Walkera V450D01/D03 - 3D Settings
- Tom Z
08 Jan 2014 02:11 - 30 Apr 2014 15:22 #18180
by Tom Z
My model does not use a Fixed ID.
If you used a Fixed ID with the original Walkera firmware you must clear the Fixed ID in the Receiver with the Bind Plug.
If you don't clear the Fixed ID the model will not bind.
If you want to use a Fixed ID you can enter the same Fixed ID you had for the original Walkera firmware.
Example: Your original Walkera firmware Fixed ID was: 123456
Assign the Deviation Fixed ID: 123456
You can also assign any Fixed ID that you want to use. You don't have to use the original Walkera firmware Fixed ID. Clear the Fixed ID in the Receiver with the Bind Plug then assign any Fixed ID that you want to use.
Gyro Gain
Set to 60% for Normal and Stunt modes. This value is equal to the Walkera firmware value of 80% gyro gain.
Throttle Curve
Normal: -100, -33, 33, 100, 100, 100, 100
ST-1: V Shaped Throttle Curve
ST-2: 100% Flat Across
Pitch Curve
Normal: About -1.5* negative pitch. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP EXP -6%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
Install the configuration settings file into your models folder.
Example: The file you downloaded is named model5 so change the “5? to another slot
See my video:
Walkera V450D01/D03 - 3D Settings was created by Tom Z
- TX Power=100mW
- Channels=7
- Protocol=DEVO
- No Fixed ID
- Throttle Hold is active on RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
Model 16 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Gyro Gain
Throttle Curve
Pitch Curve
DR/EXPO
Switch Position
Switch Position
See my video:
Last edit: 30 Apr 2014 15:22 by Tom Z.
Time to create page: 0.970 seconds
Model Configs
- Walkera V450D01/D03 - 3D Settings
