Blade mQX
- Tom Z
09 Jan 2014 01:13 - 15 Feb 2014 23:34 #18255
by Tom Z
Turn up RUD Scale -/+ to 150 if you want faster piros.
Blade mQX was created by Tom Z
- Throttle hold on the RUDD D/R switch
- TX Power=100mW
- Protocol=DSMX
- No Fixed ID
Model 19 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Flight Mode controls the response.
- Flight Mode 1 = Beginner Settings
- Flight Mode 2 = Standard Settings
- Flight Mode 3 = Aggressive Settings
Last edit: 15 Feb 2014 23:34 by Tom Z.
Time to create page: 1.000 seconds
