Walkera Master CP - 3D Settings
- Tom Z
10 Apr 2013 16:26 - 30 Apr 2014 15:15 #8830
by Tom Z
Walkera Master CP - 3D Settings was created by Tom Z
Buildem336 (Manuel) 3D settings
Here is a video of the stock Master CP flying with the settings below. He is not using the deviation firmware but I converted the settings over for the deviation firmware.
Walkera Master cp 3d flight
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Throttle Curve
Normal: -100, -33, 33, 100, 100, 100, 100
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: About -1.5* negative pitch. Zero degrees pitch at mid stick.
Gyro Gain
64% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 82% gyro gain.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP LIN
0- AILE D/R = 100% EXP LIN
RUDD D/R = 100% EXP EXP -6%
Switch Position
1- ELEV D/R = 100% EXP LIN
1- AILE D/R = 100% EXP LIN
Install the configuration settings file into your models folder.
Example: The file you downloaded is named model5 so change the “5? to another slot
See my video:
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
- Throttle Hold is active on RUDD D/R switch.
- Travel Adjustment: Pitch = 54%
- Pitch Travel has been set so that there is no bogging of the motor.
- 7 Point Throttle and Pitch Curves.
Model 9 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 9-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 9 instead.
Model 2 is for deviation firmware v3 and the Devo 8/8S/12.
Model 28 is for deviation firmware v3 and the Devo 10.
See the post below this for the Devo 6S Model.
I have test flown this model in the Devo 10 transmitter.
Throttle Curve
Pitch Curve
Gyro Gain
DR/EXPO
Switch Position
Switch Position
See my video:
Last edit: 30 Apr 2014 15:15 by Tom Z.
- Tom Z
12 Apr 2013 22:06 - 19 Jan 2014 06:26 #8908
by Tom Z
Replied by Tom Z on topic Walkera Master CP - 3D Settings
This model is for the Devo 6S only.
1. 7 Point Throttle and Pitch Curves.
2. TX Power=100mW
3. Channels=7
4. Protocol=DEVO
5. No Fixed ID
6. Mode 2
7. Travel Adjustment: Pitch = 54%
8. Pitch Travel has been set so that there is no bogging of the motor.
9. FMOD switch - for stunt modes
10. DR switch - for aile & ele dual rates
11. Gear switch - for throttle hold, Position 1 is held
12. MIX switch - is free to use for what you want
This model is for deviation firmware v3.
This is no height changes switching between flight modes.
Throttle Curve
Normal Mode: -100,-33,33,100,100,100,100
ST- 1: 100% Flat Across
ST- 2: 100% Flat Across
Pitch Curve
Normal Mode: About -1.5* negative pitch. Zero degrees pitch at mid stick.
ST- 1: Full +/- 3D pitch curve. Zero degrees pitch at mid stick.
ST- 2: Full +/- 3D pitch curve. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
Switch Position
Thanks JJ1984 for testing the model for me on on your Devo 6S and taking the time to customize it for us.
2. TX Power=100mW
3. Channels=7
4. Protocol=DEVO
5. No Fixed ID
6. Mode 2
Throttle Curve
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 19 Jan 2014 06:26 by Tom Z.
- LAVITAL
03 Jun 2015 18:52 - 03 Jun 2015 18:58 #33400
by LAVITAL
Replied by LAVITAL on topic Walkera Master CP - 3D Settings
hi,
I need the settings for DEVO 7 . is it possible ? ( I'm french so, my english can have some errors in my speaking_)
In throotle curve, I have not the numbers negative ( -100; -33 ) I have P-L = 0.0 , P-1, P-2, P-M = 50.0, P-3, P-4, P-H = 100.
For ST-1 and 2 too.
PS: I'm between beginner and 3D XD.
For ST-1 and 2 too.
Last edit: 03 Jun 2015 18:58 by LAVITAL.
- olongapso
04 Sep 2015 09:32 #37431
by olongapso
Replied by olongapso on topic Walkera Master CP - 3D Settings
amazing video and pilot skills.
thanks for conversion, this night I will update this model into my radio and tomorrow I will try immediately this kind of setting.
Luca
Luca
Time to create page: 0.491 seconds
Model Configs
- Walkera Master CP - 3D Settings
