v922/fbl100-7e-140ºswash-custom layout
- HappyHarry
i have also added a version of this ini for a 7e with no switch mods, this file is called fbl100-stock7e.ini.txt
- blackmoon
I like the layout
- HappyHarry
- blackmoon
- djzinc
A7105 is not for FlySky/Hubsan?
nRF24L01 should be used for V922.
I made the A7105 mod to a DEVO 7e, with a module harvested from a V913 Tx. It is working on the V913 itstelf and on Hubsan X4 (old version - no motor LEDs).
mow I ordered a nRF24L01 module to make the mod also for my V922.
Am I wrong with something?
Tnx
- HappyHarry
- djzinc
I only used the wl-t6 adaptor to contoll V922 with DEVO 7e. Pls tell me, you are pleased how's your 7e working with nRF24L01+ module?
- HappyHarry
- hogan
- HappyHarry
- WheresWaldo
- HappyHarry
- eaman
If someone noob like me could be interested this is my config for the HCP100 / Devo 7e with no extra switch noob friendly.
It has quite a bit of EXPO (35) in normal mode as I found the v922 quite twitchy compared to my gentle SuperCP with gyro at 9 o'clock.
In IDLE1 it has less EXPO (25) and more SCALE / servo travel, enought even for me to roll the bird AND have some chances to hold the bird in inverted hovering for orientation training.
Do note that THOLD is away from you, in HOLD0, as I find that on the small Devo 7e is easier for me to hit THOLD with my thumb as i move away from throttle. Be sure to change that if that's not your thing.
So all switch AWAY FROM YOU / UP you are safe to insert the battery, when the gyro is OK check that throttle stick IS DOWN then you can take down THOLD ad get airborne.
Each time you are about to take off just be sure that every switch is away from you and throttle is down.
This should get you hovering if there's not much wind, in that case (be safe and wait for next time) consider lower the EXPO. Same thing if you fell like hovering indoor (just don't if u're noob like me): you have to lower the expo (say 10/15) as soon as you start anything harder than tail-in hovering or you just won't be able to recover and will only over-compensate to a crash by the other side.
Notes: it's based on advanced mixers so you have:
3-THR as throttle
4-RUD as rudder
CYC-AIL as Aileron (left right)
CYC-ELE as elevator (forward backward)
CYC-COL as pitch
- stringrazor
- HappyHarry
- cx12
I used the newbie ini file model22 i think it was and it has no negative pitch. I used harry file and the thing will not stop even at -100 throttle. Pulling my hair out and frustration setting in. I just want to use the basic cp setting you know -100 on the throttle stick means no power and as you move it towards center it spin at 0 pitch and throttle movement up or down controls the pitch unless you are in FMode1 or Fmode 2. I just need to know where is the crazy pitch curve channel and where is the real throttle curve channel. PLEASE HELP
- HappyHarry
- cx12
- HappyHarry
- cx12
Model Configs
- v922/fbl100-7e-140ºswash-custom layout
