Blade mQX
09 Jan 2014 01:13 - 15 Feb 2014 23:34 #18255 by Tom Z
Blade mQX was created by Tom Z
  • Throttle hold on the RUDD D/R switch
  • TX Power=100mW
  • Protocol=DSMX
  • No Fixed ID
  • Stick Mode 2
  • If you need Stick Mode 1, 3, or 4 load the model into your transmitter then change the Stick Mode in the transmitter settings.
    Model 19 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
    Flight Mode controls the response.
  • Flight Mode 1 = Beginner Settings
  • Flight Mode 2 = Standard Settings
  • Flight Mode 3 = Aggressive Settings
Turn up RUD Scale -/+ to 150 if you want faster piros.
Last edit: 15 Feb 2014 23:34 by Tom Z.
18 Feb 2015 12:35 #28807 by mario123
Replied by mario123 on topic Blade mQX
Thank you for your config. I tried to configure my mQx for over an hour and it didn't flew. With your config it was easy doing.
P.S. Sorry for bad English.
Time to create page: 0.041 seconds
