun 2014 01:38 #23801 by Torch
Cut and Paste using NotePad ++ to model30.ini but still don't see options to set the flight mode? Or do I need to copy it to hardware.ini? I don't see hardware.ini?
[channel7]
template=expo_dr
[mixer]
src=Ch7
dest=Ch7
scalar=-34
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
usetrim=0
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE2
scalar=66
usetrim=0
curvetype=fixed
Last edit: 01 Jun 2014 01:38 by Torch.
02 Jun 2014 02:40 - 02 Jun 2014 15:50 #23838 by Tom Z
Replied by Tom Z on topic LadyBird V2 stuck on Flip mode
Torch wrote: Deviation v4 with Devo 7E LadyBird V2 only binds and stays in Flip mode (Green lights). How do I setup Flight Mode switch to enable and turn off Flip mode?
;enable-haptic=1
extra-switches=3x2
[modules]
; has_pa-a7105 = 1
; has_pa-cc2500 = 1
That is a Hardware.ini file for the Devo 7E with the switch mod.
You don't have the switch mod so that doesn't apply to your transmitter. Ignore that file.
Last edit: 02 Jun 2014 15:50 by Tom Z.
02 Jun 2014 03:06 - 02 Jun 2014 03:49 #23839 by Tom Z
Both modes should be working for your Devo 7E if you used my model.
Flight Mode 0 = 6 axis mode (Normal Mode)
Flight Mode 1 = 3 axis mode (3D/Flip Mode)
Normal/3D modes are controlled on Channel 7 by the Scalar Value.
-34 / 66
The Devo 7E only has FMOD 0 and FMOD 1 so it should use this setup below.
This is in the model.ini file.
[channel7]
template=complex
[mixer]
src=Ch7
dest=Ch7
scalar=-34
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
[mixer]
src=Ch7
dest=Ch7
switch=FMODE1
scalar=66
curvetype=fixed
If you need more help see if one of the tech guys can help you out as I don't know what else to have you check.
Last edit: 02 Jun 2014 03:49 by Tom Z.
02 Jun 2014 03:10 #23842 by Torch
Replied by Torch on topic Walkera Quads - Standard Settings
Tanks Tom but i didnt do switch mod so i cant use this. Will have to fly my ladybird in 3D mode only.
Time to create page: 1.517 seconds
