QR X350 V1.2 on Devo 8s
- fassla
01 Oct 2013 19:33 - 01 Oct 2013 19:37 #14198
by fassla
QR X350
Blade QX3 AP CGO2
Devo 8s
QR X350 V1.2 on Devo 8s was created by fassla
I received my QR X350 and started with the firmware update V1.2.
update war working fine.
But now I'm stuck with the settings on Devo 8s.
Can you please post here the setting for QR X350 >V1.2 ?
Model is "airplane" instead of heli and also the flight modes have changed.
Your already working setting will be of great help.
QR X350
Blade QX3 AP CGO2
Devo 8s
Last edit: 01 Oct 2013 19:37 by fassla.
- Fernbediener71
04 Oct 2013 17:21 #14237
by Fernbediener71
Replied by Fernbediener71 on topic QR X350 V1.2 on Devo 8s
Hi!
Here are my Devo8S (deviation V3) Settings.
I modifyed my QR X350 using the RX802 and the WK-CTL01-D Telemetry but the settings should work for the RX702.
I use the actual firmware from the Walkera homepage with the extra wire installed.
I changed the original settings, the original settings were not so fine for me:
Flightmode 0=normal
Flightmode 1=position hold
Flightmode 2=return home
AirleD/R 0=IOC off (normal)
AirleD/R 1=IOC on (Lock)
Mix is prepared for channel 8 (I changed the RX702 to an RX802) to use an servo for the "big" cam
Gear is prepared for channel 7 to use the FPV cam (but i was not able to test it, the FPV cam is still in the shop
For using failsafe (sender off) I think I will set a fixed ID to get the QRX350 back
In my test it stayed long time at the last position but did not return home.
Have fun with the QR X350! It is great!
Flightmode 0=normal
04 Oct 2013 17:29 #14238
Replied by FDR on topic QR X350 V1.2 on Devo 8s
I think your Ch5 is misconfigured, that's why the RTH didn't work.
Change the function to fixed, and the scale values to -100, 0, +100
- Fernbediener71
04 Oct 2013 17:59 #14239
by Fernbediener71
In the file the settings are -100,0,100 on the Fmode-switch.
Fmode2=RTH works fine but turning off the devo8s the QRX350 does not return home but it stays in it's position in the Sky...until the lipo gets power down...
Without fixed ID it's not possible to get it under control again.
04 Oct 2013 18:45 #14241
This is your Ch5 config:
...which uses the deadband function instead of fixed.
Also for the RTH on tx off you can set the failsafe value of the Ch5 to +100...
[channel5]
template=expo_dr
[mixer]
src=FMODE0
dest=Ch5
scalar=-100
curvetype=deadband
points=0,0
[mixer]
src=FMODE0
dest=Ch5
switch=FMODE1
scalar=0
curvetype=deadband
points=0,0
[mixer]
src=FMODE0
dest=Ch5
switch=FMODE2
curvetype=deadband
points=0,0
- Fernbediener71
04 Oct 2013 20:21 #14245
by Fernbediener71
Oh, I thougth i had set it to fixed. Thanks!
I will try it next Days!
- Fernbediener71
13 Jan 2014 20:04 #18484
by Fernbediener71
Everything works fine with this settings for me (Devo8S)
QRX350 Firmware 1.3
Fmode 0=normal,
FMode 1=Position hold
Fmode 2= Return home
Airle D/R 1=hedlock
Gear 1=Start recording (for DV04)
Telemetry is on, i put the CTL01-D inside.
QRX350 Firmware 1.3
Fmode 0=normal,
Airle D/R 1=hedlock
- magic_marty
16 Feb 2014 20:03 #20395
by magic_marty
Replied by magic_marty on topic QR X350 V1.2 on Devo 8s
What would i have to change to get this model config to work with a QRX350 with a spektrum ar6210 insted of of a walkera rx?
Time to create page: 0.036 seconds
Model Configs
- QR X350 V1.2 on Devo 8s
