Tested Standard GUI V922 WL-T6 Devo 8s combo
- BirdBarber
- Hummingbird Assassin
10 Oct 2013 11:56 - 14 Jul 2015 09:49 #14431
by BirdBarber
Tested Standard GUI V922 WL-T6 Devo 8s combo was created by BirdBarber
I have developed a Standard GUI model & icon for a WL V922 using a Devo 8s with a WL-T6 adapter. This should probably work for a HCP100 / FBL100 and HT8 as well but I have only tested it on the V922.
This model is tuned for intermediate level 2D flying.
Set the idle up throttle curves to flat or "V" before flying 3D.
Make sure the WL-T6 is in Walkera mode (left LED off).
Note that Throttle hold is on the right FMod switch for us that learned on Spektrum transmitters.
Select Idle ups using the Mix switch.
Aile D/R switches Aile & Elev.
Elev D/R switches Rudder.
Left hand throttle hold is unused (Rudd D/R switch).
Toggle box displays:
Red Box - Idle up engaged
Green Box - Throttle Hold is on
Yellow Box - Dual Rates in high mode
Last edit: 14 Jul 2015 09:49 by BirdBarber.
- thana
18 Oct 2013 15:13 #14759
by thana
Replied by thana on topic Tested Standard GUI V922 WL-T6 Devo 8s combo
Danke Danke schoen
- jacklscott3
18 Mar 2014 05:59 #21640
by jacklscott3
Replied by jacklscott3 on topic Tested Standard GUI V922 WL-T6 Devo 8s combo
Ok Im new to all of this so please bare with me, but I used your model, It's working great with my v922, however, Im not sure how to change the pitch curve for 3d flight. If i make the adjustments on my devo 7e it will not save them right? I would need open the text file and make the adjustment there..correct? also I cant remember with certainty the pitch curve for stunt mode...
is it:
100 90 80 90 100?
is it:
100 90 80 90 100?
- BirdBarber
19 Mar 2014 12:30 #21661
by BirdBarber
You should be able to save any changes you make on your transmitter. The only thing that would get rid of any changes would be if you downloaded the model file to your transmitter again. There is rarely any need to make changes to the text file on the PC.
The model already has Idle Up 1 & 2 pitch curves that should work for 3D: -100 -50 0 50 100.
You do need to set the Idle Up 1 & 2 throttle curves to be something like a flat 90 90 90 90 90 and v-curve like 100 95 90 95 100 to start with.
Replied by BirdBarber on topic Tested Standard GUI V922 WL-T6 Devo 8s combo
jacklscott3 wrote: Ok Im new to all of this so please bare with me, but I used your model, It's working great with my v922, however, Im not sure how to ...
Time to create page: 0.028 seconds
Model Configs
- Tested Standard GUI V922 WL-T6 Devo 8s combo
