V120D02S Model config for V3 Deviation
- Crash Survivor
14 Jul 2013 22:31 #12246
by Crash Survivor
V120D02S Model config for V3 Deviation was created by Crash Survivor
Does anyone have a WK2801 & Devo model config for the V120D02S with the Devo 8 I can load & work off of?
- stevecox
- Keep swinging
15 Jul 2013 04:02 #12247
by stevecox
Adelaide
Replied by stevecox on topic V120D02S Model config for V3 Deviation
I am using this, run through it to see it suits you and what switches are what
www.deviationtx.com/forum/model-configs/...-for-the-fbl100#7437
Adelaide
- Crash Survivor
15 Jul 2013 23:10 #12257
by Crash Survivor
Replied by Crash Survivor on topic V120D02S Model config for V3 Deviation
That's for a Devo 10, will that also work for a Devo 8? Haven't loaded Deviation yet, but was wanting a good base to start off of before the new learning curve. Can Deviation also start & stop your flight timer with throttle?
- stevecox
- Keep swinging
16 Jul 2013 04:23 - 16 Jul 2013 04:28 #12258
by stevecox
Adelaide
Hi, okay don't have much time but quickly, here is my live .ini version I am using on the Devo8, I think I have the rudder dual rate set for throttle kill, 3D off the Fmod switch. Ail and Ele have dual rates on their own switches. Also a logo for it
Have Fmod switch 3D off when you switch the Rud dual rates or you gonna have some swinging blades ...
Run through the settings with throttle off before first flight to be sure.
Adelaide
Last edit: 16 Jul 2013 04:28 by stevecox.
- Crash Survivor
16 Jul 2013 10:39 #12265
by Crash Survivor
Thanks, that should give me a good starting point.
- jazzjohn
04 Nov 2013 17:44 #15343
by jazzjohn
Replied by jazzjohn on topic V120D02S Model config for V3 Deviation
Here's another V120D02s config that is used on my Devo 6. Throttle hold is on the FMOD switch and the flight modes are on the MIX switch. Pitch is about +/- 12 deg and cyclic pitch is 6.5/9 on the D/R switch.
Time to create page: 0.028 seconds
Model Configs
- V120D02S Model config for V3 Deviation
