Walkera FP Helicopters - Standard Settings
- Tom Z
- Topic Author
07 Jan 2014 02:50 - 30 Apr 2014 15:24 #18122
by Tom Z
Walkera FP Helicopters - Standard Settings was created by Tom Z
This model will work on the following helicopters
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Gyro gain is controlled with the MIX Switch. These are the values I used then converted them to the deviation values.
Switch Position 0: 50%
Switch Position 1: 78%
Switch Position 2: 82%
DR/EXPO
Switch Position
0- ELEV D/R = 70% EXP +30%
0- AILE D/R = 70% EXP +30%
RUDD D/R = 100% EXP LIN
Switch Position
1- ELEV D/R = 100% EXP +30%
1- AILE D/R = 100% EXP +30%
If the tail is too touchy for you add some positive expo.
Try +20%. EX: RUDD D/R = 100% EXP +20%
- Walkera Super FP
- Walkera Genius FP
- Walkera V200D01 w/Devo Receiver RX2437V-D
- Walkera V200D02 w/Devo Receiver RX2440V-D
- Protocol=DEVO
- TX Power=100mW
- No Fixed ID
- Throttle Hold is active on RUDD D/R switch.
- Mix Switch is Gyro Gain.
- 7 Point Throttle Curve.
Model 15 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
DR/EXPO
Switch Position
Switch Position
Last edit: 30 Apr 2014 15:24 by Tom Z.
- FireAngel
12 Jan 2014 16:21 #18417
by FireAngel
Replied by FireAngel on topic Walkera Super FP - Standard Settings
Hi Tom Z
Could this also be used for the Walker V200D01 Fixed Pitch heli ?
- Tom Z
- Topic Author
12 Jan 2014 16:45 #18419
by Tom Z
Replied by Tom Z on topic Walkera Super FP - Standard Settings
Hi, which transmitter are you using for the heli? The Devo transmitter or WK-2801 Pro?
- Tom Z
- Topic Author
12 Jan 2014 16:56 #18420
by Tom Z
Also can you go into the Channel Reverse Setup and tell me what each one is set to for ELEV, AIL, THRO, RUDD. Each one will be Nor or Rev.
Once I know this and what transmitter you have I will be able to tell you if you can use my model or not. If not I will make a model for you. All I would have to do is make some changes in the settings for your transmitter and servo Channel Reverse settings.
- FireAngel
12 Jan 2014 18:21 #18436
by FireAngel
Sorry for the poor info,
I have the devo10 and have just put on deviation 4.0.1.
I just got the heli BNF so i dont have a model setup yet but the instructions say
swash type: 1 servo normal
The instructions dont have the devo10 settings But the Reverse switch settings are all shown as normal for devo6,7,8,12.
- Tom Z
- Topic Author
12 Jan 2014 18:45 #18437
by Tom Z
Thanks, that is everything I need to know.
From what you posted all my model settings are the same as the V200D01 settings so the model will (should) work for the V200D01. You can use my Standard Settings or Beginner Settings model.
Let me know if you try the model and I will update my posts that the model will also work for the Walkera V200D01.
- FireAngel
12 Jan 2014 18:59 #18439
by FireAngel
That's Great Tom, Thanks very much.
- FireAngel
12 Jan 2014 19:22 #18441
by FireAngel
Just Done a quick test hover inside and everything seems to work ok.
- Tom Z
- Topic Author
12 Jan 2014 21:27 #18444
by Tom Z
Replied by Tom Z on topic Walkera FP Helicopters - Standard Settings
Your welcome.
That's Great! Thanks for letting me know. I have updated my posts that the model will also work on the Walkera V200D01 with the Devo Receiver.
Time to create page: 0.095 seconds
- Home
- Walkera FP Helicopters - Standard Settings
