Blade Nano CP X - 3D Settings
- Tom Z
26 Jan 2014 16:53 - 15 Feb 2014 23:30 #19169
by Tom Z
Normal: 0% 40% 60% 80% 100%
ST-1: 100% 90% 80% 90% 100%
ST-2: 100% Flat Across
Pitch Curve
Normal Mode: -3* negative pitch. Zero degrees pitch at mid stick.
ST- 1: Full +/- 3D pitch curve. Zero degrees pitch at mid stick.
ST- 2: Full +/- 3D pitch curve. Zero degrees pitch at mid stick.
DR/EXPO
Switch Position
0- ELEV D/R = 100% EXP +30%
0- AILE D/R = 100% EXP +30%
RUDD D/R = 100% EXP -6%
Switch Position
1- ELEV D/R = 125% EXP LIN
1- AILE D/R = 125% EXP LIN
Blade Nano CP X - 3D Settings was created by Tom Z
- Throttle hold on the RUDD D/R switch.
- 7 Point Throttle and Pitch Curves.
- TX Power=100mW
- Channels=7
- Protocol=DSMX
- No Fixed ID
Model 35 is for deviation firmware v4 and the DEVO 6/6S/8/8S/10/12/12S.
Model 35-2 has Zero Degree Pitch when throttle hold is on.
If you want control of the swash in TH to help you land in a crash don’t use this model use Model 35 instead.
Pitch Curve
DR/EXPO
Switch Position
Switch Position
Last edit: 15 Feb 2014 23:30 by Tom Z.
- Tom Z
26 Jan 2014 19:38 - 26 Jan 2014 19:57 #19196
by Tom Z
Replied by Tom Z on topic Blade Nano CP X - 3D Settings
I forgot to add my custom GUI. I just added it and re-uploaded the models.
If you downloaded the file before I posted this you should download the model again as that model will use the default GUI on your transmitter and not my custom GUI which works on all the transmitters, has all the switch icons assigned to them, and has a custom layout for your home screen.
Last edit: 26 Jan 2014 19:57 by Tom Z.
Time to create page: 0.299 seconds
Model Configs
- Blade Nano CP X - 3D Settings
