V120D02s V2 beginner for DEVO 10
07 Dec 2013 16:00 - 07 Dec 2013 16:25 #16372 by hugo_fabricio
V120D02s V2 beginner for DEVO 10 was created by hugo_fabricio
someone has a setting for beginner V120D02S V2 with Debo 10
found one here in the forum but did not work and apparently not for the V120D02 V2
how to use the original configuration of Walker wanted a similar'll'm starting now ...
tanks
Last edit: 07 Dec 2013 16:25 by hugo_fabricio.
07 Dec 2013 21:36 - 07 Dec 2013 21:37 #16392 by HappyHarry
Replied by HappyHarry on topic V120D02s V2 beginner for DEVO 10
my settings for the v120d02s v2 are attached, they are for a 7e but you can get a rough idea of what to set your own at by looking at them
idle0 is -1 to +10 deg pitch with zero deg at centre stick, 0 to 95% throttle with 85% at centre stick, and the tail gain is at 75%. also the dual rates on elevator and aileron are at 80% with zero expo, this is a good basic setup but you might want to add some expo and lower the d/r level to calm it down some more
idle1 is -11 to +11 deg pitch, again zero deg at centre stick, and 100 - 90 - 100 throttle. 100% throws and no expo, this is a 3d setup so stay out of it until you feel ready :)
Last edit: 07 Dec 2013 21:37 by HappyHarry.
08 Dec 2013 01:19 #16393 by hugo_fabricio
Replied by hugo_fabricio on topic V120D02s V2 beginner for DEVO 10
thank you very much
I will use as a reference for your configuration
to the mine
I already have a starting point!
then put the result
12 Dec 2013 08:26 #16539 by ricksonchow
Replied by ricksonchow on topic V120D02s V2 beginner for DEVO 10
Thanks for the sharing. But just want to know if the ini is applicable to all firmware? Like the stock, V2.1 and V3.0 or V3.1?
  • rbe2012
  • rbe2012's Avatar
12 Dec 2013 10:52 #16540 by rbe2012
Replied by rbe2012 on topic V120D02s V2 beginner for DEVO 10
Deviation config files do never work with stock firmware (or vice versa).
This specific one is built with V3.1 or the nightlies since July or August. If you use it with V3.0 you will loose the GUI settings (you get a default page), differences to 2.1 are more (don't actually know which settings are different, but it should work except some additions which came after 2.1).
Time to create page: 1.424 seconds
