Align T-Rex 150
- Kramard
07 Dec 2013 02:44 - 07 Dec 2013 02:45 #16351
by Kramard
Align T-Rex 150 was created by Kramard
Hey guys,
I don't know how, but I was able to score a T-Rex 150 at my local hobby shop today. Presume I am one of the first but was hoping someone else was planning to use their 7E with this model.
Here is Align's great set up video - I have a DSMX satellite and the 7E - do you feel that I should be able to use the settings (e.g., 11MS frame rate) and bind using my 7E?
Align DSM2 / DSMX radio setup and bind procedure
Thanks,
Dave
Thanks,
Dave
Last edit: 07 Dec 2013 02:45 by Kramard.
- WheresWaldo
07 Dec 2013 04:03 #16352
by WheresWaldo
Replied by WheresWaldo on topic Align T-Rex 150
The devo will bind to a DSMX at 11ms, that is what I am using on my TRex 500 clone with two satellites.
- Hexperience
07 Dec 2013 18:41 #16384
by Hexperience
Replied by Hexperience on topic Align T-Rex 150
I thought deviation didnt support 11ms mode. How do you know its not 22ms mode?
- WheresWaldo
07 Dec 2013 19:47 #16388
by WheresWaldo
To be honest I can't tell from the devo, but I set up the mini vBar to 11ms DSMX Satellites and it's working.
Hexperience wrote: I thought deviation didnt support 11ms mode. How do you know its not 22ms mode?
- Thomas.Heiss
29 Sep 2016 06:27 #54389
by Thomas.Heiss
Replied by Thomas.Heiss on topic Align T-Rex 150
DSMx 11ms high speed test build:
www.deviationtx.com/forum/protocol-devel...pported-or-not#54325
- Danker16
24 Nov 2017 07:34 - 24 Nov 2017 07:40 #66117
by Danker16
Replied by Danker16 on topic Align T-Rex 150
I know this is an old topic but for anyone looking for compatibility with this bird on the devo 10,
installed CC2500 module from banggood with latest vlads build, no freq tuning needed on mine for binding with S-FHSS Protocol. seems to respond better than with DSMX protocol and satellite.
all DR and TH-H operational.
im attaching my model file.
AIL and ELE DR0 50 w +30EXP, DR1 100/ LIN
Normal, idle 1 and 2 as per align manual, throttle safety at -100, and RUD1 Throttle -100 and pitch hold at 0 degrees.
the 150x GRS is nice because the deviation values match, GRS values are -100 to +100. always calibrate when you change tx settings in app and do it with throttle hold off.
Last edit: 24 Nov 2017 07:40 by Danker16.
- mtx63
25 Nov 2017 09:32 #66156
by mtx63
Replied by mtx63 on topic Align T-Rex 150
Hi Danker16,
Thanks for sharing. I fly the Trex 150 x with the DEVO 6s.
Dieter
Dieter
Time to create page: 0.105 seconds
Model Configs
- Align T-Rex 150
