Blade 130 X - Standard Settings
- Tom Z
17 Apr 2013 16:34 - 15 Feb 2014 23:33 #9006
by Tom Z
Blade 130 X - Standard Settings was created by Tom Z
UPDATE: 5/13/13
I have updated all the models which have the same name as before.
* Notice of Ch 3 being 0 not -100 has been corrected.
* DSM2 has been changed to DSMX.
Normal: 0% 40% 60% 68% 75%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal: -3* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 80% EXP +30%
0- AILE D/R = 80% EXP +30%
RUDD D/R = 80% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Model 2 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 2-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 2 instead.
Model 51 is for deviation firmware v3 and the Devo 8/8S/12.
Model 52 is for deviation firmware v3 and the Devo 10.
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:33 by Tom Z.
- RoJAck
05 May 2013 02:55 #9574
by RoJAck
Replied by RoJAck on topic Blade 130 X - Standard Settings
Nice, thanks! ... can't wait to try it out!
- ave1
11 May 2013 17:49 #9864
by ave1
Replied by ave1 on topic Blade 130 X - Standard Settings
Thank you for offering so much help here, and on your web site. I know it takes much of your time.
So, I'm Steve Gross, a newbie fighting to come to speed. I working w a 12S. I installed V3.
When I loaded your Model 51 (name changed to 7 for my TX model slot) I consistently get a notice of Ch 3 being 0 not -100.
I looked at the code and could find nowhere to change this. Not sure how to proceed. Also, I have 30 model slots. How do we use more, if necessary.
Finally, why did u bind DSM2 and not DSMX?
wondering if you might clarify and/or advise.
TY
TY
- Scream
11 May 2013 19:23 #9870
by Scream
Cheers!
-=S=-
Replied by Scream on topic Blade 130 X - Standard Settings
Hiya!
I've been having the same exact problem!
And of all channels... who cares about channel 3 anyhow!
I cant figure it out either, if anybody knows how to rid this symptom from an otherwise enjoyable config please share!
Cheers,
-=S=-
Cheers,
-=S=-
Cheers!
-=S=-
11 May 2013 19:26 - 11 May 2013 19:27 #9871
Replied by FDR on topic Blade 130 X - Standard Settings
For DSM2/DSMX replace the folowing text in your model.ini file:
...with this:
Use a text editor like notepad++, because the Windows notepad doesn't handle the unix style line ends well...
[safety]
Ch3=min...with this:
[safety]
Ch1=minUse a text editor like notepad++, because the Windows notepad doesn't handle the unix style line ends well...
Last edit: 11 May 2013 19:27 by FDR.
- ave1
11 May 2013 20:29 #9872
by ave1
Thank you.
I continue to be amazed and inspired by the sharing and enthusiasm shown to me and others. Great patience consistently shown to those such as me, such a newbie, trying hard to "catch-up". Learn.
The work thus far is spectacular, I am flying 80% of all my models with a very nicely built 12S Walkera. 1 TX.
Thank you all, once again. I wait so impatiently and watch email alerts for the Version that fills the entire screen of my 12S and other enhancements as I must never forget that even as it is now, it is 100% better than when the 12S first arrived w Walkera default firmware inside.
Best to all, thanks to all.
Steve
Steve
11 May 2013 20:50 #9876
Even better will be "auto=min" because it will select the usual throttle channel for the selected protocol.
Replied by rbe2012 on topic Blade 130 X - Standard Settings
FDR wrote: ...with this:
[safety] Ch1=min
11 May 2013 20:54 #9877
Yep, indeed.
I replied without looking into an actual ini file...
- Tom Z
13 May 2013 16:19 - 13 May 2013 16:49 #9926
by Tom Z
Your welcome Steve.
I used DSM2 as this is what I have always worked with before. The models have now been changed to DSMX now that I now understand what the difference between the two are.
Download the updated models (which have the same name as before) and install.
Replied by Tom Z on topic Blade 130 X - Standard Settings
ave1 wrote: Thank you for offering so much help here, and on your web site. I know it takes much of your time.
TY
Your welcome Steve.
Last edit: 13 May 2013 16:49 by Tom Z.
- Tom Z
13 May 2013 16:20 - 13 May 2013 17:17 #9927
by Tom Z
I edited the models with the "auto=min" setting as recommended by rbe2012. I did this with notepad++ and checked the models in the simulators again.
Download the updated model and install it again.
I also changed DSM2 to DSMX.
I updated all the Blade models I have posted on this site with these changes.
Last edit: 13 May 2013 17:17 by Tom Z.
- ave1
13 May 2013 17:20 #9928
by ave1
This Deviation software is the most exciting aspect of RC since I became addicted to RC Helicopters.
In advance, I apologize to all, for my questions, as I Learn. Forgive my inexperience.
I would love to contribute (in any way needed) to this awesome project, if allowed. Yesterday, I and my 12S w deviation V3 flew models from 3 binding sources, never before possible. I really enjoy my 12S, also. Stick feel is good for me.
Tom, you have a great site and the time you have invested is apparent and, much appreciated, also.
Thanks to all the players,
Steve
Steve
- Tom Z
13 May 2013 17:35 #9931
by Tom Z
Thanks Steve.
I missed your question before. "30 model slots. How do we use more, if necessary".
I think you just continue to name them as you do with the models under 30.
I just tried it in the deviation simulator and it worked so it should also work in the transmitter.
Example: model #31 would be named model31.ini
model #32 would be named model32.ini
13 May 2013 18:27 - 13 May 2013 18:27 #9934
Yep, that's the way. Make sure to number the files continuously because when you have a gap the method will stop looking for further files.
Last edit: 13 May 2013 18:27 by rbe2012.
- Scream
15 May 2013 19:17 #10037
by Scream
Cheers!
-=S=-
Works great, plus I just learned we can add more than 30 models
Thanks guys!
Cheers,
-=S=-
Thanks guys!
Cheers,
-=S=-
Cheers!
-=S=-
- leest
05 Sep 2013 09:34 #13553
by leest
Replied by leest on topic Blade 130 X - Standard Settings
Tom, need your help!
I had set up my 130x with the template you posted. It flied great. But after i upgrade the tail with DS35 servo, i can't manage to adjust the travel range and gyro gain with your templete. Need help in how to:
- adjusting the tail servo travel
- adjusting the tail servo gain
- adjusting the main rotor gyro gain as i changed to other lighter blade it seem the gain is too low/high and it keep on vibrating.
I did tried to use the strandard gui, and all the servo travel can be adjusted then,but i can't figured out how to adjust the main rotor gain and tail servo gain. Please understand that you are my only hope as i posted this question in the general disccusion but to no avail.
TQ
TQ
- Tom Z
11 Sep 2013 04:39 #13694
by Tom Z
TQ, I don't use the deviation firmware. I installed it to make the How to videos and make models to post on this site then returned to the factory firmware.
Without having the deviation firmware installed I can't help you out.
Someone should be able to help you out here when they see your post.
- ave1
11 Sep 2013 04:54 #13695
by ave1
jumping in here, are you saying that if you bind to a new memory, you can't control your servo travel/gain? because of a template stops that adjustment?
- Diaz
- Keep flying!
09 Nov 2013 03:22 #15452
by Diaz
Erik
Replied by Diaz on topic Blade 130 X - Standard Settings
how do you load these files into the radio? there just scripts of the setings when i open them up ? thanks in advance ... erik
Erik
09 Nov 2013 08:05 #15458
Have you already read the manual? If not, plese do so.
In short: connect your tx to your pc, go into USB mode and look at the file system. Put the config files in the "models" folder (rename them model1.ini to model30.ini - search a number you did not used for the models already in your tx).
- Scott Bishop
07 Jan 2014 22:26 - 07 Jan 2014 22:27 #18162
by Scott Bishop
Replied by Scott Bishop on topic Blade 130 X - Standard Settings
Will the 130x Devo10 config work on the 7e fw deviation 4.01 ?
Last edit: 07 Jan 2014 22:27 by Scott Bishop.
Time to create page: 0.787 seconds
Model Configs
- Blade 130 X - Standard Settings
